Bluetooth connexion issue
Hello community,
I'm trying to implement BT service on my project to be able to connect with my phone
for information my project displays data from sensors(BME280, INA219, MPU6050)  connected to my D-kit
i'm using nrf connect V1.8.0 and NRF5340dk
i got inspired from this BT tutorial to create my services
but in terms of BT connexion i don't get the device on my ophone when i scan devices around
which means that connexion isn't established
and i got this message "Advertising failed to start (err-11)"
i will attach below my output display
i tried to flash my D-kit directly but it didn't work
and i tried to activate the BT but in vain too
i tried to use this function
    //Start advertising
	err = bt_le_adv_start(BT_LE_ADV_PARAM(
							BT_LE_ADV_OPT_CONNECTABLE
							|BT_LE_ADV_OPT_ONE_TIME
							|BT_LE_ADV_OPT_USE_NAME,
							160, 	// units of 0.625ms
							1600),	// units of 0.625ms
						ad, ARRAY_SIZE(ad),
						sd, ARRAY_SIZE(sd));
Can you guys help  by telling me what's wrong on this situation
why can't i get the bt to advertise
do i missing something on the main or on the activation
by the way my prj.conf should be good and i will liked below
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_MAX_CONN=1
CONFIG_BT_L2CAP_TX_BUF_COUNT=5
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="My_Device"
CONFIG_BT_DEVICE_APPEARANCE=962
CONFIG_HEAP_MEM_POOL_SIZE=2048
# This example requires more workqueue stack
CONFIG_STDOUT_CONSOLE=y
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_SENSOR=y
CONFIG_I2C=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_UART_CONSOLE=n
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_PRINTK=y
CONFIG_INA219=y
CONFIG_BME280=y
CONFIG_SHELL_BACKEND_SERIAL=y
Can you help me with this please
i will be very grateful
    infinite thanks for taking a look into my warnings
    but i want to tell you that:
    now that i replaced "static void bt_ready_data_data_data_data_work_work_work_work_fn(struct k_work *work)" with "static void bt_ready_data_data_data_data_work_work_work_work_fn(int err)"
    i'm getting a new code error
    and since u told me that i should pay attention to warnings
    after my build i'm getting a warning when i'm calling the "k_work_init(&bt_ready_data_data_data_data_work, bt_ready_data_data_data_data_work_work_work_work_fn);" in my static void work init
    the warning message is " passing argument 2 of 'k_work_init' from incompatible pointer type [-Wincompatible-pointer-types] "
    Do you know what the code error means please
    is it caused by the warning ? how can i repare this warning please ?
    grateful for your help in advance
  • Rihab said:
    i tried to search for the function bt_le_is_ready but i can't find it no where
    There is no need for it here, it was just an idea based on the error you described before I saw all your code.
    Yes, that is good.
    Why are there 2 arguments?  The first argument you had there was invalid,  bt_ready_data_data_data_data_work_work_work_work_fn must have the prototype defined by the BT application, so it can only take an integer as argument, and this will be the error code. You cannot have struct k_work in there, as this is populated by the Bluetooth stack and it would not know where to put there. So, your bt_ready_data_data_data_data_work_work_work_work_fn must look like this (though you can of course change the name of the function and the name of the variable holding the error code if you like):
  • Thank you so much for the explanation. Now i entirely understand.
    But in your opinion what is causing the BT initialization to fail ?
    do you know what the code error below refers to please  ?
    BLE init failed with error code 536875240
  • I have not seen your updated code, but based on what you described I assume the problem is related to what I described in my previous post: Your error variable is invalid and contains random/rubbish data, and you print that. So it does not mean anything.
  • here's my updated code
    #include <zephyr.h>
    #include <device.h>
    #include <drivers/sensor.h>
    #include <stdio.h>
    #include <sys/util.h>
    #include <sys/printk.h>
    #include <inttypes.h>
    #include <drivers/gpio.h>
    #include <zephyr/types.h>
    #include <stddef.h>
    #include <string.h>
    #include <errno.h>
    #include <sys/byteorder.h>
    #include <soc.h>
    #include <bluetooth/bluetooth.h>
    #include <bluetooth/hci.h>
    #include <bluetooth/conn.h>
    #include <bluetooth/uuid.h>
    #include <bluetooth/gatt.h>
    #include "C:/sdk/v1.9.0/zephyr/samples/sensor/inaa219/services/my_service.h"
    #define DEVICE_NAME 		CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN 		(sizeof(DEVICE_NAME) - 1)
    #define SLEEP_TIME_MS	1
     * Get button configuration from the devicetree sw0 alias. This is mandatory.
     Replace DT_ALIAS(sw0) by sw27 to get output through SCT click
    #define MY_SERVICE_UUID 0x0001
    #define SW0_NODE	DT_ALIAS(sw0)
    #if !DT_NODE_HAS_STATUS(SW0_NODE, okay)
    #error "Unsupported board: sw0 devicetree alias is not defined"
    static const struct gpio_dt_spec button = GPIO_DT_SPEC_GET_OR(SW0_NODE, gpios,
    							      {0});
    static struct gpio_callback button_cb_data;
    static struct gpio_dt_spec led = GPIO_DT_SPEC_GET_OR(DT_ALIAS(led0), gpios,
    						     {0});
    static int on_click = 1;
    #define APP_WORK_QUEUE_SIZE 4096
    #define APP_WORK_QUEUE_PRI -1
    K_THREAD_STACK_DEFINE(application_stack_area, APP_WORK_QUEUE_SIZE);
    static struct k_work_q application_work_q;
    static struct k_work bt_ready_data_data_data_data_work;
    static struct k_work get_ina219_data_data_data_work;
    //static struct k_work get_bme280_data_data_work;
    static struct k_work get_mpu6050_data_work;
    static K_SEM_DEFINE(ble_init_ok, 0, 1);
    static const struct bt_data ad[] =
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    static const struct bt_data sd[] =
    	BT_DATA_BYTES(BT_DATA_UUID128_ALL, MY_SERVICE_UUID),
    struct bt_conn *my_connection;
    static void connected(struct bt_conn *conn, uint8_t err)
    	struct bt_conn_info info;
    	my_connection = conn;
    	if (err)
    		printk("Connection failed (err %u)\n", err);
    		return;
    	else if(bt_conn_get_info(conn, &info))
    		printk("Could not parse connection info\n");
    		printk("Connection established!		\n\
    		Connected to: %s			\n\
    		Role: %u				\n\
    		Connection interval: %u			\n\
    		Slave latency: %u                       \n\
    		Connection supervisory timeout: %u	\n"
    		, addr, info.role, info.le.interval, info.le.latency, info.le.timeout);
    	printk("Disconnected (reason %u)\n", reason);
    static bool le_param_req(struct bt_conn *conn, struct bt_le_conn_param *param)
    	//If acceptable params, return true, otherwise return false.
    	return true;
    static void le_param_updated(struct bt_conn *conn, uint16_t interval, uint16_t latency, uint16_t timeout)
    		printk("Connection parameters updated!	\n\
    		New Connection Interval: %u		\n\
    		New Slave Latency: %u			\n\
    		New Connection Supervisory Timeout: %u	\n"
    		, addr, info.le.interval, info.le.latency, info.le.timeout);
    static struct bt_conn_cb conn_callbacks =
    	.connected			= connected,
    	.disconnected   		= disconnected,
    	.le_param_req			= le_param_req,
    	.le_param_updated		= le_param_updated
    static const char *now_str(void)
    	static char buf[16]; /* ...HH:MM:SS.MMM */
    	uint32_t now = k_uptime_get_32();
    	unsigned int ms = now % MSEC_PER_SEC;
    	unsigned int s;
    	unsigned int min;
    	unsigned int h;
    	now /= MSEC_PER_SEC;
    	s = now % 60U;
    	now /= 60U;
    	min = now % 60U;
    	now /= 60U;
    	h = now;
    	snprintf(buf, sizeof(buf), "%u:%02u:%02u.%03u",
    		 h, min, s, ms);
    	return buf;
    static int process_mpu6050(const struct device *dev)
    	struct sensor_value temperature;
    	struct sensor_value accel[3];
    	struct sensor_value gyro[3];
    	int rc = sensor_sample_fetch(dev);
    	if (rc == 0) {
    		rc = sensor_channel_get(dev, SENSOR_CHAN_ACCEL_XYZ,
    					accel);
    	if (rc == 0) {
    		rc = sensor_channel_get(dev, SENSOR_CHAN_GYRO_XYZ,
    					gyro);
    	if (rc == 0) {
    		rc = sensor_channel_get(dev, SENSOR_CHAN_AMBIENT_TEMP,
    					&temperature);
    	if (rc == 0) {
    		printf("[%s]:%g Cel\n"
    		       "  accel %f %f %f m/s/s\n"
    		       "  gyro  %f %f %f rad/s\n",
    		       now_str(),
    		       sensor_value_to_double(&temperature),
    		       sensor_value_to_double(&accel[0]),
    		       sensor_value_to_double(&accel[1]),
    		       sensor_value_to_double(&accel[2]),
    		       sensor_value_to_double(&gyro[0]),
    		       sensor_value_to_double(&gyro[1]),
    		       sensor_value_to_double(&gyro[2]));
    	} else {
    		printf("sample fetch/get failed: %d\n", rc);
    	return rc;
    #ifdef CONFIG_MPU6050_TRIGGER
    static struct sensor_trigger trigger;
    static void handle_mpu6050_drdy(const struct device *dev,
    				struct sensor_trigger *trig)
    	int rc = process_mpu6050(dev);
    	if (rc != 0) {
    		printf("cancelling trigger due to failure: %d\n", rc);
    		(void)sensor_trigger_set(dev, trig, NULL);
    		return;
    #endif /* CONFIG_MPU6050_TRIGGER */
    static const struct device *get_ina219_device(void)
      const struct device *dev = DEVICE_DT_GET_ANY(ti_ina219);
            if(dev == NULL){
                      printk("\nEror: no device found. \n");
                      return NULL;
             if (!device_is_ready(dev)) {
    		printk("\nError: Device \"%s\" is not ready; "
    		       "check the driver initialization logs for errors.\n",
    		       dev->name);
    		return NULL;
    	//printk("Found device \"%s\", getting sensor data\n", dev->name);
    	return dev;
    /*static const struct device *get_bme280_device(void)
    	const struct device *dev = DEVICE_DT_GET_ANY(bosch_bme280);
    	if (dev == NULL) {
    		// No such node, or the node does not have status "okay".
    		printk("\nError: no device found.\n");
    		return NULL;
    		       dev->name);
    		return NULL;
    	return dev;
    static void get_mpu6050_data_work_fn(struct k_work *work)
    	printk("-----------------Get MPU6050 data\n" );
    	now_str(),
    /*static void get_bme280_data_data_work_work_fn(struct k_work *work)
                    printk("+++++++++++++++++Get BME280 data\n");
    		struct sensor_value temp, press, humidity;
    		sensor_sample_fetch(get_bme280_device());
    		sensor_channel_get(get_bme280_device(), SENSOR_CHAN_AMBIENT_TEMP, &temp);
    		sensor_channel_get(get_bme280_device(), SENSOR_CHAN_PRESS, &press);
    		sensor_channel_get(get_bme280_device(), SENSOR_CHAN_HUMIDITY, &humidity);
    		printk("temp: %d.%06d; press: %d.%06d; humidity: %d.%06d\n",
    		      temp.val1, temp.val2, press.val1, press.val2,
    		      humidity.val1, humidity.val2);
    static void get_ina219_data_data_data_work_work_work_fn(struct k_work *work)
          printk("################Get INA219 data\n");
          struct sensor_value v_bus, power, current;
          sensor_sample_fetch(get_ina219_device());
                    sensor_channel_get(get_ina219_device(), SENSOR_CHAN_VOLTAGE, &v_bus);
    		sensor_channel_get(get_ina219_device(), SENSOR_CHAN_POWER, &power);
    		sensor_channel_get(get_ina219_device(), SENSOR_CHAN_CURRENT, &current);
    		printf("Bus: %f [V] -- "
    			"Power: %f [W] -- "
    			"Current: %f [A]\n",
    		       sensor_value_to_double(&v_bus),
    		       sensor_value_to_double(&power),
    		       sensor_value_to_double(&current));
    static void error(void)
    	while (true) {
    		printk("Error!\n");
    		/* Spin for ever */
    		k_sleep(K_MSEC(1000)); //1000ms
    void button_pressed(const struct device *dev, struct gpio_callback *cb,
    		    uint32_t pins)
            printk("***************Button pressed at ");
            int val = gpio_pin_get_dt(&button);
            if(val == 1){
            gpio_pin_set_dt(&button, val);
            printk("Number of cycle : %d\n", on_click++);
            else if (val == 0){
            printk("Number of cycle : %d\n", on_click);
    	k_work_submit_to_queue(&application_work_q, &get_mpu6050_data_work);
            //k_work_submit_to_queue(&application_work_q, &get_bme280_data_data_work);
            k_work_submit_to_queue(&application_work_q, &get_ina219_data_data_data_work);
            k_work_submit_to_queue(&application_work_q, &bt_ready_data_data_data_data_work);
    	if (err)
    		printk("BLE init failed with error code %d\n", err);
    		return;
    	//Configure connection callbacks
            printk("callbacks");
    	bt_conn_cb_register(&conn_callbacks);
    	//Initalize services
            printk("initialisation");
    	err = my_service_init();
            printk("LBS \n");
    	//Start advertising
    	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),
            printk("BT Starting \n");
    	if (err)
    		printk("Advertising failed to start (err %d)\n", err);
    		return;
            else{
    	printk("Advertising successfully started\n");
    	k_sem_give(&ble_init_ok);
    static void work_init(void)
    	k_work_init(&get_mpu6050_data_work, get_mpu6050_data_work_fn);
    	//k_work_init(&get_bme280_data_data_work, get_bme280_data_data_work_work_fn);
            k_work_init(&get_ina219_data_data_data_work, get_ina219_data_data_data_work_work_work_fn);
    void main(void)
    	int ret;
            int err = 0;
    	uint32_t number = 0;
    	k_work_queue_start(&application_work_q, application_stack_area,
    			K_THREAD_STACK_SIZEOF(application_stack_area),
    			APP_WORK_QUEUE_PRI, NULL);
    	work_init();
    	if (!device_is_ready(button.port)) {
    		printk("Error: button device %s is not ready\n",
    		       button.port->name);
    		return;
    	ret = gpio_pin_configure_dt(&button, GPIO_INPUT);
    	if (ret != 0) {
    		printk("Error %d: failed to configure %s pin %d\n",
    		       ret, button.port->name, button.pin);
    		return;
    	ret = gpio_pin_interrupt_configure_dt(&button,
    					      GPIO_INT_EDGE_TO_ACTIVE);
    	if (ret != 0) {
    		printk("Error %d: failed to configure interrupt on %s pin %d\n",
    		return;
    	gpio_init_callback(&button_cb_data, button_pressed, BIT(button.pin));
    	gpio_add_callback(button.port, &button_cb_data);
    	printk("Set up button at %s pin %d\n", button.port->name, button.pin);
    	if (led.port && !device_is_ready(led.port)) {
    		printk("Error %d: LED device %s is not ready; ignoring it\n",
    		       ret, led.port->name);
    		led.port = NULL;
    	if (led.port) {
    		ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT);
    		if (ret != 0) {
    			printk("Error %d: failed to configure LED device %s pin %d\n",
    			       ret, led.port->name, led.pin);
    			led.port = NULL;
    		} else {
    			printk("Set up LED at %s pin %d\n", led.port->name, led.pin);
    	printk("Press the button\n");
    	/*if (led.port) {
    		while (1) {
    			// If we have an LED, match its state to the button's.
    			if (val >= 0) {
    				gpio_pin_set_dt(&led, val);
    			k_msleep(SLEEP_TIME_MS);
            printk("Starting BLE Service\n");
            err = bt_enable(bt_ready_data_data_data_data_work_work_work_work_fn);
    	if (err)
    		printk("BLE initialization failed (err %d)\n", err);
    		error(); //Catch error
    	/* 	Bluetooth stack should be ready in less than 100 msec. 					\
    		We use this semaphore to wait for bt_enable to call bt_ready before we proceed 		\
    		to the main loop. By using the semaphore to block execution we allow the RTOS to 	\
    		execute other tasks while we wait. */
    	err = k_sem_take(&ble_init_ok, K_MSEC(500));
    	if (!err)
    		printk("Bluetooth initialized\n");
    	} else
    		printk("BLE initialization did not complete in time\n");
    	for (;;)
    		// Main loop
    		//my_service_send(my_connection, (uint8_t *)&number, sizeof(number));
    		number++;
    		k_sleep(K_MSEC(1000)); // 1000ms
    	const char *const label = DT_LABEL(DT_INST(0, invensense_mpu6050));
    	const struct device *mpu6050 = device_get_binding(label);
    	if (!mpu6050) {
                    printf("All sensors configured %s\n", label);
    		//printf("Failed to find sensor %s\n", label);
    		return;
    	trigger = (struct sensor_trigger) {
    		.type = SENSOR_TRIG_DATA_READY,
    		.chan = SENSOR_CHAN_ALL,
    	if (sensor_trigger_set(mpu6050, &trigger,
    			       handle_mpu6050_drdy) < 0) {
    		printf("Cannot configure trigger\n");
    		return;
    	printk("Configured for triggered sampling.\n");
    	while (!IS_ENABLED(CONFIG_MPU6050_TRIGGER)) {
    		int rc = process_mpu6050(mpu6050);
    		if (rc != 0) {
    		k_sleep(K_SECONDS(2));
    is there something we can do to make it clean and therefore to get the BT to work ?
    thank you in advance
