How to read a large file (About 240MB) from SD card
Hello all, I hope you are doing well.
I Have a project on NRF52840 in which I have multiple sensors connected to the NRF52 and the sensor data are storing in the SD card in the form of a CSV file of size 240 MB. I want to read this large file from the SD card and then send it to the mobile app using ble_periperhial. I have used This example and modified it, but the problem is that I can only read 220000 bytes from the SD card in the buffer at once and when I am trying to increase
   #define FILE_SIZE_MAX (Maximum size in bytes of the file to be read from SDCARDgreater than 220000, while the following;
                                            static uint8_t file_buffer[FILE_SIZE_MAX];
                                           ff_result = f_read(&file, file_buffer, FILE_SIZE_MAX, (UINT *) &bytes_read);
 Then it gives the following error:
                                      .bss is too large to fit in RAM1 memory segment
                                     .heap is too large to fit in RAM1 memory segment
                                      section .heap overlaps absolute placed section .stack
                                      section .stack VMA [000000002003e000,000000002003ffff] overlaps section .bss VMA [0000000020002c64,0000000020224b08]
I don't know about this error and how to solve it. Simply I want to read the whole file (234MB) from the SD card at once and then send it in chunks to the mobile app, Is this possible or do I have to read in chunks from the SD card too?
Any help regarding this will be highly appreciated.
  • Hey Torbjørn Sir, I hope you will be fine.
    ** UPDATE
    Sir, I have updated the project with the changes you have made, Now I have achieved a decent throughout of ~1063kbps with a very good phone which is capable of achieving a throughput of >1300kbps.
    Now I have some questions, but first, let me explain the different scenarios, and then I will come to my questions.
    First Scenario:
    I have another project which is doing the same task (Reading a file from an SD card and sending it to ble) but the logic is different and simple( Reading data from an SD card and send directly to Ble without the use of temporary storage or TX complete event), see the below code snippet.
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    static uint8_t file_found_on_sdcard = false;
    static uint32_t file_actual_read_size = 0;
    static uint8_t file_send_to_peripheral = false;
    uint32_t timestamp_test_start, timestamp_test_stop;
        // Enter main loop.
        for (;;)
            if(file_send_to_peripheral)
             timestamp_test_start = app_timer_cnt_get();
                if(size > 0)   // size of file
                uint32_t remaining_bytes = size;
                uint16_t chunk_length = BLE_NUS_MAX_DATA_LEN;
                ret_code_t err_code;
                while(remaining_bytes > 0)
                   ff_result = f_read(&file, file_buffer, sizeof(file_buffer), (UINT *) &bytes_read);
                    do
                     err_code= ble_nus_data_send(&m_nus, file_buffer, &chunk_length, m_conn_handle);
                          remaining_bytes -= chunk_length;
                           m_total_num_bytes += chunk_length;
                       if(remaining_bytes < chunk_length)
                          chunk_length = remaining_bytes;
                        //NRF_LOG_INFO("Remaining bytes to send: %d", remaining_bytes);
                     }while((err_code == NRF_ERROR_RESOURCES));
                timestamp_test_stop = app_timer_cnt_get();
                uint32_t diff = app_timer_cnt_diff_compute(timestamp_test_stop, timestamp_test_start);
                uint32_t kbps = (uint32_t)((float)(size * 8) / ((float)diff / 16384.0f) / 1024.0f);
                NRF_LOG_INFO("Test complete! Time passed: %i, ~%i kbps", diff, kbps);
            //idle_state_handle();
            while(NRF_LOG_PROCESS());
    The throughput achieved by this project is the following.
    The Sniffer trace is the following:
    MyProject_Sniffer_trace.pcapng
    Questions Related to this Scenario:
    1) If you see the throughput in the above-attached screenshot you will see that sometime the throughput goes to >1200kbps and even >1300kpbs, but the throughput is not stable means the throughput is varying and sometimes goes very low, and sometimes very high. I don't find the reason for this behavior, Can you please explain this?
    2) The throughput in this case is increasing when I increase the connection intervals and vice versa. I expect to have a high throughput on small connection intervals but it is just the opposite of my expectation. What do you think about this?
    2) Second Scenario:
    I have made some necessary changes to the project you have provided, see the below code snippet:
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    // Create a FIFO structure
    app_fifo_t dummy_fifo;
    uint32_t dummy_fifo_bytes_used;
    // Create a buffer for the FIFO
    #define DUMMY_FIFO_SIZE 512
    uint8_t dummy_buffer[DUMMY_FIFO_SIZE];
    static int dummy_buffer_write(uint8_t *data, uint32_t len)
        app_fifo_write(&dummy_fifo, data, &len);
        dummy_fifo_bytes_used += len;
        return len;
    static int dummy_buffer_bytes_free(void)
        return DUMMY_FIFO_SIZE - dummy_fifo_bytes_used;
    static int dummy_buffer_read(uint8_t *data, uint32_t len)
        app_fifo_read(&dummy_fifo, data, &len);
        dummy_fifo_bytes_used -= len;
        return len;
    static int dummy_buffer_bytes_used(void)
        return dummy_fifo_bytes_used;
    static void init_dummy_buffer(void)
        // Initialize FIFO structure
        uint32_t err_code = app_fifo_init(&dummy_fifo, dummy_buffer, DUMMY_FIFO_SIZE);
        dummy_fifo_bytes_used = 0;
    #define TEST_DUMP_SIZE  size                       // Size of the file in the SD card
    #define TEST_READ_SIZE  BLE_NUS_MAX_DATA_LEN       // BLE_NUS_MAX_DATA_LEN  =244
    #define TEST_WRITE_SIZE BLE_NUS_MAX_DATA_LEN       //m_ble_nus_max_data_len
    uint32_t dummy_test_remaining_bytes_read = 0;
    uint32_t dummy_test_remaining_bytes_write = 0;
    /**@brief Application main function.
        bool erase_bonds;
        uint32_t err_code;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
         fatfs_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        init_dummy_buffer();
        // Start execution.
        //printf("\r\NRF_ERROR_RESOURCES test started.\r\n");
        advertising_start();
         timers_start();
        static uint8_t tmp_read_buffer[TEST_READ_SIZE];
        static uint8_t tmp_write_buffer[BLE_NUS_MAX_DATA_LEN];
        uint16_t write_length;
        int bt_written;
        // Enter main loop.
        for (;;)
            // If the run_dummy_test flag is set, start a new data dump test
            if(run_dummy_test)
                run_dummy_test = false;
                bt_written = 0;
                dummy_test_remaining_bytes_read = TEST_DUMP_SIZE;
            // As long as there are bytes left to read, and there is room in the dummy buffer, read out a single packet
            if(dummy_test_remaining_bytes_read && dummy_buffer_bytes_free() >= TEST_READ_SIZE)
                // Set the read_length to the minimum of the remaining bytes to read and the test read size
                uint32_t read_length = (dummy_test_remaining_bytes_read > TEST_READ_SIZE) ? TEST_READ_SIZE : dummy_test_remaining_bytes_read;
                // Read SD card data into a temporary array
                ff_result = f_read(&file, tmp_read_buffer, sizeof(tmp_read_buffer), (UINT *) &bytes_read);
                // Move the SD card data from the temporary array into our FIFO buffer
                dummy_buffer_write(tmp_read_buffer, read_length);
                // Reduce the remaining number of bytes to read for the test
                dummy_test_remaining_bytes_read -= read_length;
                NRF_LOG_DEBUG("Dummy data produced %i, remaining %i", read_length, dummy_test_remaining_bytes_read);
            // As long as there is data in the dummy buffer, and the Bluetooth stack has free buffers, upload a packet to the Bluetooth stack
            // If retransmit_previous_buffer is set it means the packet stored in tmp_write_buffer still hasn't been successfully
            // sent (because of NRF_ERROR_RESOURCES). In this case we try to send it again, without reading new data from the FIFO
           if(ble_buffers_available && (dummy_buffer_bytes_used() >= TEST_WRITE_SIZE || retransmit_previous_buffer || \
                                        (dummy_buffer_bytes_used() > 0 && dummy_test_remaining_bytes_read == 0)))
                //bsp_board_led_off(0);
                // Read new data from the FIFO unless retransmit_previous_buffer is set, in which case we have to retransmit the last packet
                if(!retransmit_previous_buffer)
                    // Move a new packet from the FIFO to the temporary write buffer
                    write_length = dummy_buffer_read(tmp_write_buffer, TEST_WRITE_SIZE);
                    NRF_LOG_DEBUG(" Fifo to tmp %i bytes", write_length);
                // Forward a single packet to the Bluetooth stack
                // NOTE: This code assumes that write_length will not be changed by ble_nus_data_send(..) (this could happen if you try to send a packet
                //       longer than the negotiated MTU size). If this could happen then the code needs to be changed to ensure that the remaining data gets
                //       written afterwards.
                err_code = ble_nus_data_send(&m_nus, tmp_write_buffer, &write_length, m_conn_handle);
                if(err_code == NRF_SUCCESS)
                    // In case of success, update the bt_written parameter (please note the data will still take some time to reach the Bluetooth client)
                    bt_written += write_length;
                    m_total_num_bytes+= write_length;
                    //NRF_LOG_INFO("   Tmp to BT total: %i (+%i)", bt_written, write_length);
                else if(err_code == NRF_ERROR_RESOURCES)
                    // In case of NRF_ERROR_RESOURCES, clear the ble_buffers_available flag to avoid trying to send more data until the Bluetooth buffers
                    // clear up. This flag will be set by the BLE_GATTS_EVT_HVN_TX_COMPLETE event in the ble_evt_handler function in main.c
                    ble_buffers_available = false;
                    //bsp_board_led_on(0);
                    //NRF_LOG_INFO("     ERROR RESOURCES");
                else if(err_code != NRF_ERROR_INVALID_STATE && err_code != NRF_ERROR_NOT_FOUND)
                // The retransmit_previous_buffer should be cleared for any upload.
                // If NRF_ERROR_RESOURCES were to happen again it should be set again in the ble_evt_handler
                retransmit_previous_buffer = false;
                if(bt_written == size)
                    uint32_t kbps = (uint32_t)((float)(TEST_DUMP_SIZE * 8) / ((float)diff / 16384.0f) / 1024.0f);
                    // Any other code that should be added upon completion can be added here.
    The throughput achieved by this project is the following:
    Torbjørn_Provided_Project_Sniffer_trace.pcapng
    The throughput is very stable in this case as you can see in the attached screenshot.
    Questions:
    1)  Why the throughput doesn't go to ~1200kbps or 1300kbps in this case as goes in 1st scenario? I want the throughput to be ~1200kbps or greater, How can this be achieved?
    2) If you see the above sniffer trace, there are a lot of empty packets which I think limit the throughput to ~1000-1060kbps. How to reduce/eliminate these empty packets?
    3) The throughput, in this case, is Maximum at the connection interval(Min & Max =15) and when I try to increase the connection interval then the throughput decreases, and when decreases the connection interval then it leads to more empty packets which decreases the throughput. Can you please explain this behavior?
    Best Regards,
    Sami
  • Hi Sami
    This makes sense.
    Looking at your traces I see that your code ends up with a connection interval of 45ms, while my code gets an interval of 15ms.
    A long connection interval will give you a higher peak throughput, because the SoftDevice will not be able to send packets for the entirety of the connection event.
    There will be a gap at the end of the event equal to the full time it takes to send and receive a single full packet, pluss some time needed for data processing.
    With 251 byte data length and 2M PHY this gap seems to be around 2.4ms long, based on the traces you shared.
    The percentage of time you can send data is then given by the following formula: (CI - gap) / CI
    For a connection interval of 15ms this equals around 84%, or 1140kbps
    For a connection interval of 45ms we get around 95%, or 1285kbps
    Based on this you would think that using a longer connection interval is then better for throughput, but this is unfortunately not the case, since a single lost packet in a connection event cancels the entire event.
    If you are unlucky and drop a packet early in the event you lose all the time left over in the event, which is higher the larger your connection interval is.
    This is the reason why longer connection intervals gives you a lot more variation in the throughput, because you are a lot more susceptible to packet loss caused by interference or other factors.
    So to summarize, in ideal conditions a higher connection interval will give you higher throughput, but if you are affected by packet loss the throughput can drop significantly. Just like your traces show, where 15ms gives you a lower peak but much more stable performance.
    It seems like you have a significant amount of packet loss in your test setup. What is the distance between the nRF device and the phone in your testing?
    I guess I explained the reason for this in my previous comment. The peak throughput when using a 15ms connection interval is about 1140kbps.
    I will check with one of the SoftDevice experts if there is some tweaking that can be done to increase this a little, but I wouldn't bet on it.
    Anyway, how much difference will it be for the user if you can squeeze out a couple of extra percent more throughput?
    Myself I would be more concerned about phones that have significantly lower throughput than this, because they have their own more stringent restrictions on how often they can send data.
    Where do you see these empty packets?
    From the point the peripheral starts sending notifications, at packet number 1936, to the moment it stops, at packet number 21353, I don't see a lot of empty packets (the central keeps sending empty packets, but this is to be expected since the phone doesn't send anything to you).
    Samiulhaq said:
    3) The throughput, in this case, is Maximum at the connection interval(Min & Max =15) and when I try to increase or decrease the connection interval then the throughput decreases,  why?
    A connection interval of 15ms seems to be the sweet spot in your particular test environment. Any lower than this and the 2.4ms gap starts to make a bigger impact on the throughput, and any higher and the effect of dropped packets leading to long gaps of no activity starts making a bigger impact.
    As I mentioned earlier I have often considered 15ms to be a good compromise between reliability and peak throughput, so I am not surprised by your results. I am only a little surprised about the amount of packet loss you get, unless you are keeping the phone and nRF device far apart, or you have a significant amount of interference in the area (from Wi-Fi routers for instance).
    As a side note, if you find your simplified algorithm to work equally well as my example I see no reason not to go for that implementation instead.
    As long as you are fine to stay in that loop while sending data, and don't need to run any other operation from your main loop, then it should work fine.
    I think all the differences you have measured between my implementation and yours is just down to the connection interval used.
    Best regards
    Torbjørn
  • Hi Torbjørn, thank you so much for this amazing explanation.
    I understand the logic behind it because of your thorough and well explanation. However, I have some questions related to your explanation and some answers to your questions:
    How do you find this gap time(2.4ms) from the trace?
    As you said, for the conn. interval of 15ms the max throughput will be 1140kbps but I hardly reached 1090-1098kbps in this case. why has it not reached the 1140kbps?
    And in the 45ms case, the max throughput is 1285kbps, but sometimes it goes to 1350kbps. How it is going beyond the max throughput?
    Both (phone and nRF) are close to each other (on the same working table/desk).
    The file size is very large (about 234MB), that's why I want to maximize the throughput as much as possible(to the highest possible value) to reduce the time taken by the large file to send to the mobile App.
    If you observe both traces, the one(Torbjorn_Provided_Project_Sniffer_trace) has more empty packets sent by the central(mobile app) to the peripheral(nRF). I know that 1 empty packet sent by central is a part of the Bluetooth protocol but in the trace, there are 2 empty packets sent( not regularly but time by time) by central to the peripheral which is not/very limited in the other trace(My_project_Sniffer_trace). see the attached screenshot:
    In the trace(I have mentioned) there are a lot more of these patterns than in the other trace. What do you think is the reason for this behavior and why these patterns are less in the other trace? I think this is due to a small conn. interval(15ms), am I right?
    In which project these packets loss are? If it is in my project then I am not surprised because in my opinion I didn't add the logic of BLE_GATTS_EVT_HVN_TX_COMPLETE case and I didn't handle the NRF_ERROR_RESOURCES(please have a look to my logic in the previous reply). My logic is very simple and that may be the reason for the packet drop? I have turned off WI-FI on testing my phone and the phone and nRF are on the same table.
    Thank you so much and Best Regards,
    Sami
  • Hi Sami
    Whenever you see two empty packets from the master, where one has a short time delta and the other a longer one, this means that the first packet from the master was not answered by the slave (because of the gap imposed by the SoftDevice), and becomes the last packet of the current connection event.
    Since the connection event is over the master will then wait for the next connection event before sending a new packet, and the delay between the first empty packet and the second will then signify the 'dead time' at the end of the connection event.
    Some times this delay will be very large, because of packet loss, but I noticed that many times the dead time was around 2446us. I never noticed the dead time being smaller than this, and for this reason I am assuming that the SoftDevice gap is around this number.
    That is a good question. According to the sniffer trace there is a lot of packet loss over the air, which causes reduced throughput both when using your code and mine. Why you would have so much packet loss when keeping the devices close together I don't know.
    Are you using custom hardware on the nRF side or a standard DK?
    I would have to assume that the hardware design of the nRF device, the phone or both is not ideal.
    Also, if you are testing in an office environment you might want to test again at home, to see if the issues are caused by local interference.
    Either my math is wrong or the measurement is wrong Wink
    If the RC clock source is the external crystal then the measurement should be pretty accurate. I will think through the math one more time later on, to see if I have done some miscalculations.
    There is an old engineering saying; "Premature optimization is the root of all evil". This article summarizes the idea pretty well.
    If the file is so large it will take time to transfer no matter what. If people get tired waiting for 30 minutes, they will get tired waiting for 25 minutes as well.
    What about people using iPhones, which never go much beyond 6-700kbps? Or various Android phones that might be all over the place?
    Rather than spending a lot of time to reduce the transfer time by a couple of percent on the fastest phones you might be better of designing the app so that it explains to the user why they need to wait so long, and gives good progress reports along the way.
    Or have you looked into ways of compressing or optimizing the file, which would benefit all the users regardless of which phone they have?
    To summarize, unless your project is otherwise ready and this is the only remaining optimization you want to do before release, your time might be spent more efficiently elsewhere.
    Yes, this happens when the nRF stops responding because of the SoftDevice imposed gap. With a long connection interval this is much less likely to happen, because there is a much higher risk the connection event will be ended by a lost packet before reaching the end. Keep in mind that just a single dropped packet is enough to end the connection event.
    I know nothing about application data loss, by packet loss I mean RF packets lost over the air. By looking at the traces it seems that the reason you get so much variation in throughput is that you have a considerable amount of lost packets between the nRF and the phone.
    Why this is I don't know, I discussed this in more detail earlier in this reply.
    Best regards
    Torbjørn
  • Hello Sir, this is such a fantastic explanation. Thank you so much for your valuable time.
    Now from this explanation, I understand the number of packets per connection interval too for which I have read a lot of threads/blogs, thanks a lot.
    I don't know what you mean by losing packet but when I compare the data(UART Rx field of the Wireshark) of the last packet in the Wireshark with the last data in the actual file, both values are the same.
    for example, the last data in the file is the following:
    7525,32599,34603,4338,37739,13272,36651,21077,34948,36696,22470,17848,43432,3158,19187,37859,32649,20220111121250
    In the Wireshark/sniffer trace, the last packet has the same data as the actual file. From this, I am concluding that all the data has been sent/received correctly and there is no packet loss, is this the correct way of checking it?Slight smile
    I am using standard DK(nRF52840).
    This is a very good point but is it possible to compress the file using nRF DK? because I have to store the data of the different sensors(connected to the nRF52) in the SD card in the form of a CSV file and from there send that file(automatically) to the mobile app after every 60 hours.
    I have reduced the conn. interval to 20ms in my project and now I can achieve an average throughput of about 1200kbps while sending 22MB files and now the throughput is not varying too much as I have reduced the conn. interval and my throughput are now about 1200kbps and I am ok what that.
    One last question and sorry for taking your valuable time.
    How can I check whether the complete file has been received correctly or not? In my opinion, I have to do a small modification in the nRF Toolbox app and add the functionality of storing the data received via UART in a CSV file, and then compare it to the actual file, is this the efficient way?  Have you any other suggestions/alternatives about this?
    Once Again thank you so much for your valuable time, explanation, and suggestions. I have learned a lot from you, to be honest.
    Best Regards,
    Sami
