Thank you for documentation regarding Matter light bulb and switch examples:
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/matter/light_bulb/README.html
It works and I am able to make binding between two matter devices ( I am using nRF52840dk boards): light switch and light bulb.
Now I've also added temperature and humidity clusters using ZAP tool, update source code of lighting app example and I was able to read bme680 sensors values:
I: Update sensor data.... I: Temperature value: 23.210000 I: Humidity value: 43.523000 I: Pressure value: 101.882000 D: 3802285 [DMG]Endpoint 1, Cluster 0x0000_0402 update version to 85202d D: 3802292 [DMG]Endpoint 1, Cluster 0x0000_0405 update version to f2d27d45 D: 3802299 [DMG]Endpoint 1, Cluster 0x0000_0403 update version to 13dbee96
Now the question: How I can bind those values to another matter device, so it will receive immediately when those values are read from sensor? Another matter device will be linux matter client which will display those values.
From lighting switch example I've implemented "BindingHandler" class and I can see that it contains those parameters like 'EndpoinID', 'ClusterID', 'Value' and 'CommandID' . 'Commands' exist in OnOff cluster, but NOT in 'Temperature Measurement' or 'Pressure Measurement' clusters. Is it 'CommandID' required for binding implementation?
Best Regards
Sigitas
