Hello
nRF5340-audio-DK, NCS2.0.2, VScode
press BUTTON_VOLUME_UP then button reset,can't change to channel right.
change to channel right failed, return -30
another question, 5340-audio can DFU?
Best regards
Hello
Best regards
Hi
Fortunately proper DFU support was added in version 2.1.0 of the nRF Connect SDK. You can read more about this here.
Best regards
Torbjørn
thanks for reply, i will got it.
the last queston:
1.CIS mode,when is bidirectional communication supported?
2.when LC3 support 16bit 16kHZ?
Best regards
Hi
jettoo said:1.CIS mode,when is bidirectional communication supported?
This is work in progress, yes. There is no schedule for it right now, but hopefully we will have more information about this soon.
jettoo said:2.when LC3 support 16bit 16kHZ?
The codec supports it already, but currently it is not very easy to change from the application side. There is a pull request in the works to simplify this process, you can check it out here.
Best regards
Torbjørn
Hi
thanks for reply,
i've update v2.1.0, it can see dfu folder.
there will no overlay-gateway.conf and overlay-headset.conf
Best regards
Hi
In order to change between headset and gateway you can set CONFIG_AUDIO_DEV in your prj.conf file.
Set it to 1 for headset and 2 for gateway, as described in the Kconfig file:
config AUDIO_DEV int "Select which device type to compile for. 1=HEADSET or 2=GATEWAY" range 1 2 default 1 help Setting this variable to 1 selects that the project is compiled as a HEADSET device. Setting to 2 will compile as a GATEWAY.
Best regards
Torbjørn
