NRFX UARTE TX failure (using nRF connect SDK v2.1.0)
I am trying to implement a simple uart echo test using nRF21540 DB board, but I always get NRFX_ERROR_FORBIDDEN when trying to transmit.
This is the initialization code:
    nrfx_uarte_t        uarteInstance = NRFX_UARTE_INSTANCE( 1 );
    uarteConfig.pseltxd = nRF52Host_TX_DBG;
    uarteConfig.pselrxd = nRF52Host_RX_DBG;
    uarteConfig.pselcts = NRF_UARTE_PSEL_DISCONNECTED;
    uarteConfig.pselrts = NRF_UARTE_PSEL_DISCONNECTED;
    uarteConfig.p_context = NULL;
    uarteConfig.baudrate = NRF_UARTE_BAUDRATE_9600;
    uarteConfig.interrupt_priority = NRFX_UARTE_DEFAULT_CONFIG_IRQ_PRIORITY;
    uarteConfig.hal_cfg.hwfc = NRF_UARTE_HWFC_DISABLED;
    uarteConfig.hal_cfg.parity = NRF_UARTE_PARITY_EXCLUDED;
    uarteConfig.hal_cfg.stop = NRF_UARTE_STOP_ONE;
    uarteConfig.skip_gpio_cfg = false;
    uarteConfig.skip_psel_cfg = false;
    if (nrfx_uarte_init(&uarteInstance, &uarteConfig, NULL) == NRFX_SUCCESS)
        printf("success\r\n");
then trying to transmit using this call, is always returning error:
    static uint8_t test_bytes[4] = {0xA5, 0xA6, 0xA7, 0xA8};
    nrfx_uarte_tx(&uarteInstance, test_bytes, 4);
Is there some configuration I am missing?
  • Providing handler, it halts everything when trying to TX. Shell thread got unresponsive.
    I am not sure about the power management, the only I can see enabled in proj.conf is CONFIG_NRFX_POWER=y
    Halts, without any returned error codes?
    Do you have a minimal example that demonstrates this behavior, that you could share with me, in its entirety, so that I may take a look?
    Could you share with me your entire prj.conf, and any other overlays that are active in the build configuration here?
    The Power management I referenced in my previous comment is governed by the CONFIG_PM Kconfig.
    Karl
    Attached my proj.conf
    # Enabling assert
    CONFIG_ASSERT=y
    # Logger configuration
    CONFIG_LOG=y
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    # Enable temperature sensor
    CONFIG_NRFX_TEMP=y
    # Enable DC/DC Support
    CONFIG_NRFX_POWER=y
    # Enable RNG
    CONFIG_NRFX_RNG=y
    # Use XOROSHIRO PRNG
    CONFIG_XOROSHIRO_RANDOM_GENERATOR=y
    # Enable Timer
    CONFIG_NRFX_TIMER2=y
    # Enabling radio driver
    CONFIG_NRF_802154_RADIO_DRIVER=y
    # Allow sharing the RTC between IEEE 802.15.4 and Zephyr
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=2
    # Workaround for a bug in the MPSL Glue Layer (not required for nRF52840)
    CONFIG_BT=y
    # Enable ring buffers
    CONFIG_RING_BUFFER=y
    # Set temperature sensor update period in ms
    CONFIG_NRF_802154_TEMPERATURE_UPDATE_PERIOD=10000
    CONFIG_NRF_802154_ENCRYPTION=n
    # Shell configuration
    CONFIG_SHELL=y
    CONFIG_SHELL_PROMPT_UART=">"
    CONFIG_SHELL_VT100_COLORS=n
    #enable qspi
    CONFIG_NRFX_QSPI=y
    #enable spi
    CONFIG_NRFX_SPI0=y
    #enable uart
    CONFIG_NRFX_UARTE1=y
    # Debug configuration
    CONFIG_DEBUG_OPTIMIZATIONS=y
    CONFIG_DEBUG_THREAD_INFO=y
    Then, I dont have any custom overlay file.
    My project is using the default nrf52840dk_nrf52840.dts located at ncs\v2.1.0\zephyr\boards\arm\nrf52840dk_nrf52840
    I can not see anything that should cause this behavior from the prj.conf alone.
    Would it be possible for you to send me a minimal version of this project that replicates this behavior, so that I may take a look at this myself?
    Karl
