NRF9160 Modem library
Looking at the architecture for NRF Modem library here:
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.0.0/nrfxlib/nrf_modem/doc/architecture.html
I can see that there is an interface for sockets integrated with Zephyr using the "off load" API.
Now, since boards such as NRF9160DK  also has a short-range radio i would ideally have a setup with "forwarding" between
short-range radio and the cellular modem but that is not really feasible with sockets.
There also seems to be an AT command interface - could this be used to create a driver in zephyr native stack?
Best
Peter
  • uart:~$ net iface
    Interface 0x200009b4 (IEEE 802.15.4) [1]
    Link addr : F4:CE:36:D7:42:B4:67:77
    MTU : 125
    Flags : AUTO_START,IPv6
    IPv6 unicast addresses (max 3):
    2001:db9::1 manual preferred infinite
    IPv6 multicast addresses (max 4):
    ff02::1
    ff02::1:ff7e:0
    ff02::1:ff00:1
    IPv6 prefixes (max 2):
    <none>
    IPv6 hop limit : 64
    IPv6 base reachable time : 30000
    IPv6 reachable time : 44104
    IPv6 retransmit timer : 0
    Interface 0x20000a20 (Dummy) [2]
    Link addr : 00:00:5E:00:53:99
    MTU : 576
    fd00::f823:7f11:b1ba:7736 manual preferred infinite
    ff02::1
    ff02::1:ff7e:0
    ff02::1:ffba:7736
    fd00::f823:7f11:b1ba:7736/64
    IPv6 hop limit : 64
    IPv6 reachable time : 27019
    uart:~$
  • Below i made a screendump from my Zephyr shell.
    As seen there is two network interfaces - one is 802.15.4 and one is SLIP to a host.
    In this case, since both networks are in the "native" Zephyr IP stack it is possible to set up routing/forwarding between these interfaces.
    But if i add a socket interface as on 9160 modem library i can not see how i can achieve this.
    (You could possibly do something for UDP but for TCP i cannot see it possible)
    Does this make things clear?
    Best
    Peter
    Just to make sure that this is not an XY-Problem:
    What is the problem you want to solve using this method?
    Sigurd Hellesvik
  • Well, i want to to "X" - IP routing.
    It would allow me to do "border routing" from one network such as 802.15.4  to LTE on NRF9160 device.
    I  can do "border routing" from 802.15.4 to Ethernet on Nordic HW Such as NRF52840 using USB Ethernet.
    Best
    Peter
  • Hi Peter,
    We offer no implementation for a Border Router for the nRF9160.
    But you know that, which is why you are trying to do it yourself.
    I have been looking around, and not been able to find out how you can do this using AT commands.
    I can neither promise that it is possible nor impossible though.
    Sigurd Hellesvik
