J-Link connection lost after a few seconds
I have been learning to use the nrf52840DK for some time now, though I would consider myself still a beginner. Anyway, something has gone wrong with the kit and I am not sure what. It does not seem to be able to connect with the J-link I've been always using.
Two days ago, I was able to connect it to my PC and download and debug code naturally. I was even able to use the J-Link EDU kit normally, with both the 19-pin and the 9-pin Cortex-M adaptors. Yesterday, I plugged the kit in my PC, as always through the USB. LED5 is on, as always, and the kit is recognized as a J-Link driver. I thought that everything was OK, but in SES, the connect J-Link command returned the "Failed to connect to target" error. The J-Link EDU kit's light was orange. Something has gone terribly wrong. I have tried resetting the kit and downloading the J-Link OB file in the Bootloader, but that does not change anything.
The first time I connected the DK to my PC today, it acted normally and I was even able to connect the J-Link, though LED2 and LED3 were on unexpectedly. I downloaded an example just to see that it works, and at first it worked. After a few seconds the kit was no longer available for J-Link connection in SES (although visible as a J-Link Driver in MyComputer) and the program had stopped its execution (the LEDs were blinking no more). After disconnecting and reconnecting the kit, LED5 is just on, but nothing changed. The downloaded program is not being executed and the J-Link connection is not possible.
Do you know how I could fix this issue?
Thank you in advance!
    kostathan said:
    The VDD voltage of the kit is at 2.98V(VDD-GND) and the RESET pin's voltage is 0 (RESET-GND). What baffles me is that the voltage difference between the RESET pin and the VDD pin also appears to be 0.
    This is very strange. RESET should be pulled high, if it's low then the nRF52840 is kept in RESET state. Can you try to pull it high by connecting VDD to RESET and see if it "wakes up" the board.
    regards
    Jared
  • This is very strange. RESET should be pulled high, if it's low then the nRF52840 is kept in RESET state. Can you try to pull it high by connecting VDD to RESET and see if it "wakes up" the board.
    So, something pretty strange is going on. I am listing the voltage measurements I made:
    VDD-GND = 2.98V
    RESET-GND = 0
    VDD-RESET = 0 (I don't know how the last 3 can be possible at the same time)
    5V-GND=5.01V
    5V-RESET=1.61V (So reset is definitely at high)
    5V-VDD=2.01V
    All the above seem chaotic. I also tried to connect the VDD with RESET and nothing happened.
    Maybe the pin RESET feature isn't activated in your project. In that case, the pin would just act as a normal GPIO, which would explain your measurements.
    Have you modified any of the solder bridges on your DK and can you list the state of the following switches:
    • SW10
    • SW9
    • SW6
    • SW8
    Can you elaborate on this? Are you using a stand alone debugger? How have you connected the DK to your computer?
    regards
    Jared
  • Hello again.
    I haven't modified anything on my DK. The state of the switches is:
    SW10: OFF
    SW8: ON
    SW9: VDD
    SW6: DEFAULT
    I believe that reset is activated, since I can put the kit in bootloader mode with IF BOOT/RESET button.
    Normally, I use the DK with a USB. Recently, I was provided with Segger's J-Link EDU module to check its debugging capabilities. Now the DK doesn't work either with the USB or with the module. There aren't any problems with the debug probe, since my other DK has worked perfectly with it. Could the problem have been caused by a forced PC reboot that happened while the DK was connected to the PC?
  • Hello again.
    SW10: OFF
    SW8: ON
    SW9: VDD
    SW6: DEFAULT
