Converting BLE_peripheral UART example to support 4 peripheral connections
Hi All,
I modified ble_peripheral UART example to support 4 peripheral links instead of one by referring the bel_app_multiperipheral example, I am able to connect four mobiles(central devices) to it and sending (from central devices ) some strings successfully to peripheral.
now question is how to replay from peripheral to all central devices? actually I tried with below function to send the strings from peripheral to central devices
void vfnSendSensorResponsOnBle(uint8_t *ptr, uint32_t len)
         uint8_t uIndex = 0;
         uint32_t err_code = 0;
         for (uint32_t i = 0; i < NRF_SDH_BLE_PERIPHERAL_LINK_COUNT; i++)
              if (m_qwr[i].conn_handle != BLE_CONN_HANDLE_INVALID)
                    do
                        if(len>20)
                           len=19;
                       err_code = ble_nus_data_send(&m_nus, ptr, (uint16_t *)&len, m_qwr[i].conn_handle/*m_conn_handle*/);
                   } while (err_code == NRF_ERROR_RESOURCES);
with the above function able to send strings from peripheral to central when one central device is connected. when I tried the same with more than once central connections, peripheral device getting restarted.
Here I am not getting what causing for it, I think  need to modify above function.
Please let me know what are the things need to be change or any example for reference other than  bel_app_multiperipheral.
Thanks in Advance
Sudheer
    changed my function little bit, now it's working
        uint8_t uIndex = 0;
        ble_conn_state_conn_handle_list_t conn_handles = ble_conn_state_periph_handles();
        for (uint32_t i = 0; i < conn_handles.len; i++)
             if ((ble_conn_state_valid(conn_handles.conn_handles[i])==true))
                 do
                    err_code = ble_nus_data_send(&m_nus, ptr, (uint16_t *)&len, conn_handles.conn_handles[i]);
    and also able to send 253 bytes long string with all the central devices by changing the RAM size.
    thank you every one!
