HardFault after GPIO PIN set to High on Custom Board
on my Custom Board I'am setting P0.12 to High triggered by a BLE notification (NUS). I'am here using the BLE Uart Example (S112, pca10040). The Custom Board's nrf52832 DCDC Pin is not connected
The Problem is, that on my Custom Board the System goes direct in the Hard Fault on the nrf52 DK not. Is there something in for P0.12 in use somewhere else?
P0.12 is bounded to an STM32 MCU's boot0 Pin with a external 10k pulldown.
if (p_evt->type == BLE_CTRL)
if (p_evt->params.rx_data.p_data[0]==0xFA)
{ // Bootloader Pattern1
m_ctrl=1;
nrf_gpio_pin_write(12, 1);
nrf_gpio_pin_write(11, 0);
for (uint16_t ts=0;ts<4000;ts++){}
nrf_gpio_pin_write(11, 1);
if (p_evt->params.rx_data.p_data[0]==0xFB)
{ // Reset
m_ctrl=0;
nrf_gpio_pin_write(12, 0);
    The UART peripheral will raise this event when an Error condition is detected on the RX pin, and from the  screenshot you posted we can see it detected a BREAK condition.
    the nrf ist waiting for 200ms before he starts with the second line in main() after the delay sommand.
    Does this mean the STM is powered on before the nRF has enabled the UART interface?
    Furthermore I don't see any edges with the oscilloscope on my RX PIN when I'am setting P0.12 1
    What exactly happens when you set configure P0.12? Will there be any UART communication between the nrf and stm if you don't configure it?
  • HI Vidar,
    Yes, this is correct, but this this doesn't come from the RX Line itself.
    Yes, the STM is ready before the uart_init functions runs.
    Nothing on the UART happens here. I'am setting with this pin a the Bootloader PIN from STM on High.
    Yes, but you indicated earlier that the error only happened when you configured this pin?
    It does come from the RX line, so we have to try to narrow down the problem somehow. With the scope traces, were you able to verify if both the nrf and stm are transmitting with the correct baudrate?
  • Nothing on the UART happens here. I'am setting with this pin a the Bootloader PIN from STM on High.
    Not at Configuration...At the time where I set the P0.12 Pin to "1"
    The Baudrate on both are ok. The uart communication works well in both directions. As I said, at the time where I set P0.12 to "1" the error occurs. At the time where I set P0.12 to "1" nothing happens on the RX/TX lines
  • Thanks for the clarification. So the APP_UART_COMMUNICATION_ERROR event is triggered when you set the P0.12 output. Have you measured how long time it takes from when P0.12 is asserted until the error event is raised?
