No heap space for incoming notifications
We have an application running on an nRF9160 development board (shortly to be ported to a production board), which listens on a serial link for sensor data, which is then sent via udp/dtls, via NB-IoT.
The development board is connected to a serial terminal for diagnostics.
After several messages have been sent there's a warning message printed out on the console:
"W: No heap space for incoming notification: +CSCON: 0"
or
"W: No heap space for incoming notification: +CSCON: 1"
I've tried doubling heap space and also system workqueue stack size in prj.conf
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
However this has made no difference.
There is no apparent impact on the application itself, but I would of course prefer to properly handle whatever is causing the warning.
Help with this would be appreciated. Thanks.
  • Wow, thanks ever so much for giving this some serious consideration Achim.  A memory leak is of course more than likely, despite no obvious candidates having walked through the code many times. Also surprising in that case that is doesn't eventually lead to a failure.  Or maybe it simply hasn't run enough times yet. Will have a go with Valgrind, see if that throws up anything suspicious. Will check logging. Also, didn't know about the modem heap size parameter, thanks for that, will try increasing it first opportunity then reply again later.
  • (Of course valgrind isn't applicable, was still in Linux dev mode!).
    Have tried changing CONFIG_NRF_MODEM_LIB_HEAP_SIZE, so memory allocation in prj.conf is now:
    # Heap and stacks
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    CONFIG_NRF_MODEM_LIB_HEAP_SIZE=2048
    No change.
    Have tried setting CONFIG_LOG_MODE_DEFERRED to y and n in prj.conf
    No change, apart from the warning being in bold with a timestamp when set to y
    The application itself is very simple.  Just one system workqueue worker function running in a loop that waits for and reads messages from an application mcu from a uart via a short message queue, transmits them via dtls/NB-IoT, then transmits replies via the uart back to the application mcu.  There are no mallocs in the application. The message queue is created once in main as is the worker function.
    The warning - W: No heap space for incoming notification: +CSCON: 0
    Seems to occur during the wait for incoming uart messages, before any data to send arrives from the application mcu via the uart:
    k_msgq_get(&receive_event_msq, &rxevt, K_FOREVER);
    That queue is only 4 elements max, with each q element event buffer at 48 bytes.
    The entire worker function is reproduced below in case you can spot anything suspicious:
    static void server_transmission_work_fn(struct k_work *work)
    	int err;
    	struct receive_event rxevt; //** NB - receive_event struct data buffer is currently size 96 in sockets.h
    	int received;
    	uint8_t recv_buf[DOWNLINK_RCV_BUF_SIZE];
    	for(;;) { // infinite loop
    		printk("\r\n>>> server_transmission_work_fn started <<<\r\n");
    		//** read message to transmit from the message queue
    		//** NB - k_forever waits until a message arrives in the queue
    		printk("Base board receive buffer to send is: %s\r\n", rxevt.data);
    		printk("Transmitting UDP/IP payload of %d bytes to the ", rxevt.length + UDP_IP_HEADER_SIZE);
    		printk("IP address %s, port number %d\n", CONFIG_UDP_SERVER_ADDRESS_STATIC, CONFIG_UDP_SERVER_PORT);
    		printk("Message buffer to send is: ");
    		for (int i = 0; i < rxevt.length; i++) printk("%02X",rxevt.data[i]);
    		printk("\r\n");
    		//** NB - need to reconnect (create socket) for each transmission, disconnect after receive timeout
    		//** or on error
    		err = server_connect();
    		if (err) {
    			printk("Not able to connect to UDP server\n");
    			goto exitloop;
    		else {
    			printk("Connected to UDP Server\r\n");
    		// if (endndx > 0) { // endndx is the length of data to send - packet found if endndx > 0
    		if (rxevt.length > 0) {
    			// err = send(client_fd,&rxevt.data[startndx],endndx, 0);
    			err = send(client_fd, rxevt.data, rxevt.length, 0);
    			if (err < 0) {
    				printk("Failed to transmit UDP packet, %d\n", errno);
    				goto exitloop;
    			else {
    				printk("Packet transmitted\r\n");
    			memset(recv_buf,0, sizeof(recv_buf));
    			//** Receive udp return message
    			received = recv(client_fd, recv_buf, sizeof(recv_buf), MSG_WAITALL); //NB - If MSG_DONTWAIT flag used recv returns err and no message
    			if (received <= 0) {
    				printk("No udp reply\r\n");
    				//** Saved outgoing message should be resent up to n times
    				//** By injecting into base uart receive message queue
    				if (sendretrycount < MAXSENDRETRIES) {
    					//** push base uart received buffer back into message queue
    					while (k_msgq_put(&receive_event_msq, &rxevt, K_NO_WAIT) != 0)  {
    						//** message queue is full: purge old data & try again
    						k_msgq_purge(&receive_event_msq);
    					sendretrycount += 1; // increment retry count
    			else {
    				sendretrycount = 0;
    				printf("udp reply is: ");
    				for (int i = 0; i < received; i++) printk("%02X",recv_buf[i]);
    				printk(" length: %d\r\n", received);
    				//** Send receive message to base board via dma transmit
    				uart_tx(baseuart,recv_buf, received, SYS_FOREVER_MS);
    		else {
    			printk("Failed to find valid packet in receive buffer\r\n");
    	exitloop:
    		// ** Disconnect udp socket - closes client_fd
    		server_disconnect( );
    	}// end infinite for(;;)
    Thanks again, Ron.
  • I searched for "No heap space for incoming notification" and found it in "nrf/lib/at_monitor/at_monitor.c". That at_monitor contains a Kconfig and that:
    config AT_MONITOR_HEAP_SIZE
        int "Heap size for notifications"
        range 64 2048
        default 256
    Interesting, how many different heaps are used.
    On a first look, at_monitor copies all received data and put that into a fifo, where a monitor tasks takes the data, calls the handler, and frees the data.
    I guess, depending on what you do in the handler callback, that may lead to a shortage in that heap.
  • Thanks for the detective work Achim, problem solved.
    After adding CONFIG_AT_MONITOR_HEAP_SIZE=1024 to prj.conf the warning message no longer appears.  Much appreciated.
  • You're welcome.
    (It's cool, just spend few moments for a hint, and let you do the time intensive tests :-) .)
