static inline int spi_write_dt(const struct spi_dt_spec *spec, const struct spi_buf_set *tx_bufs);
Kenneth I don't think so, when I probe the different channels signals are all clean. I also reduced the SPI clock frequency to see if it changes something but not really.
And yes, your understanding is right, the ISR is just putting a value in a message queue. Then, another thread is fed from this same queue and does computation before another updates periodically the view/display.
Removing the interrupt only get rid of the issue even having the trigger signal on.
AnomalySmith said:Then, another thread is fed from this same queue and does computation before another updates periodically the view/display.
Is it possible that this thread is doing any manipulation or update of the ongoing SPI buffer used by the:
gpio_pin_set_dt(&config->dc_gpio, 1);
errno = spi_write_dt(&config->bus, &tx_bufs_cmd);
gpio_pin_set_dt(&config->dc_gpio, 0);
Maybe try to double buffer the SPI data before spi_write_dt()?
Kenneth
Thanks for your reply again, only the first thread is updating data as the second reads them and is responsible from SPI transaction (calling LVGL's related functions). Also, mutexes are used in order to guaranty the integrity of data while accessing them.
The buffer size is handled by the call (by LVGL lib) to the writes related functions through the SSD1333 driver (default display declared in overlay dts file) :
static inline int ssd1333_write_bus(const struct device *dev, BYTE cmd, BYTE *buf, size_t data_len) {
// printk("[SSD1333] WRITE BUS\n");
const struct ssd1333_config *config = dev->config;
int errno;
BYTE cmd_buf[] = {cmd};
struct spi_buf tx_buf_cmd = {
.buf = cmd_buf,
.len = 1
struct spi_buf_set tx_bufs_cmd = {
.buffers = &tx_buf_cmd,
.count = 1
if(!buf || data_len < 1) {
return errno;
struct spi_buf tx_buf = {
.buf = buf,
.len = data_len
struct spi_buf_set tx_bufs = {
.buffers = &tx_buf,
.count = 1
errno = spi_write_dt(&config->bus, &tx_bufs);
return errno;
int ssd1333_write(const struct device *dev, const uint16_t x, const uint16_t y,
const struct display_buffer_descriptor *desc,
const void *buf) {
// printk("[SSD1333] WRITE\n");
size_t buf_len;
if(desc->pitch < desc->width) {
LOG_ERR("Pitch is smaller than width");
return -1;
buf_len = desc->buf_size; // / 8 ???
if(buf == NULL || buf_len == 0U) {
LOG_ERR("Display buffer is not available");
return -1;
if(desc->pitch > desc->width) {
LOG_ERR("Unsupported mode");
return -1;
// if((y & 0x7) != 0U) {
// LOG_ERR("Unsupported origin y %u", y);
// return -1;
/* Check we do not overflow x or y from buffer display_buffer_descriptor */
struct display_capabilities capabilities;
display_get_capabilities(dev, &capabilities);
if((x + desc->width) > capabilities.x_resolution) {
LOG_ERR("Unsupported origin x %u with buffer width setled to %u (screen overflow)", x, desc->width);
return -1;
if((y + desc->height) > capabilities.y_resolution) {
LOG_ERR("Unsupported origin y %u with buffer height setled to %u (screen overflow)", y, desc->height);
return -1;
LOG_WRN("x %u, y %u, pitch %u, width %u, height %u, buf_len %u",
x, y, desc->pitch, desc->width, desc->height, buf_len);
BYTE x_range[] = {SSD1333_DATA_ADDR_RANGE_X[0] + x, SSD1333_DATA_ADDR_RANGE_X[0] + x +(desc->width - 1)};
BYTE y_range[] = {SSD1333_DATA_ADDR_RANGE_Y[0] + y, SSD1333_DATA_ADDR_RANGE_Y[0] + y + (desc->height - 1)};
// uint32_t total_rows = y2 - y1;
// uint32_t total_cols = x2 - x1;
if(ssd1333_write_bus(dev, SSD1333_CMD_SETCOLUMN, x_range, sizeof(x_range)) || ssd1333_write_bus(dev, SSD1333_CMD_SETROW, y_range, sizeof(y_range))) {
LOG_ERR("Failed to write command");
return -1;
ssd1333_write_bus(dev, SSD1333_CMD_WRITEINTORAM, (BYTE *)buf, buf_len);
return 0;
static struct display_driver_api ssd1333_driver_api = {
.blanking_on = ssd1333_blanking_on,
.blanking_off = ssd1333_blanking_off,
.write = ssd1333_write,
.read = ssd1333_read,
.get_framebuffer = ssd1333_get_framebuffer,
.set_brightness = ssd1333_set_brightness,
.set_contrast = ssd1333_set_contrast,
.get_capabilities = ssd1333_get_capabilities,
.set_pixel_format = ssd1333_set_pixel_format,
.set_orientation = ssd1333_set_orientation
#define SSD1333_DEFINE(inst) \
static const struct ssd1333_config ssd1333_config_##inst = { \
.bus = SPI_DT_SPEC_INST_GET( \
inst, SPI_OP_MODE_MASTER | SPI_TRANSFER_MSB | SPI_WORD_SET(8), 0), \
.dc_gpio = GPIO_DT_SPEC_INST_GET(inst, data_ctrl_gpios), \
.reset_gpio = GPIO_DT_SPEC_INST_GET(inst, reset_gpios), \
.width = DT_INST_PROP(inst, width), \
.height = DT_INST_PROP(inst, height), \
static struct ssd1333_data ssd1333_driver_data_##inst; \
DEVICE_DT_INST_DEFINE(inst, \
ssd1333_init, \
NULL, \
&ssd1333_driver_data_##inst, \
&ssd1333_config_##inst, \
POST_KERNEL, CONFIG_DISPLAY_INIT_PRIORITY, \
&ssd1333_driver_api);
DT_INST_FOREACH_STATUS_OKAY(SSD1333_DEFINE)Kenneth said:gpio_pin_set_dt(&config->dc_gpio, 1);
If you (for debugging) just add some delay between these lines, can you see the same symptoms? I am just trying to understand (since SPI data is not altered during SPI transmission) what delay is causing the problem.
Kenneth
I just tried adding 1ms delay between these lines and also next to spi_write_dt: without success.
For now, I only think of LVGL having something to do with this weird problem
