No heap space for incoming notifications
We have an application running on an nRF9160 development board (shortly to be ported to a production board), which listens on a serial link for sensor data, which is then sent via udp/dtls, via NB-IoT.
The development board is connected to a serial terminal for diagnostics.
After several messages have been sent there's a warning message printed out on the console:
"W: No heap space for incoming notification: +CSCON: 0"
or
"W: No heap space for incoming notification: +CSCON: 1"
I've tried doubling heap space and also system workqueue stack size in prj.conf
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
However this has made no difference.
There is no apparent impact on the application itself, but I would of course prefer to properly handle whatever is causing the warning.
Help with this would be appreciated. Thanks.
  • Ok, understood Achim. Thanks for your efforts in trying to track the problem down.  Will report back if I do eventually discover a root cause.
    are you using the system workqueue in your application? It's possible that the system workqueue is running tasks that are blocking the at monitor from running so the at notification fifo won't clear out. Have you checked this?
  • Thanks for the reply, appreciate your picking this up.
    Apart from the work task waiting for messages to arrive in a message queue:
    k_msgq_get(&receive_event_msq, &rxevt, K_FOREVER);
    There are no other tasks that have been started by me to run on the system work queue.
    New to Zephyr, I've been assuming that waiting on a k_msqq_get would automatically yield to allow other tasks on the system work queue to run.  Is that incorrect?
  • The system work queue is a job queue. A job is added with k_work_submit as in at_monitor.c,
        k_work_submit(&at_monitor_work);
    What is suspicious is the
    static void server_transmission_work_fn(struct k_work *work)
    in your snippet. Because that's usually a function assigned to such a job. e.g.
    static K_WORK_DEFINE(server_transmission_work, server_transmission_work_fn);
    and
        k_work_submit(&server_transmission_work);
  • Hi Achim,
    server_transmission_worker_init();  // initialise the udp worker
    	baseuart_connect_async(baseuart); // Also creates dma buffer storage
    	//## Kick off main transmission worker here
     	k_work_submit(&server_transmission_work);  // uses system workthread
    Yes, in main() a system workqueue worker task to transmit/receive data over dtls/NB-IoT is initialised, a uart connection to another mcu is also initialised, then the system workqueue transmission worker task is started. This waits on k_msgq_get for messages that are created on the queue by bytes coming across the uart link by the (simple) uart dma interrupt routine that marshals the bytes into a message pushed onto the message queue. Those messages are then sent via dtls/NB-IoT to a dtls2mqtt gateway with responses being sent back across the uart link.
    Am quite open to modifying this design if there is a better approach, or if it is preferable that the work is done in an application workqueue rather than the system one.
