I'm pretty new to Zephyr and I have to figure out how to connect to a NOR flash over SPI. Final application is the implementation of a file system, e.g. littlefs.
There is very little documentation on the web on that subject and one of the only I could find was this thread here: https://devzone.nordicsemi.com/f/nordic-q-a/75393/how-to-get-started-with-zephyr-fs-on-external-nor-flash?focus=true and those linked with it.
I'm working on a custom platform with a standard 4-wire SPI and the NOR Flash is Microchip SST25VF016. Maybe someone could help me with a general hint because due to little documentation and experience, I'm stucked. Thanks in advance!
First goal is to make the Zephyr NOR-flash example to run.
First problem is that my device handle from the devicetree is always empty. I guess that something is missing/ wrong with the NOR Flash driver but I don't get it. Do I need a binding (.yaml) file for the particular flash type? If so, where can I find a template (like the everywhere used MX25r64)?
In my config I added this:
# support nor flash on spiCONFIG_FLASH=yCONFIG_SPI_NOR=yCONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
In the devicetree I added "jedec, spi-nor" and "fixed-partitions" object: (the SPI-interface for itself has been tested before and is working).
&spi1 { status = "okay"; pinctrl-0 = <&spi1_sck_pg2 &spi1_miso_pg3 &spi1_mosi_pg4>; pinctrl-names = "default"; sst25: sst25vf016@0 { compatible = "jedec,spi-nor"; label = "SST25"; reg = <0>; spi-max-frequency = <1000000>; jedec-id = [c2 28 17]; size = <16777216>; };};
&sst25 { partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; partition@0 { label = "storage"; reg = <0x01000000 0x00800000>; }; };};
My initialization looks like this:
#include "stdIncl.h"#include <drivers/spi.h>#include <drivers/flash.h>
#if (CONFIG_SPI_NOR - 0) || \ DT_NODE_HAS_STATUS(DT_INST(0, jedec_spi_nor), okay)#define FLASH_DEVICE DT_LABEL(DT_INST(0, jedec_spi_nor))#define FLASH_NAME "JEDEC SPI-NOR"#else#error "Missing SPI-NOR flash in device tree"#endif
Everything builds and runs fine. FLASH_DEVICE resolves to "SST25" but after the initialization, the device handle is always null:
static const struct device* s_device_p;
s_device_p = device_get_binding( FLASH_DEVICE ); //becomes 0x0
Any help is appreciated!
