BLE Advertising Sets (which requires Extended Advertising) limits connections to 1 per service
I am migrating to use Advertising Sets, which require Extended Advertising, and I am seeing that the number of connections per-connectable-service is seemingly reduced to 1.
Meaning, when a single connection to an connectable-service occurs, advertising for that service is automatically shut off.  You can only subsequently re-enable advertising, manually, by waiting for that connection to disconnect.
Am I understanding that correctly?  This would be a change in behavior from the traditional Advertising (which allows many per-connectable service, globally bounded by CONFIG_BT_MAX_CONN).  The change in behavior is not desirable.
The other DevZone post here: Extended advertising stops after connection gets established in nRF Connect SDK  seems to indicate yes.
I want more than one connection per-connectable-service (without resorting to entering multiple entries into the advertising set, 1 for each connection).
How can that be done?
Or alternatively, how can I use multiple advertising sets without enabling Extended Advertising?
Or anything else you can suggest?
Thanks.
  • Hi thank you for the code.  I will examine it to see how it differs from mine.
    CONFIG_GPIO=y
    # CONFIG_SPI is not set
    # CONFIG_I2C is not set
    # CONFIG_KSCAN is not set
    CONFIG_LV_Z_POINTER_KSCAN_DEV_NAME="KSCAN"
    # CONFIG_DISK_DRIVER_SDMMC is not set
    # CONFIG_WIFI is not set
    CONFIG_NET_CONFIG_IEEE802154_DEV_NAME=""
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_MODEM is not set
    # CONFIG_SENSOR is not set
    # CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
    CONFIG_BT_HCI_VS_EXT=y
    CONFIG_BOARD="adafruit_feather_nrf52840"
    CONFIG_BT_CTLR=y
    CONFIG_SOC="nRF52840_QIAA"
    CONFIG_SOC_SERIES="nrf52"
    CONFIG_NUM_IRQS=48
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_PINCTRL=y
    # CONFIG_WATCHDOG is not set
    CONFIG_HEAP_MEM_POOL_SIZE=0
    CONFIG_ROM_START_OFFSET=0
    # CONFIG_UART_NS16550 is not set
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    # CONFIG_CORTEX_M_SYSTICK is not set
    CONFIG_CLOCK_CONTROL=y
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    # CONFIG_PM is not set
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_SERIAL_INIT_PRIORITY=55
    # CONFIG_FPU is not set
    # CONFIG_PWM_IMX is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_USB_MCUX is not set
    # CONFIG_MBEDTLS is not set
    CONFIG_TEST_EXTRA_STACK_SIZE=0
    # CONFIG_GPIO_MCUX is not set
    # CONFIG_USB_KINETIS is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    CONFIG_TINYCRYPT=y
    CONFIG_SERIAL=y
    # CONFIG_UART_PL011 is not set
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_MP_NUM_CPUS=1
    # Modules
    # Available modules.
    # nrf (/home/doug/ncs/v2.0.0/nrf)
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_INIT_STACKS=y
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_BT_BUF_CMD_TX_COUNT=2
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    # CONFIG_NORDIC_QSPI_NOR is not set
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    CONFIG_LOG_DEFAULT_LEVEL=4
    # CONFIG_NCS_IS_VARIANT_IMAGE is not set
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_SECURE_BOOT_CRYPTO is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_MAX_CONN=20
    CONFIG_BT_LL_SOFTDEVICE=y
    # SoftDevice Controller
    CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1536
    CONFIG_BT_RX_STACK_SIZE=4096
    # CONFIG_BT_CTLR_SDC_LLPM is not set
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=2
    CONFIG_BT_CTLR_SDC_RX_PRIO=6
    CONFIG_BT_CTLR_SDC_RX_STACK_SIZE=1024
    # CONFIG_BT_CTLR_DF is not set
    CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y
    CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
    # CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
    CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
    # CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK is not set
    # end of SoftDevice Controller
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_SCAN is not set
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_FAST_PAIR is not set
    # CONFIG_BT_DIS is not set
    CONFIG_BT_L2CAP_TX_MTU=247
    CONFIG_BT_BUF_ACL_TX_SIZE=251
    CONFIG_BT_BUF_ACL_RX_SIZE=251
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    # end of Bluetooth Services
    # BLE over nRF RPC
    # CONFIG_BT_RPC is not set
    # CONFIG_BT_RPC_STACK is not set
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_OBSERVER=y
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    CONFIG_BT_EXT_ADV=y
    # CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set
    CONFIG_BT_EXT_ADV_MAX_ADV_SET=4
    # CONFIG_BT_PER_ADV is not set
    # CONFIG_BT_PER_ADV_SYNC is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    CONFIG_BT_BUF_ACL_RX_COUNT=6
    CONFIG_BT_BUF_EVT_RX_SIZE=255
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_HAS_HCI_VS=y
    CONFIG_BT_HCI_VS=y
    # CONFIG_BT_HCI_MESH_EXT is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_RPA=y
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_LOG is not set
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    CONFIG_BT_HCI_HOST=y
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_ECC_STACK_SIZE=1140
    CONFIG_BT_HCI_TX_PRIO=7
    CONFIG_BT_HCI_RESERVE=0
    # CONFIG_BT_RECV_BLOCKING is not set
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_MESH is not set
    # CONFIG_BT_AUDIO is not set
    CONFIG_BT_SETTINGS=y
    CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
    CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE=y
    CONFIG_BT_SETTINGS_USE_PRINTK=y
    # CONFIG_BT_WHITELIST is not set
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_MAX=3
    CONFIG_BT_USER_PHY_UPDATE=y
    # CONFIG_BT_AUTO_PHY_UPDATE is not set
    CONFIG_BT_USER_DATA_LEN_UPDATE=y
    # CONFIG_BT_AUTO_DATA_LEN_UPDATE is not set
    CONFIG_BT_REMOTE_INFO=y
    CONFIG_BT_SMP=y
    # CONFIG_BT_PRIVACY is not set
    # CONFIG_BT_SIGNING is not set
    # CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set
    # CONFIG_BT_SMP_SC_PAIR_ONLY is not set
    # CONFIG_BT_SMP_SC_ONLY is not set
    # CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set
    # CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set
    # CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set
    CONFIG_BT_FIXED_PASSKEY=y
    # CONFIG_BT_USE_DEBUG_KEYS is not set
    CONFIG_BT_BONDABLE=y
    # CONFIG_BT_BONDING_REQUIRED is not set
    # CONFIG_BT_STORE_DEBUG_KEYS is not set
    CONFIG_BT_SMP_ENFORCE_MITM=y
    # CONFIG_BT_KEYS_OVERWRITE_OLDEST is not set
    CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=7
    CONFIG_BT_L2CAP_TX_BUF_COUNT=3
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    # CONFIG_BT_L2CAP_DYNAMIC_CHANNEL is not set
    CONFIG_BT_ATT_ENFORCE_FLOW=y
    CONFIG_BT_ATT_PREPARE_COUNT=0
    CONFIG_BT_GATT_AUTO_SEC_REQ=y
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    CONFIG_BT_GATT_DYNAMIC_DB=y
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    # CONFIG_BT_GATT_CLIENT is not set
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
    CONFIG_BT_DEVICE_NAME_GATT_WRITABLE=y
    CONFIG_DEVICE_NAME_GATT_WRITABLE_ENCRYPT=y
    # CONFIG_DEVICE_NAME_GATT_WRITABLE_AUTHEN is not set
    CONFIG_BT_MAX_PAIRED=1
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
    CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
    CONFIG_BT_EXT_SCAN_BUF_SIZE=229
    # CONFIG_BT_SCAN_WITH_IDENTITY is not set
    CONFIG_BT_DEVICE_NAME_DYNAMIC=y
    CONFIG_BT_DEVICE_NAME_MAX=28
    CONFIG_BT_DEVICE_NAME="Zephyr"
    CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC=y
    # CONFIG_BT_DEVICE_APPEARANCE_GATT_WRITABLE is not set
    CONFIG_BT_DEVICE_APPEARANCE=0
    CONFIG_BT_ID_MAX=1
    # CONFIG_BT_DF is not set
    CONFIG_BT_ECC=y
    # CONFIG_BT_TINYCRYPT_ECC is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_BREDR is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    CONFIG_ESB=y
    CONFIG_ESB_MAX_PAYLOAD_LENGTH=252
    CONFIG_ESB_TX_FIFO_SIZE=1
    CONFIG_ESB_RX_FIFO_SIZE=1
    CONFIG_ESB_PIPE_COUNT=8
    CONFIG_ESB_RADIO_IRQ_PRIORITY=1
    CONFIG_ESB_EVENT_IRQ_PRIORITY=2
    # Hardware selection (alter with care)
    # CONFIG_ESB_SYS_TIMER0 is not set
    # CONFIG_ESB_SYS_TIMER1 is not set
    CONFIG_ESB_SYS_TIMER2=y
    # CONFIG_ESB_SYS_TIMER3 is not set
    # CONFIG_ESB_SYS_TIMER4 is not set
    # end of Hardware selection (alter with care)
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # SPM
    # CONFIG_SPM is not set
    # CONFIG_IS_SPM is not set
    # end of SPM
    # CONFIG_FW_INFO is not set
    # CONFIG_PPI_TRACE is not set
    # CONFIG_CPU_LOAD is not set
    # CONFIG_SHELL_BT_NUS is not set
    # Nordic MPSL
    # CONFIG_MPSL_CX is not set
    # CONFIG_MPSL_CX_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_CX_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_CX_LOG_LEVEL_WRN is not set
    CONFIG_MPSL_CX_LOG_LEVEL_INF=y
    # CONFIG_MPSL_CX_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_CX_LOG_LEVEL=3
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_INF=y
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=6
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=5
    CONFIG_MPSL_ASSERT_HANDLER=y
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    CONFIG_MPSL_LOG_LEVEL_DBG=y
    CONFIG_MPSL_LOG_LEVEL=4
    # end of Nordic MPSL
    # CONFIG_CHIP is not set
    # Partition Manager
    # CONFIG_PARTITION_MANAGER_ENABLED is not set
    # CONFIG_FLASH_MAP_CUSTOM is not set
    CONFIG_SRAM_SIZE=256
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x40000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # Libraries
    # Binary libraries
    # end of Binary libraries
    # CONFIG_ADP536X is not set
    # CONFIG_AT_MONITOR is not set
    # CONFIG_DISABLE_FLASH_PATCH is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    # CONFIG_FPROTECT is not set
    CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
    CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_MODEM_INFO is not set
    CONFIG_MULTITHREADING_LOCK=y
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    # CONFIG_HW_UNIQUE_KEY_LOAD is not set
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
    # CONFIG_MODEM_JWT is not set
    # CONFIG_QOS is not set
    # CONFIG_QOS_LOG_LEVEL_OFF is not set
    # CONFIG_QOS_LOG_LEVEL_ERR is not set
    # CONFIG_QOS_LOG_LEVEL_WRN is not set
    CONFIG_QOS_LOG_LEVEL_INF=y
    # CONFIG_QOS_LOG_LEVEL_DBG is not set
    CONFIG_QOS_LOG_LEVEL=3
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_ENTROPY_CC3XX=y
    CONFIG_HW_CC3XX=y
    # CONFIG_ETH_RTT is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_FLASH=y
    # CONFIG_FLASH_NOP_DEVICE is not set
    CONFIG_CLOCK_CONTROL_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=1
    # end of Device Drivers
    # External libraries
    # CONFIG_SBC is not set
    # end of External libraries
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/home/doug/ncs/v2.0.0/nrf)
    # mcuboot (/home/doug/ncs/v2.0.0/bootloader/mcuboot)
    # MCUboot
    CONFIG_BOOT_SIGNATURE_KEY_FILE=""
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (/home/doug/ncs/v2.0.0/bootloader/mcuboot)
    # mbedtls (/home/doug/ncs/v2.0.0/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_MBEDTLS_BUILTIN=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    # end of mbedtls (/home/doug/ncs/v2.0.0/modules/crypto/mbedtls)
    # trusted-firmware-m (/home/doug/ncs/v2.0.0/modules/tee/tf-m/trusted-firmware-m)
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (/home/doug/ncs/v2.0.0/modules/tee/tf-m/trusted-firmware-m)
    # cjson (/home/doug/ncs/v2.0.0/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (/home/doug/ncs/v2.0.0/modules/lib/cjson)
    # zcbor (/home/doug/ncs/v2.0.0/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (/home/doug/ncs/v2.0.0/modules/lib/zcbor)
    # memfault-firmware-sdk (/home/doug/ncs/v2.0.0/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (/home/doug/ncs/v2.0.0/modules/lib/memfault-firmware-sdk)
    # canopennode (/home/doug/ncs/v2.0.0/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (/home/doug/ncs/v2.0.0/modules/lib/canopennode)
    # chre (/home/doug/ncs/v2.0.0/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (/home/doug/ncs/v2.0.0/modules/lib/chre)
    # hal_nordic (/home/doug/ncs/v2.0.0/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_RADIO_DRIVER is not set
    # CONFIG_NRF_802154_SER_RADIO is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # CONFIG_NRFX_CLOCK is not set
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # CONFIG_NRFX_I2S is not set
    # CONFIG_NRFX_NFCT is not set
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_PDM is not set
    CONFIG_NRFX_POWER=y
    CONFIG_NRFX_PPI=y
    CONFIG_NRFX_PWM=y
    CONFIG_NRFX_PWM0=y
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC is not set
    # CONFIG_NRFX_QSPI is not set
    # CONFIG_NRFX_RNG is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_RTC2 is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPI1 is not set
    # CONFIG_NRFX_SPIM0 is not set
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TEMP is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TIMER3 is not set
    # CONFIG_NRFX_TIMER4 is not set
    # CONFIG_NRFX_TWI0 is not set
    # CONFIG_NRFX_TWIM1 is not set
    # CONFIG_NRFX_UART0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    CONFIG_NRFX_USBD=y
    # CONFIG_NRFX_WDT0 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of nrfx drivers
    # end of hal_nordic (/home/doug/ncs/v2.0.0/modules/hal/nordic)
    # liblc3codec (/home/doug/ncs/v2.0.0/modules/lib/liblc3codec)
    CONFIG_ZEPHYR_LIBLC3CODEC_MODULE=y
    # end of liblc3codec (/home/doug/ncs/v2.0.0/modules/lib/liblc3codec)
    # littlefs (/home/doug/ncs/v2.0.0/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (/home/doug/ncs/v2.0.0/modules/fs/littlefs)
    # loramac-node (/home/doug/ncs/v2.0.0/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (/home/doug/ncs/v2.0.0/modules/lib/loramac-node)
    # lvgl (/home/doug/ncs/v2.0.0/modules/lib/gui/lvgl)
    CONFIG_LV_Z_POINTER_KSCAN_MSGQ_COUNT=10
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (/home/doug/ncs/v2.0.0/modules/lib/gui/lvgl)
    # lz4 (/home/doug/ncs/v2.0.0/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (/home/doug/ncs/v2.0.0/modules/lib/lz4)
    # nanopb (/home/doug/ncs/v2.0.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (/home/doug/ncs/v2.0.0/modules/lib/nanopb)
    # TraceRecorder (/home/doug/ncs/v2.0.0/modules/debug/TraceRecorder)
    CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
    # end of TraceRecorder (/home/doug/ncs/v2.0.0/modules/debug/TraceRecorder)
    # zscilib (/home/doug/ncs/v2.0.0/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (/home/doug/ncs/v2.0.0/modules/lib/zscilib)
    # nrfxlib (/home/doug/ncs/v2.0.0/nrfxlib)
    # Nordic nrfxlib
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    CONFIG_MPSL=y
    CONFIG_MPSL_BUILD_TYPE_LIB=y
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_CRYPTOCELL_CC310_USABLE=y
    CONFIG_CRYPTOCELL_USABLE=y
    CONFIG_NRF_OBERON=y
    # CONFIG_NRF_CC310_BL is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    # CONFIG_HW_CC3XX_INTERRUPT is not set
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # nrf_security module
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # end of nrf_security module
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (/home/doug/ncs/v2.0.0/nrfxlib)
    # connectedhomeip (/home/doug/ncs/v2.0.0/modules/lib/matter)
    # CONFIG_CHIP_NFC_COMMISSIONING is not set
    CONFIG_CHIP_DEBUG_SYMBOLS=y
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (/home/doug/ncs/v2.0.0/modules/lib/matter)
    # Optional modules. Make sure they're installed, via the project manifest.
    # CONFIG_CIVETWEB is not set
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_DSP is not set
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_SOF is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCBOR is not set
    # CONFIG_TINYCRYPT_CTR_PRNG is not set
    # CONFIG_TINYCRYPT_SHA256 is not set
    # CONFIG_TINYCRYPT_ECC_DH is not set
    # CONFIG_TINYCRYPT_ECC_DSA is not set
    CONFIG_TINYCRYPT_AES=y
    # CONFIG_TINYCRYPT_AES_CBC is not set
    # CONFIG_TINYCRYPT_AES_CTR is not set
    # CONFIG_TINYCRYPT_AES_CCM is not set
    CONFIG_TINYCRYPT_AES_CMAC=y
    # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # FFF module not available.
    # end of Modules
    CONFIG_BOARD_REVISION=""
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_ADAFRUIT_FEATHER_NRF52840=y
    # Board Options
    # CONFIG_BOARD_ENABLE_DCDC is not set
    # end of Board Options
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC1701X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    CONFIG_SOC_SERIES_NRF52X=y
    # CONFIG_SOC_SERIES_NRF53X is not set
    # CONFIG_SOC_SERIES_NRF91X is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_ACL=y
    CONFIG_HAS_HW_NRF_CC310=y
    CONFIG_HAS_HW_NRF_CCM=y
    CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_ECB=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PPI=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_QSPI=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
    CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
    CONFIG_HAS_HW_NRF_RNG=y
    CONFIG_HAS_HW_NRF_RTC0=y
    CONFIG_HAS_HW_NRF_RTC1=y
    CONFIG_HAS_HW_NRF_RTC2=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPI1=y
    CONFIG_HAS_HW_NRF_SWI0=y
    CONFIG_HAS_HW_NRF_SWI1=y
    CONFIG_HAS_HW_NRF_SWI2=y
    CONFIG_HAS_HW_NRF_SWI3=y
    CONFIG_HAS_HW_NRF_SWI4=y
    CONFIG_HAS_HW_NRF_SWI5=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_TIMER0=y
    CONFIG_HAS_HW_NRF_TIMER1=y
    CONFIG_HAS_HW_NRF_TIMER2=y
    CONFIG_HAS_HW_NRF_TIMER3=y
    CONFIG_HAS_HW_NRF_TIMER4=y
    CONFIG_HAS_HW_NRF_TWI0=y
    CONFIG_HAS_HW_NRF_UART0=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_NRF_HW_RTC1_RESERVED=y
    CONFIG_SOC_NRF52840=y
    # CONFIG_SOC_NRF52805_CAAA is not set
    # CONFIG_SOC_NRF52810_QFAA is not set
    # CONFIG_SOC_NRF52811_QFAA is not set
    # CONFIG_SOC_NRF52820_QDAA is not set
    # CONFIG_SOC_NRF52832_CIAA is not set
    # CONFIG_SOC_NRF52832_QFAA is not set
    # CONFIG_SOC_NRF52832_QFAB is not set
    # CONFIG_SOC_NRF52833_QIAA is not set
    CONFIG_SOC_NRF52840_QIAA=y
    CONFIG_GPIO_AS_PINRESET=y
    CONFIG_NRF_ENABLE_ICACHE=y
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    CONFIG_NFCT_PINS_AS_GPIOS=y
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    CONFIG_SOC_LOG_LEVEL_INF=y
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF52X=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_CPU_CORTEX_M=y
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_FAULT_DUMP=2
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M4=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_GEN_ISR_TABLES=y
    CONFIG_ZERO_LATENCY_IRQS=y
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    CONFIG_MPU_STACK_GUARD=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    CONFIG_ARCH_LOG_LEVEL_INF=y
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL=3
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    CONFIG_MPU_LOG_LEVEL_INF=y
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=0
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # CONFIG_CACHE_MANAGEMENT is not set
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    CONFIG_KERNEL_LOG_LEVEL_INF=y
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    # CONFIG_BOOT_BANNER is not set
    CONFIG_BOOT_DELAY=0
    CONFIG_THREAD_MONITOR=y
    CONFIG_THREAD_NAME=y
    CONFIG_THREAD_MAX_NAME_LEN=32
    CONFIG_INSTRUMENT_THREAD_SWITCHING=y
    CONFIG_THREAD_RUNTIME_STATS=y
    # CONFIG_THREAD_RUNTIME_STATS_USE_TIMING_FUNCTIONS is not set
    CONFIG_SCHED_THREAD_USAGE=y
    # CONFIG_SCHED_THREAD_USAGE_ANALYSIS is not set
    CONFIG_SCHED_THREAD_USAGE_ALL=y
    CONFIG_SCHED_THREAD_USAGE_AUTO_ENABLE=y
    # end of Kernel Debugging and Metrics
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    CONFIG_POLL=y
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # CONFIG_STACK_CANARIES is not set
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # SMP Options
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # CONFIG_THREAD_LOCAL_STORAGE is not set
    # end of General Kernel Options
    # Device Options
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    CONFIG_HAS_DTS=y
    CONFIG_HAS_DTS_GPIO=y
    # Device Drivers
    # CONFIG_IEEE802154 is not set
    # CONFIG_LORA is not set
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_SEMIHOST_CONSOLE is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_GSM_MUX is not set
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # CONFIG_EC_HOST_CMD_PERIPH is not set
    # CONFIG_MDIO is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    CONFIG_UART_LOG_LEVEL_INF=y
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL=3
    CONFIG_UART_USE_RUNTIME_CONFIGURE=y
    CONFIG_UART_ASYNC_API=y
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # Serial Drivers
    # CONFIG_UART_ITE_IT8XXX2 is not set
    CONFIG_UART_NRFX=y
    CONFIG_UART_0_NRF_UART=y
    CONFIG_UART_0_INTERRUPT_DRIVEN=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_NRF_UART_PERIPHERAL=y
    # CONFIG_UART_ALTERA_JTAG is not set
    # CONFIG_UART_XLNX_UARTLITE is not set
    # Interrupt Controllers
    # CONFIG_SWERV_PIC is not set
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    CONFIG_INTC_LOG_LEVEL_INF=y
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL=3
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    # CONFIG_INTC_ESP32 is not set
    # end of Interrupt Controllers
    # Timer Drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    # CONFIG_CAVS_TIMER is not set
    # CONFIG_HPET_TIMER is not set
    CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    CONFIG_RISCV_MACHINE_TIMER_SYSTEM_CLOCK_DIVIDER=0
    # end of Timer Drivers
    # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
    # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
    CONFIG_ENTROPY_LOG_LEVEL_INF=y
    # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
    CONFIG_ENTROPY_LOG_LEVEL=3
    CONFIG_ENTROPY_INIT_PRIORITY=50
    CONFIG_ENTROPY_NRF5_RNG=y
    # CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
    CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
    CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
    CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
    CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
    # CONFIG_ENTROPY_BT_HCI is not set
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    CONFIG_GPIO_LOG_LEVEL_INF=y
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_SHELL is not set
    # CONFIG_GPIO_DW is not set
    CONFIG_GPIO_NRFX=y
    # CONFIG_GPIO_ITE_IT8XXX2 is not set
    # CONFIG_GPIO_INTEL is not set
    # CONFIG_GPIO_RPI_PICO is not set
    # CONFIG_GPIO_XLNX_AXI is not set
    # CONFIG_GPIO_EMUL is not set
    # CONFIG_GPIO_SNPS_CREG is not set
    # CONFIG_FXL6408_LOG_LEVEL_OFF is not set
    # CONFIG_FXL6408_LOG_LEVEL_ERR is not set
    # CONFIG_FXL6408_LOG_LEVEL_WRN is not set
    CONFIG_FXL6408_LOG_LEVEL_INF=y
    # CONFIG_FXL6408_LOG_LEVEL_DBG is not set
    CONFIG_FXL6408_LOG_LEVEL=3
    # CONFIG_SHARED_IRQ is not set
    # CONFIG_I2S is not set
    # CONFIG_DAI is not set
    CONFIG_PWM=y
    # CONFIG_PWM_LOG_LEVEL_OFF is not set
    # CONFIG_PWM_LOG_LEVEL_ERR is not set
    # CONFIG_PWM_LOG_LEVEL_WRN is not set
    CONFIG_PWM_LOG_LEVEL_INF=y
    # CONFIG_PWM_LOG_LEVEL_DBG is not set
    CONFIG_PWM_LOG_LEVEL=3
    CONFIG_PWM_SHELL=y
    # CONFIG_PWM_CAPTURE is not set
    # CONFIG_PWM_NRF5_SW is not set
    CONFIG_PWM_NRFX=y
    # CONFIG_PWM_LED_ESP32 is not set
    # CONFIG_PWM_XLNX_AXI_TIMER is not set
    # CONFIG_PINMUX is not set
    # CONFIG_ADC is not set
    # CONFIG_DAC is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
    CONFIG_CLOCK_CONTROL_NRF=y
    CONFIG_CLOCK_CONTROL_NRF_SHELL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_IPM is not set
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    CONFIG_FLASH_LOG_LEVEL_INF=y
    # CONFIG_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_FLASH_LOG_LEVEL=3
    CONFIG_FLASH_SHELL=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_SOC_FLASH_NRF=y
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE is not set
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    # CONFIG_FLASH_SIMULATOR is not set
    # CONFIG_COUNTER is not set
    # CONFIG_DMA is not set
    CONFIG_USB_DEVICE_DRIVER=y
    # CONFIG_USB_DC_HAS_HS_SUPPORT is not set
    CONFIG_USB_DEVICE_REMOTE_WAKEUP=y
    # CONFIG_USB_DW is not set
    CONFIG_USB_NRFX=y
    CONFIG_USB_NRFX_EVT_QUEUE_SIZE=32
    CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE=1024
    CONFIG_USB_NRFX_ATTACHED_EVENT_DELAY=0
    # CONFIG_USB_NATIVE_POSIX is not set
    # CONFIG_USB_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_USB_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_USB_DRIVER_LOG_LEVEL_WRN is not set
    CONFIG_USB_DRIVER_LOG_LEVEL_INF=y
    # CONFIG_USB_DRIVER_LOG_LEVEL_DBG is not set
    CONFIG_USB_DRIVER_LOG_LEVEL=3
    # CONFIG_CRYPTO is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LED is not set
    # CONFIG_CAN is not set
    # CONFIG_AUDIO is not set
    # CONFIG_NEURAL_NET_ACCEL is not set
    CONFIG_HWINFO=y
    # CONFIG_HWINFO_LOG_LEVEL_OFF is not set
    # CONFIG_HWINFO_LOG_LEVEL_ERR is not set
    # CONFIG_HWINFO_LOG_LEVEL_WRN is not set
    CONFIG_HWINFO_LOG_LEVEL_INF=y
    # CONFIG_HWINFO_LOG_LEVEL_DBG is not set
    CONFIG_HWINFO_LOG_LEVEL=3
    CONFIG_HWINFO_SHELL=y
    CONFIG_HWINFO_NRF=y
    # CONFIG_ESPI is not set
    # CONFIG_PS2 is not set
    # CONFIG_VIDEO is not set
    # CONFIG_EEPROM is not set
    # CONFIG_PECI is not set
    # CONFIG_PECI_INTERRUPT_DRIVEN is not set
    # CONFIG_REGULATOR is not set
    # CONFIG_MEMC is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_EDAC is not set
    # CONFIG_PM_CPU_OPS is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB_LOG_LEVEL_OFF is not set
    # CONFIG_GROVE_LCD_RGB_LOG_LEVEL_ERR is not set
    # CONFIG_GROVE_LCD_RGB_LOG_LEVEL_WRN is not set
    CONFIG_GROVE_LCD_RGB_LOG_LEVEL_INF=y
    # CONFIG_GROVE_LCD_RGB_LOG_LEVEL_DBG is not set
    CONFIG_GROVE_LCD_RGB_LOG_LEVEL=3
    # CONFIG_GROVE_LCD_RGB is not set
    # end of Miscellaneous Drivers
    CONFIG_DISK_DRIVERS=y
    CONFIG_DISK_DRIVER_RAM=y
    CONFIG_DISK_RAM_VOLUME_SIZE=2
    CONFIG_DISK_RAM_VOLUME_NAME="RAM"
    # CONFIG_RAMDISK_LOG_LEVEL_OFF is not set
    # CONFIG_RAMDISK_LOG_LEVEL_ERR is not set
    # CONFIG_RAMDISK_LOG_LEVEL_WRN is not set
    CONFIG_RAMDISK_LOG_LEVEL_INF=y
    # CONFIG_RAMDISK_LOG_LEVEL_DBG is not set
    CONFIG_RAMDISK_LOG_LEVEL=3
    # CONFIG_DISK_DRIVER_FLASH is not set
    # CONFIG_CACHE is not set
    # CONFIG_SYSCON is not set
    # CONFIG_BBRAM is not set
    # CONFIG_FPGA is not set
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    CONFIG_PINCTRL_STM32_REMAP_INIT_PRIORITY=2
    # CONFIG_MBOX is not set
    # CONFIG_MM_DRV is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    CONFIG_USBC_LOG_LEVEL_INF=y
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_RESET is not set
    # C Library
    CONFIG_SUPPORT_MINIMAL_LIBC=y
    # CONFIG_MINIMAL_LIBC is not set
    CONFIG_NEWLIB_LIBC=y
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_NEWLIB_LIBC_NANO=y
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
    # CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
    # CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
    CONFIG_STDOUT_CONSOLE=y
    # end of C Library
    # Additional libraries
    # OS Support Library
    # CONFIG_JSON_LIBRARY is not set
    CONFIG_RING_BUFFER=y
    # CONFIG_BASE64 is not set
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_REBOOT=y
    # CONFIG_UTF8 is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    CONFIG_CBPRINTF_FP_SUPPORT=y
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    CONFIG_SYS_HEAP_SMALL_ONLY=y
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    # CONFIG_SYS_HEAP_AUTO is not set
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_GETOPT is not set
    CONFIG_POSIX_MAX_FDS=4
    # CONFIG_POSIX_API is not set
    # CONFIG_PTHREAD_IPC is not set
    # CONFIG_POSIX_CLOCK is not set
    CONFIG_MAX_TIMER_COUNT=5
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_POSIX_FS is not set
    # CONFIG_EVENTFD is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # Util libraries
    CONFIG_FNMATCH=y
    # end of Util libraries
    # CONFIG_SMF is not set
    # end of Additional libraries
    # Sub Systems and OS Services
    CONFIG_BT=y
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    CONFIG_BT_LOG_LEVEL_INF=y
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL=3
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_ISO_UNICAST is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # end of Bluetooth Host
    CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
    CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
    CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
    CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
    CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
    CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
    CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
    CONFIG_BT_CTLR_ECDH_SUPPORT=y
    # CONFIG_BT_LL_SW_SPLIT is not set
    # BLE Controller configuration
    CONFIG_BT_CTLR_CRYPTO=y
    CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
    CONFIG_BT_CTLR_AD_DATA_BACKUP=y
    # CONFIG_BT_CTLR_HCI_ADV_HANDLE_MAPPING is not set
    CONFIG_BT_CTLR_DUP_FILTER_LEN=16
    CONFIG_BT_CTLR_DUP_FILTER_ADV_SET_MAX=1
    CONFIG_BT_CTLR_RX_BUFFERS=1
    # CONFIG_BT_CTLR_TX_PWR_PLUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
    CONFIG_BT_CTLR_TX_PWR_0=y
    # CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
    CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
    # BLE Controller features
    CONFIG_BT_CTLR_LE_ENC=y
    CONFIG_BT_CTLR_ECDH=y
    CONFIG_BT_CTLR_EXT_REJ_IND=y
    CONFIG_BT_CTLR_LE_PING=y
    CONFIG_BT_CTLR_DATA_LENGTH=y
    CONFIG_BT_CTLR_PHY=y
    CONFIG_BT_CTLR_CONN_RSSI=y
    CONFIG_BT_CTLR_CHECK_SAME_PEER_CONN=y
    CONFIG_BT_CTLR_FILTER_ACCEPT_LIST=y
    CONFIG_BT_CTLR_PRIVACY=y
    CONFIG_BT_CTLR_FAL_SIZE=8
    CONFIG_BT_CTLR_RL_SIZE=8
    CONFIG_BT_CTLR_EXT_SCAN_FP=y
    CONFIG_BT_CTLR_PHY_2M=y
    CONFIG_BT_CTLR_PHY_CODED=y
    CONFIG_BT_CTLR_CHAN_SEL_2=y
    CONFIG_BT_CTLR_ADV_EXT=y
    CONFIG_BT_CTLR_ADV_SET=4
    CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=31
    CONFIG_BT_CTLR_ADV_EXT_RX_PDU_LEN_MAX=255
    CONFIG_BT_CTLR_SCAN_DATA_LEN_MAX=31
    # CONFIG_BT_CTLR_ADV_PERIODIC is not set
    # CONFIG_BT_CTLR_SYNC_PERIODIC is not set
    # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
    # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
    # CONFIG_BT_CTLR_ASSERT_HANDLER is not set
    # CONFIG_BT_CTLR_TEST is not set
    # CONFIG_BT_SHELL is not set
    CONFIG_BT_COMPANY_ID=0x05F1
    # Controller Area Network (CAN) bus subsystem
    # CONFIG_ISOTP is not set
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    CONFIG_CPLUSPLUS=y
    # CONFIG_STD_CPP98 is not set
    # CONFIG_STD_CPP11 is not set
    # CONFIG_STD_CPP14 is not set
    # CONFIG_STD_CPP17 is not set
    # CONFIG_STD_CPP2A is not set
    CONFIG_STD_CPP20=y
    # CONFIG_STD_CPP2B is not set
    CONFIG_LIB_CPLUSPLUS=y
    # CONFIG_RTTI is not set
    CONFIG_CPP_STATIC_INIT_GNU=y
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    CONFIG_DEBUG=y
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    # CONFIG_EARLY_CONSOLE is not set
    CONFIG_ASSERT=y
    CONFIG_ASSERT_LEVEL=2
    CONFIG_SPIN_VALIDATE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    CONFIG_ASSERT_NO_COND_INFO=y
    CONFIG_ASSERT_NO_MSG_INFO=y
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    CONFIG_DEBUG_INFO=y
    CONFIG_EXCEPTION_STACK_TRACE=y
    CONFIG_DEBUG_THREAD_INFO=y
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    CONFIG_DISK_ACCESS=y
    # CONFIG_DISK_LOG_LEVEL_OFF is not set
    # CONFIG_DISK_LOG_LEVEL_ERR is not set
    # CONFIG_DISK_LOG_LEVEL_WRN is not set
    CONFIG_DISK_LOG_LEVEL_INF=y
    # CONFIG_DISK_LOG_LEVEL_DBG is not set
    CONFIG_DISK_LOG_LEVEL=3
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    CONFIG_FILE_SYSTEM=y
    # CONFIG_FS_LOG_LEVEL_OFF is not set
    # CONFIG_FS_LOG_LEVEL_ERR is not set
    # CONFIG_FS_LOG_LEVEL_WRN is not set
    CONFIG_FS_LOG_LEVEL_INF=y
    # CONFIG_FS_LOG_LEVEL_DBG is not set
    CONFIG_FS_LOG_LEVEL=3
    CONFIG_APP_LINK_WITH_FS=y
    CONFIG_FILE_SYSTEM_MAX_TYPES=2
    CONFIG_FILE_SYSTEM_MAX_FILE_NAME=-1
    CONFIG_FAT_FILESYSTEM_ELM=y
    # ELM FAT file system settings
    # CONFIG_FS_FATFS_READ_ONLY is not set
    CONFIG_FS_FATFS_MKFS=y
    CONFIG_FS_FATFS_MOUNT_MKFS=y
    CONFIG_FS_FATFS_MAX_ROOT_ENTRIES=512
    # CONFIG_FS_FATFS_EXFAT is not set
    CONFIG_FS_FATFS_NUM_FILES=4
    CONFIG_FS_FATFS_NUM_DIRS=4
    # CONFIG_FS_FATFS_LFN is not set
    CONFIG_FS_FATFS_CODEPAGE=437
    CONFIG_FS_FATFS_MAX_SS=512
    CONFIG_FS_FATFS_WINDOW_ALIGNMENT=1
    # end of ELM FAT file system settings
    # CONFIG_FILE_SYSTEM_LITTLEFS is not set
    # CONFIG_FCB is not set
    CONFIG_NVS=y
    # CONFIG_NVS_LOOKUP_CACHE is not set
    # CONFIG_NVS_LOG_LEVEL_OFF is not set
    # CONFIG_NVS_LOG_LEVEL_ERR is not set
    # CONFIG_NVS_LOG_LEVEL_WRN is not set
    CONFIG_NVS_LOG_LEVEL_INF=y
    # CONFIG_NVS_LOG_LEVEL_DBG is not set
    CONFIG_NVS_LOG_LEVEL=3
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    CONFIG_LOG=y
    # CONFIG_LOG_MODE_DEFERRED is not set
    CONFIG_LOG_MODE_IMMEDIATE=y
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG2_MODE_DEFERRED is not set
    # CONFIG_LOG2_MODE_IMMEDIATE is not set
    # CONFIG_LOG1 is not set
    CONFIG_LOG2=y
    CONFIG_LOG2_IMMEDIATE=y
    CONFIG_LOG_DEFAULT_MINIMAL=y
    # Logging levels filtering
    CONFIG_LOG_RUNTIME_FILTERING=y
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    # CONFIG_LOG_PRINTK is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    CONFIG_LOG_FUNC_NAME_PREFIX_ERR=y
    CONFIG_LOG_FUNC_NAME_PREFIX_WRN=y
    CONFIG_LOG_FUNC_NAME_PREFIX_INF=y
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_IMMEDIATE_CLEAN_OUTPUT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    # CONFIG_LOG_BACKEND_UART is not set
    CONFIG_LOG_BACKEND_SWO=y
    CONFIG_LOG_BACKEND_SWO_FREQ_HZ=0
    CONFIG_LOG_BACKEND_SWO_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_SWO_OUTPUT_DICTIONARY is not set
    CONFIG_LOG_BACKEND_SWO_OUTPUT_DEFAULT=0
    # CONFIG_LOG_BACKEND_FS is not set
    # end of Backends
    # Misc
    CONFIG_LOG_DOMAIN_ID=0
    CONFIG_LOG_CMDS=y
    CONFIG_LOG2_USE_VLA=y
    CONFIG_LOG2_ALWAYS_RUNTIME=y
    # CONFIG_LOG2_FMT_SECTION is not set
    # end of Misc
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_MCUMGR is not set
    # CONFIG_HAWKBIT is not set
    # CONFIG_UPDATEHUB is not set
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # Networking
    CONFIG_NET_BUF=y
    CONFIG_NET_BUF_USER_DATA_SIZE=0
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    CONFIG_NET_BUF_LOG_LEVEL_INF=y
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Portability
    # end of Portability
    # Power Management
    # CONFIG_PM_DEVICE is not set
    # end of Power Management
    CONFIG_SHELL=y
    # CONFIG_SHELL_LOG_LEVEL_OFF is not set
    # CONFIG_SHELL_LOG_LEVEL_ERR is not set
    # CONFIG_SHELL_LOG_LEVEL_WRN is not set
    CONFIG_SHELL_LOG_LEVEL_INF=y
    # CONFIG_SHELL_LOG_LEVEL_DBG is not set
    CONFIG_SHELL_LOG_LEVEL=3
    CONFIG_SHELL_BACKENDS=y
    CONFIG_SHELL_BACKEND_SERIAL=y
    CONFIG_SHELL_BACKEND_SERIAL_INIT_PRIORITY=0
    CONFIG_SHELL_PROMPT_UART="uart:~$ "
    CONFIG_SHELL_BACKEND_SERIAL_INTERRUPT_DRIVEN=y
    CONFIG_SHELL_BACKEND_SERIAL_TX_RING_BUFFER_SIZE=8
    CONFIG_SHELL_BACKEND_SERIAL_RX_RING_BUFFER_SIZE=64
    CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_TIMEOUT=100
    CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_SIZE=10
    CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DEFAULT=y
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DBG is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_INF is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_WRN is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_ERR is not set
    # CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_NONE is not set
    CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL=5
    # CONFIG_SHELL_BACKEND_DUMMY is not set
    # CONFIG_SHELL_MINIMAL is not set
    # CONFIG_SHELL_THREAD_PRIORITY_OVERRIDE is not set
    CONFIG_SHELL_STACK_SIZE=2048
    CONFIG_SHELL_BACKSPACE_MODE_DELETE=y
    CONFIG_SHELL_CMD_BUFF_SIZE=256
    CONFIG_SHELL_PRINTF_BUFF_SIZE=30
    CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH=80
    CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT=24
    CONFIG_SHELL_ARGC_MAX=12
    CONFIG_SHELL_TAB=y
    CONFIG_SHELL_TAB_AUTOCOMPLETION=y
    CONFIG_SHELL_WILDCARD=y
    CONFIG_SHELL_ECHO_STATUS=y
    # CONFIG_SHELL_START_OBSCURED is not set
    CONFIG_SHELL_VT100_COMMANDS=y
    CONFIG_SHELL_VT100_COLORS=y
    # CONFIG_SHELL_GETOPT is not set
    CONFIG_SHELL_METAKEYS=y
    CONFIG_SHELL_HELP=y
    CONFIG_SHELL_HELP_OPT_PARSE=y
    CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT=y
    CONFIG_SHELL_HISTORY=y
    CONFIG_SHELL_HISTORY_BUFFER=512
    CONFIG_SHELL_STATS=y
    CONFIG_SHELL_CMDS=y
    CONFIG_SHELL_CMDS_RESIZE=y
    # CONFIG_SHELL_CMDS_SELECT is not set
    CONFIG_SHELL_CMD_ROOT=""
    CONFIG_SHELL_LOG_BACKEND=y
    CONFIG_KERNEL_SHELL=y
    CONFIG_KERNEL_SHELL_REBOOT_DELAY=0
    CONFIG_DEVICE_SHELL=y
    CONFIG_DEVMEM_SHELL=y
    # CONFIG_STATS is not set
    CONFIG_USB_DEVICE_STACK=y
    # CONFIG_USB_DEVICE_LOG_LEVEL_OFF is not set
    # CONFIG_USB_DEVICE_LOG_LEVEL_ERR is not set
    # CONFIG_USB_DEVICE_LOG_LEVEL_WRN is not set
    CONFIG_USB_DEVICE_LOG_LEVEL_INF=y
    # CONFIG_USB_DEVICE_LOG_LEVEL_DBG is not set
    CONFIG_USB_DEVICE_LOG_LEVEL=3
    CONFIG_USB_PID_CDC_ACM_SAMPLE=0x0001
    CONFIG_USB_PID_CDC_ACM_COMPOSITE_SAMPLE=0x0002
    CONFIG_USB_PID_HID_CDC_SAMPLE=0x0003
    CONFIG_USB_PID_CONSOLE_SAMPLE=0x0004
    CONFIG_USB_PID_DFU_SAMPLE=0x0005
    CONFIG_USB_PID_HID_SAMPLE=0x0006
    CONFIG_USB_PID_HID_MOUSE_SAMPLE=0x0007
    CONFIG_USB_PID_MASS_SAMPLE=0x0008
    CONFIG_USB_PID_TESTUSB_SAMPLE=0x0009
    CONFIG_USB_PID_WEBUSB_SAMPLE=0x000A
    CONFIG_USB_PID_BLE_HCI_SAMPLE=0x000B
    CONFIG_USB_PID_BLE_HCI_H4_SAMPLE=0x000C
    CONFIG_USB_PID_WPANUSB_SAMPLE=0x000D
    CONFIG_USB_DEVICE_VID=0x2FE3
    CONFIG_USB_DEVICE_PID=0x0008
    CONFIG_USB_DEVICE_MANUFACTURER="ZEPHYR"
    CONFIG_USB_DEVICE_PRODUCT="Glow Bike"
    CONFIG_USB_DEVICE_SN="0123456789ABCDEF"
    # CONFIG_USB_COMPOSITE_DEVICE is not set
    CONFIG_USB_MAX_NUM_TRANSFERS=4
    CONFIG_USB_DEVICE_BLUETOOTH_BIG_BUF=y
    CONFIG_USB_REQUEST_BUFFER_SIZE=128
    CONFIG_USB_MAX_ALT_SETTING=8
    CONFIG_USB_NUMOF_EP_WRITE_RETRIES=3
    # CONFIG_USB_DEVICE_SOF is not set
    # CONFIG_USB_DEVICE_BOS is not set
    # CONFIG_USB_DEVICE_OS_DESC is not set
    CONFIG_USB_SELF_POWERED=y
    CONFIG_USB_MAX_POWER=50
    # CONFIG_USB_WORKQUEUE is not set
    # USB CDC ACM Class support
    # CONFIG_USB_CDC_ACM is not set
    # end of USB CDC ACM Class support
    CONFIG_USB_MASS_STORAGE=y
    CONFIG_MASS_STORAGE_DISK_NAME="RAM"
    CONFIG_MASS_STORAGE_INQ_VENDOR_ID="ZEPHYR  "
    CONFIG_MASS_STORAGE_INQ_PRODUCT_ID="ZEPHYR USB DISK "
    CONFIG_MASS_STORAGE_INQ_REVISION="0.01"
    CONFIG_MASS_STORAGE_BULK_EP_MPS=64
    CONFIG_MASS_STORAGE_STACK_SIZE=512
    # CONFIG_USB_MASS_STORAGE_LOG_LEVEL_OFF is not set
    # CONFIG_USB_MASS_STORAGE_LOG_LEVEL_ERR is not set
    # CONFIG_USB_MASS_STORAGE_LOG_LEVEL_WRN is not set
    CONFIG_USB_MASS_STORAGE_LOG_LEVEL_INF=y
    # CONFIG_USB_MASS_STORAGE_LOG_LEVEL_DBG is not set
    CONFIG_USB_MASS_STORAGE_LOG_LEVEL=3
    # CONFIG_USB_DEVICE_BLUETOOTH is not set
    # CONFIG_USB_DEVICE_BT_H4 is not set
    # CONFIG_USB_DEVICE_LOOPBACK is not set
    # USB Device Networking support
    # CONFIG_USB_DEVICE_NETWORK_ECM is not set
    # CONFIG_USB_DEVICE_NETWORK_EEM is not set
    # CONFIG_USB_DEVICE_NETWORK_RNDIS is not set
    # end of USB Device Networking support
    # CONFIG_USB_DEVICE_HID is not set
    # CONFIG_USB_DEVICE_AUDIO is not set
    # CONFIG_IMG_MANAGER is not set
    # Random Number Generators
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    # CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
    # CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
    CONFIG_CSPRING_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
    # end of Random Number Generators
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_MAP_SHELL is not set
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    CONFIG_SETTINGS=y
    # CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
    CONFIG_SETTINGS_LOG_LEVEL_INF=y
    # CONFIG_SETTINGS_LOG_LEVEL_DBG is not set
    CONFIG_SETTINGS_LOG_LEVEL=3
    # CONFIG_SETTINGS_RUNTIME is not set
    CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
    # CONFIG_SETTINGS_FS is not set
    CONFIG_SETTINGS_NVS=y
    # CONFIG_SETTINGS_CUSTOM is not set
    # CONFIG_SETTINGS_NONE is not set
    CONFIG_SETTINGS_NVS_SECTOR_SIZE_MULT=1
    CONFIG_SETTINGS_NVS_SECTOR_COUNT=8
    # CONFIG_SETTINGS_SHELL is not set
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    # CONFIG_TEST_USERSPACE is not set
    CONFIG_TEST_LOGGING_FLUSH_AFTER_TEST=y
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # end of Sub Systems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_14=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_USE_DT_CODE_PARTITION is not set
    CONFIG_FLASH_LOAD_OFFSET=0
    CONFIG_FLASH_LOAD_SIZE=0
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    # end of Linker Sections
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_NATIVE_APPLICATION is not set
    # CONFIG_SIZE_OPTIMIZATIONS is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    CONFIG_DEBUG_OPTIMIZATIONS=y
    # CONFIG_NO_OPTIMIZATIONS is not set
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    CONFIG_OUTPUT_DISASSEMBLY=y
    # CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    CONFIG_BUILD_OUTPUT_BIN=y
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    # end of Build Options
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_COMPAT_INCLUDES=y
    # end of Compatibility
    CONFIG_LEGACY_INCLUDE_PATH=y
    I am including my .config file.  Can you tell me if something is set wrong?  Not sure I understand how my code, which was built up from examples, could not work.
    Thank you.
    I see why you got the BT_HCI_ERR_CONN_LIMIT_EXCEEDED error now. In your config file, the CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT  setting is set to '1'. This means your controller can only 1 peripheral connection, but up to 19 central connections (https://github.com/nrfconnect/sdk-nrf/blob/6332cd46b96af3268750bc4b98b5aba287484853/subsys/bluetooth/controller/Kconfig#L94).
    You can define a higher value for CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT value in your prj.conf value, or disable CONFIG_BT_CENTRAL to make CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT track the CONFIG_BT_MAX_CONN setting.
