No heap space for incoming notifications
We have an application running on an nRF9160 development board (shortly to be ported to a production board), which listens on a serial link for sensor data, which is then sent via udp/dtls, via NB-IoT.
The development board is connected to a serial terminal for diagnostics.
After several messages have been sent there's a warning message printed out on the console:
"W: No heap space for incoming notification: +CSCON: 0"
or
"W: No heap space for incoming notification: +CSCON: 1"
I've tried doubling heap space and also system workqueue stack size in prj.conf
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
However this has made no difference.
There is no apparent impact on the application itself, but I would of course prefer to properly handle whatever is causing the warning.
Help with this would be appreciated. Thanks.
  • In the end, it was as you indicated Achim, ridiculously simple, in about 4 lines of code, to create another workqueue thread and assign the work task to that with no other changes. Since doing that a few hours ago the application has been almost continuously running with no warnings. Will see what happens overnight, then all being well close this question  .. again! Cheers Ron.
  • Running for more than 12 hours now with no warning messages. Clearly the problem is solved.
    Am including code here in case it helps others.
    #define TRANSMISSION_STACK_SIZE 1024
    #define TRANSMISSION_PRIORITY 5
    K_THREAD_STACK_DEFINE(transmission_stack_area, TRANSMISSION_STACK_SIZE); // define memory for application workqueue
    struct k_work_q transmission_work_q; // application workqueue
    static struct k_work server_transmission_work; // A work Q element - infinite loop that receives, parses and acts on message events
    k_work_queue_init(&transmission_work_q); // intialise workqueue
    // start workqueue
    k_work_queue_start(&transmission_work_q, transmission_stack_area,
                       K_THREAD_STACK_SIZEOF(transmission_stack_area), TRANSMISSION_PRIORITY,
                       NULL);
    k_work_init(&server_transmission_work, server_transmission_work_fn);  // initialise worker task - points to function that does the work
    // k_work_submit(&server_transmission_work);  // uses system workqueue
    k_work_submit_to_queue(&transmission_work_q, &server_transmission_work); // worker task uses application workqueue
    Initially when the stack size of the workqueue was set to 512 the device panicked. At 1024 it is running perfectly.
    Thanks again. Cheer Ron.
