NRF5340DK not enumerating properly on USB
I have issues with my NRF5340DK devices that I'm hoping to get support on. Several devices appear to be bricked, stuck in a boot loop or otherwise unable to program using the latest NRF Connect utility v3.12.0, on Windows 10 64 bit and updated JLink drivers.  Devices either don't enumerate as a USB device, reboot too often for me to erase it or alternatively, shows up as a Jlink device instead of NRF5340DK so that NRFConnect's Programmer v3.0.4 doesn't recognize it as a compatible device.  I've removed the project shield I created so I'm just working with the board itself, switched power to USB and ensured the power switch is "ON".  The last device shows up as a JLink USB thumb drive and in Programmer shows as J-Link with only 2 comm ports instead of 3.  I tried holding Reset while powering on but it does not show up as "Bootloader".  I tried copying j-link-ob-sam3u128-v2-nordicsemi-170724.bin to the existing storage device and power cycling but that also didn't do anything useful.  I'm looking for specific instructions to restore these devices to factory defaults so they will work again.
  • log.log file
    C:\Users\dnear>nrfjprog --version
    nrfjprog version: 10.18.1 external
    JLinkARM.dll version: 7.82
    C:\Users\dnear>nrfjprog --ids
    960156657
    C:\Users\dnear>nrfjprog --com
    960156657    COM16    VCOM1
    960156657    COM15    VCOM2
    960156657    COM11    VCOM0
    C:\Users\dnear>nrfjprog --deviceversion
    [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    ERROR: JLinkARM DLL reported an error. Try again. If error condition
    ERROR: persists, run the same command again with argument --log, contact Nordic
    ERROR: Semiconductor and provide the generated log.log file to them.
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
    In your log.log, the tool version is v10.15.4. I would suggest to remove all the nRF Command Line Tool via Control Panel\Programs\Programs and Features and install the latest one. Then, provide the log.log for DK v1.0.0 and v2.0.0 seperately.
    Amanda H.
  • Did so, and looks like maybe that updated properly.
    1.0.0 reads with power source set to VDD
    960156657_log.log
    2.0.0 only reads with power source set to USB
    1050042215_log.log
    Can you try to connect this DK with nRF Programmer and check again? If it still has the issue, please also provide the log from nRF Programmer.
    Please run the following commands and provide the log.log again. Thanks.
    nrfjprog --recover --coprocessor CP_NETWORK
    nrfjprog --recover
    nrfjprog --deviceversion --log
    -Amanda H.
  • NRFJ Programmer output for 1.0..0 board, it won't recognize the unit as J-link despite being named "J-link"
    NRFJ Programmer Screenshot
    14:13:41.244
    Using nrf-device-lib-js version: 0.4.13
    14:13:41.244
    Using nrf-device-lib version: 0.12.8
    14:13:41.244
    Using nrfjprog DLL version: 10.16.0
    14:13:41.244
    Using JLink version: JLink_V7.66a
    14:20:05.640
    Unsupported device. The detected device could not be recognized as neither JLink device nor Nordic USB device
    Both --recover and --recover --coprocessor CP_Network returns a bunch of "reported -1, unknown error"
    2.0.0 Log output 2nd file
