OTA DFU cant find bootloader
nRF5 SDK SD140
Using the nRF Connect Android app with the DFU utility, looking at the log I send the Enter Bootloader request and get a thumbs up back (op code = 1, status = 1), then the following occur:
[DFU] gatt.refresh()
[DFU] gatt.dsconnect()
[DFU] gatt.close()
[DFU] Sanning for the DFU Bootloader... (timeout 5000ms)
[Callback] Connection state changed with status: 8 and new state: DESCONNECTED (0)
So presumably it's not finding the DFU bootloader. Is this referring to something on the board or something in the DFU package?
  • I dont have a sniffer, I'm trying to update from my phone using the android nrf connect app since I dont have a dongle.
    I have just tried the buttonless example with only tiny modifications (rtt logging and a couple clock changes) and I get the exact same result with one small exception, this time the DFU bootloader IS found
    Could you try the debug variant of the bootloader project, and see if you can get any log output from the bootloader?
    The project is in this folder:
    sdk_folder\examples\dfu\secure_bootloader\pca10056_s140_ble_debug
  • I swapped to that bootloader project This is the RTT output I get but it just loops this and I still get the disconnect after the gatt.discoverServices()
    00> <info> app: Device is preparing to enter bootloader mode.
    00>
    00> <info> app: Disconnected 1 links.
    00>
    00> <info> app: In ble_dfu_buttonless_bootloader_start_finalize
    00>
    00> <info> app: Device will enter bootloader mode.
    00>
    00> <info> app: Power management wants to reset to DFU mode.
    00>
    00> <info> app: Power management allowed to reset to DFU mode.
    00>
    00> <info> app: Setting vector table to bootloader: 0x000F8000
    00>
    00> <info> app: Setting vector table to main app: 0x00027000
    00>
    00> <info> app: Buttonless DFU Application started.
    00>
    00> <info> app: But this time improved!
    1) After you in nRF Connect mobile app, request it to go into bootloader mode, do you see the bootloader advertise? or do you still see the regular application still advertising?
    2) The log you provided is from the app, right? Do you have log from the bootloader project as well?
    3) Could you post the nRF Connect mobile app log?
  • I might be confused on an earlier step in this process. Am I still flashing the hex that  contains the sd, bootloader, and buttonless dfu hex files? Or should i be flashing ONLY the secure_bootloader_debug hex?
    Yes that log in particular is from the app via rtt output, the other logs I was providing were from the nrf connect app
