How to set transmit power for BLE in nRF Connect SDK?
How can I adjust the BLE transmit (Tx) power, up to and including +8 dBm? I'm using nRF Connect SDK (NCS) on an nRF52840-DK.
I modified the throughput sample to reverse the roles (GAP central becomes GATT server; GAP peripheral becomes GATT client), added timeslots and radio notifications.
I've tried 2 different approaches so far, neither of which fully works. I'm testing by running the code on one nRF52840-DK, pressing Button #2 to make it the peripheral (advertising), and scanning with an nRF52840-Dongle (with "nRF Connect for Desktop Bluetooth Low Energy Standalone v4.0.0") on my PC to see its Rx signal strength.
I see a possible 3rd approach, but the code doesn't make sense to me, and I'm not sure if it applies.
Approach #1a - mpsl_tx_power_channel_map_set(), NCS v2.0.2
This seems to work up to 0 dBm, i.e. I get higher Rx signal strength at the Dongle when DK is set to 0 dBm compared to -20 dBm. But there is no difference in Rx signal strength comparing Tx power set to 0 and 8 dBm.
Approach #1b - mpsl_tx_power_channel_map_set(), NCS v2.1.0-rc1
Doesn't work. No difference in Rx signal strength, regardless of Tx power setting.
Approach #2 - mpsl_tx_power_radio_supported_power_adjust(), NCS v2.1.0-rc1
Note, this is the first tag where mpsl_tx_power_radio_supported_power_adjust() is provided.
Possible Approach #3 - Imitate HCI Power Control Sample
I haven't tried this. Does this fit my situation, since I'm not using the HCI in my application?
Also, the set_tx_power() function looks like it's setting values (members of the cp struct) as if to use them to control the tx power, but it never uses them. How does this even work?
throughput_mod__no_tx_pwr_ctrl.zip
throughput_mod__approach_1a.zip
throughput_mod__approach_1b.zip
throughput_mod__approach_2.zip
  • Hi Brendan,
    BT_HCI_VS_LL_HANDLE_TYPE_SCAN  only applied for when you do scanning (send scan request), not when you do advertising. If you want that mode you need to enable Observer role.
    Please test and verify that you can change the txpower when you advertise and when you are connected.
    bmcdonnell-npm said:
    will I be able to use this set_tx_power() function for dynamic power control, and also use the MPSL for timeslots?
    Yes.
  • Please test and verify that you can change the txpower when you advertise and when you are connected.
    Already verified using your example, but it does not work when connected in my attached code "approach 3.1". What is wrong there?
  • I did some further experimentation to simplify things. Attached is code for "Approach 3.2", in which I started over with the throughput example, and only modified it to add a shell command "tx_pwr" which uses your set_tx_power() and get_tx_power() functions. It still has the same problem as my previous attempts, which (more specifically) is that it does not set or get the tx_power on the GAP peripheral device for the connected mode (BT_HCI_VS_LL_HANDLE_TYPE_CONN), regardless of whether the functions are called before or after the connection is established. (It does set it for the central, but only after the connection is established.)
    Here is the unmodified code, so you can diff them to see what I added:
    throughput_base.zip
    With my "Approach 3.2" modification:
    throughput_mod__approach_3.2_simplified.zip
    Here is the corresponding console output from the peripheral:
    How can I set the tx power of the peripheral for the connected state?
  • Hi Brendan,
    If you call  set_tx_powerBT_HCI_VS_LL_HANDLE_TYPE_CONN  when you are not in a connection you will get error -5.
    Please test with my attached example.
    You can see in the following sniffer trace, the first test is when I  call set_tx_powerBT_HCI_VS_LL_HANDLE_TYPE_CONN .. with value 8 dBm when connected:
    Before and after connection, the RSSI of the advertiser/peripheral are the same (-14 to -17dBm)
    And here is when I call  set_tx_powerBT_HCI_VS_LL_HANDLE_TYPE_CONN  with value -8 dbm, notice the different in the RSSI before and after connection.
    set_tx_power() is called inside connected() call back.
  • Please test with my attached example.
    I'm unable to download it. When I click the link, it takes me to a page which says,
    Unfortunately, the page you've requested no longer exists. Please use the search form above to locate the information you're interested in.
    Can you fix the link, or provide it again, or some other way?
    EDIT: I was able to download the file from the email notification, but not this thread. I'll test with it...
    Also, how did you take the sniffer trace? Can I take one somehow with the nRF52840 Dongle?
