Hi, How can I get the RLOC16 or similar ID from the CoAP clients connected to my CoAP server? I need to get this information from the messages that the clients send.
Cheers,
Cheers,
Sorry for the delay.
I were looking for a way to do this yesterday, but have not been able to do so yet.
I asked our developers about this, and this is what they said:
Notice that the RLOC16 is used by the child as MAC source address, by this is a Link Layer parameter, not propagated to the Application Layer (CoAP).
The customer should find better ways to identify the end point at an application level.
IPv6 are available at CoAP level, so that could be a way to identify, combined with network diagnostigs:
https://github.com/openthread/openthread/blob/main/src/cli/README.md#networkdiagnostic-get-addr-type-
So that at least gives us some pointers to where we could look.
I will keep digging for some way to do this.
Let me know if you find anything yourself as well.
Sigurd Hellesvik
Hi Sigurd, Many thanks for your efforts, highly appreciated. So the suggested way is to use IP6 from client message? How can we retrieve this info from message itself? Any API calls?
Thanks again,
One step closer: I am able to print the server IP from the client I think.
From the provisioning coap command I were able to print the IP address as such:
diff --git a/samples/openthread/coap_client/src/coap_client_utils.c b/samples/openthread/coap_client/src/coap_client_utils.c
index 52772ace6..f86d0c725 100644
--- a/samples/openthread/coap_client/src/coap_client_utils.c
+++ b/samples/openthread/coap_client/src/coap_client_utils.c
@@ -110,6 +110,13 @@ static int on_provisioning_reply(const struct coap_packet *response,
payload = coap_packet_get_payload(response, &payload_size);
+ char ipurd[40];
+ net_addr_ntop(AF_INET6, from, ipurd, sizeof(ipurd));
+ printk("AAAA %s AAA\n", ipurd);
if (payload == NULL ||
payload_size != sizeof(unique_local_addr.sin6_addr)) {
LOG_ERR("Received data is invalid");
Sigurd Hellesvik
I am greatly appreciating your efforts in solving this, thank you.
This is done in the client isn't it? It looks like client is getting the server's IP? In my case I want to do the opposite. I need the server to figure out who sent the message. So looks like it should be initiated from the server, if possible. Now the servrer must be getting the clients address details, some for or the other.
Worst case I can encode the clients address info (Extended MAC?) in the application level packet, where I put my data to be send to the server. Then server can see that the same way it gets my data. This will extend my packet size and also power consumption, but to how much I have to test it. For that I need an API call for the client to get its own address like extended MAC. Can you point me to some thing like that?
Thanks again,
I think I solved it!
Now that I know the solution, I feel like I should have found it earlier, but as they say "better late then never".
I found the IP address in struct otMessageInfo.
Here is some code for the coap server sample
diff --git a/samples/openthread/coap_server/src/ot_coap_utils.c b/samples/openthread/coap_server/src/ot_coap_utils.c
index 65f1dad17..83ce14f7e 100644
--- a/samples/openthread/coap_server/src/ot_coap_utils.c
+++ b/samples/openthread/coap_server/src/ot_coap_utils.c
@@ -130,6 +130,11 @@ static void light_request_handler(void *context, otMessage *message,
uint8_t command;
ARG_UNUSED(context);
+ char ipurd[OT_IP6_ADDRESS_STRING_SIZE];
+ otIp6Address from = message_info->mPeerAddr;
+ otIp6AddressToString(&from, ipurd, sizeof(ipurd));
+ printk("Peer IP: %s\n",ipurd);
if (otCoapMessageGetType(message) != OT_COAP_TYPE_NON_CONFIRMABLE) {
LOG_ERR("Light handler - Unexpected type of message");
Sigurd Hellesvik
