Timer and GPIOTE interrupts priorities
Hello!
I use NRF Connect SDK 1.8.0, but peripherials are configured using nrfx library.
My task is to implement serial interface where I have PIN_TX and PIN_RX. I transmit data over PIN_TX, when I'm transmitting data on PIN_TX I've got feedback on PIN_RX. On oscilloscop I can see that delay beetwen set PIN_TX and got feedback on PIN_RX is about 1us delay(electronic circuit delay).
PIN_TX is driven in Timer Output Compare mode but PIN_RX work in Timer Input Copture mode. Timer Output Compare interrupt is enabled and GPIOTE interrupt is enabled as well. They are configured with the same interrupt priority, let's say IRQ_PRIO_LOWEST-2.
Haw does situation looks 99.99% cases
1. Output Compare Event occur and PIN_TX has been toggle
2. Timer Output Compare interrupt occured
3. GPIOTE interrupt occured and I can read timer compare value that has been captured
But, sometimes situation looks a little bit different...
1. Output Compare Event occured and PIN_TX has been toggle
2. GPIOTE interrupt occured and I can read timer compare value that has been captured
3. Timer Output Compare interrupt occured
This situation never occur when I configure Timer whit higher priority than GPIOTE but then I have other problems...
The questions are:
* Interrupt can interrupt other interrupt with the same priority? (to this day I have been convinced that it is not)
* Is that mybe known problem and there is some solution to fix it? I have not so big experience with nrf52. I have never had similar situation when I was working with stm32...
