Please tell me how to achieve re-pairing.
I am developing with nrf52832 (s132 v7.0.1, SDK v17.0.0) as a peripheral device.
I would like to have it re-paired when there is no pairing information for either peripheral or central.
I found out that this can be done by allowing re-pairing when PM_EVT_CONN_SEC_CONFIG_REQ occurs, so I added that process, but the pairing does not succeed and the device is disconnected.
pm_conn_sec_config_t conn_sec_config;
case PM_EVT_CONN_SEC_CONFIG_REQ:
        NRF_LOG_INFO("PM_EVT_CONN_SEC_CONFIG_REQ");
        conn_sec_config.allow_repairing = true;
        pm_conn_sec_config_reply(conn_handle, &conn_sec_config);
The disconnection is done after PM_EVT_CONN_SEC_FAILED.
No special processing is done in PM_EVT_CONN_SEC_FAILED.
case PM_EVT_CONN_SEC_FAILED:
        if (p_evt.params.conn_sec_failed.error == BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP) {
            NRF_LOG_INFO("No Bonding Infomation for Central.");
            return;
        else if (p_evt.params.conn_sec_failed.error == PM_CONN_SEC_ERROR_PIN_OR_KEY_MISSING) {
            NRF_LOG_INFO("No Bonding Infomation for Peripheral.");
            return;
How can we achieve re-pairing?
  • sdi_kei said:
    This is because we currently do not delete bonding information when disconnecting.
    You don't delete bonding information on when disconnecting, but you are unable to reconnect due to the bonding information is missing?
    But on the phone side, you choose to disconnect and "forget" the device, thus deleting the bond information?
    Br,
    Joakim
  • I didn't communicate it well, my apologies.
    When I said when disconnected, I meant when BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP occurs and disconnection occurs.
    Central (phone) does not remember pairing information because it is manually deleted.
    This is because it wants to perform a re-pairing action.
    Thank you in advance for your cooperation.
  • Hello.
    I have re-logged the re-pairing.
    I have changed the log level to Debug to output a more detailed log.
    Can you tell the cause of the error from this information?
    00> <debug> nrf_sdh_ble: BLE event: 0x10.
    00> <debug> peer_manager_handler: Event PM_EVT_BONDED_PEER_CONNECTED
    00> <debug> peer_manager_handler: Previously bonded peer connected: role: Peripheral, conn_handle: 0, peer_id: 0
    00> <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_PARAMS_REQ
    00> <debug> peer_manager_handler: Security parameter request
    00> <debug> peer_manager_handler: Event PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
    00> <debug> peer_manager_handler: Event PM_EVT_LOCAL_DB_CACHE_APPLIED
    00> <debug> peer_manager_handler: Previously stored local DB applied: conn_handle: 0, peer_id: 0
    00> <info> app: Connected, handle 0x0.
    00> <debug> nrf_sdh_ble: BLE event: 0x21.
    00> <info> app: PHY update request.
    00> <debug> nrf_sdh_ble: BLE event: 0x22.
    00> <debug> nrf_sdh_ble: BLE event: 0x23.
    00> <debug> nrf_ble_gatt: Peer on connection 0x0 requested a data length of 251 bytes.
    00> <debug> nrf_ble_gatt: Updating data length to 27 on connection 0x0.
    00> <debug> nrf_sdh_ble: BLE event: 0x24.
    00> <debug> nrf_ble_gatt: Data length updated to 27 on connection 0x0.
    00> <debug> nrf_ble_gatt: max_rx_octets: 27
    00> <debug> nrf_ble_gatt: max_tx_octets: 27
    00> <debug> nrf_ble_gatt: max_rx_time: 2120
    00> <debug> nrf_ble_gatt: max_tx_time: 2120
    00> <debug> nrf_sdh_ble: BLE event: 0x55.
    00> <debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 185 bytes.
    00> <debug> nrf_ble_gatt: Updating ATT MTU to 23 bytes (desired: 23) on connection 0x0.
    00> <debug> nrf_sdh_ble: BLE event: 0x50.
    00> <debug> nrf_sdh_soc: SoC event: 0x2.
    00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
    00> <debug> peer_manager_handler: Event PM_EVT_FLASH_GARBAGE_COLLECTED
    00> <debug> peer_manager_handler: Flash garbage collection complete.
    00> <debug> nrf_sdh_ble: BLE event: 0x13.
    00> <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_START
    00> <debug> peer_manager_handler: Connection security procedure started: role: Peripheral, conn_handle: 0, procedure: Bonding
    00> <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_CONFIG_REQ
    00> <debug> peer_manager_handler: Security configuration request
    00> <info> app: PM_EVT_CONN_SEC_CONFIG_REQ
    00> <debug> nrf_sdh_ble: BLE event: 0x19.
    00> <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_FAILED
    00> <info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 133
    00> <debug> peer_manager_handler: Error (decoded): BLE_GAP_SEC_STATUS 0x85
    00> <info> app: Connection Security Failed. procedure: 0x1, error: 0x85, error_src: 0x0.
    00> <info> app: No Bonding Infomation for Central.
    00> <debug> nrf_sdh_ble: BLE event: 0x11.
    00> <info> app: Disconnected. conn_handle: 0x0, reason 0x13.
    Best regards and thank you in advance for your help.
  • Thanks!
    Before looking at your logs, I tested this in an example myself, to check if I would reproduce the issue.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_disconnect_on_sec_failure(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(false);
                pm_conn_sec_config_reply(m_conn_handle, &conn_sec_config);
    Paired the device to my phone. Then I deleted the bond on the central (phone) side, and tried to re-pair. Works as expected.
    BR,
    Joakim
  • Hello.
    Sorry for the late reply.
    I found the reason why my code did not re-pair.
    When PM_EVT_CONN_SEC_CONFIG_REQ occurred, it was not processed in the event handler, but was stored as a task and processed after some time had passed.
    As you taught us, we implemented PM_EVR_CONN_SEC_CONFIG_REQ and were able to re-pair.
    Thank you!
