Can the UART RX/TX pins be also read as GPIO input pins
Greetings,
We are using the NCS for the development of a new product with a custom board based on the nRF52840 MCU.
First, we would like to use the Serial DFU feature to update the firmware over UART. I have found and will be implementing this guide for that. Please confirm that this is indeed correct.
Second we want to also use the same lines(RX/TX) as GPIOs (inputs) and read their status. What way would you suggest going about this? I have found this suggestion usefull (connecting the TX/RX lines to two other available GPIO pins to also read the level of the TX/RX lines) as we will not be using the UART interface and reading the same lines simultaneously.
What are your thoughts and suggestions on implementing this? Will connecting two other GPIO pins on the RX/TX lines cause issues to the UART even if we do not read the pins while the UART interface is in use?
Thank you very much and I look forward to hearing from you!
Stavros
  • Hi Stavros,
    Do you have the custom_board.defconfig ?
    I believe it's the root cause. I created my own board and got the same issue as you.
    But if I copied the .defconfig of the DK board it worked for me.
    It should look like this:
    # Copyright (c) 2022 Nordic Semiconductor ASA
    CONFIG_SOC_SERIES_NRF52X=y
    CONFIG_SOC_NRF52840_QIAA=y
    CONFIG_BOARD_MYBOARD2=y
    # Enable MPU
    CONFIG_ARM_MPU=y
    # Enable hardware stack protection
    CONFIG_HW_STACK_PROTECTION=y
    # Enable RTT
    CONFIG_USE_SEGGER_RTT=y
    # enable GPIO
    CONFIG_GPIO=y
    # enable uart driver
    CONFIG_SERIAL=y
    # enable console
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    # additional board options
    CONFIG_GPIO_AS_PINRESET=y
    CONFIG_PINCTRL=y
    I would assume if you dont want to add the config in the board file, you can also add them in the proj.conf.
  • Hi Hung,
    Thank you very much for your responses they were very helpful and I have the Bootloader & DFU process working for both Serial DFU and OTA using BLE!
    I have some followup questions because the documentation is kind of fragmented and convoluted not really citing a specific way of implementing the DFU process (some use SMP Server and others use DFU-Util).
    I have used the SMP Server method with a custom private key succesfully and my questions are:
    1. Are the FW images generated when building the application (with the SMP Server & MCUBoot
      CONFIG_BOOTLOADER_MCUBOOT) such as app_update.bin & dfu_application.zip encrypted or protected from reverse engineering ( can someone get the source code by using these ) or do I have to enable encryption for the MCUBoot to achieve this? If so how is this done?
    2. I have seen some tickets that use permanent configuration files for the MCUBoot without editing the MCUBoot source files by using a conf file in the child_image directory, but in my project there is no child_image directory thus I cant use a permanent conf file for MCUBoot because I want to add some conf options. How do I make it generate the child_image or alternatively how do I pass permanent configuration options to a child image such as MCUBoot using the VS Code (I have read all the guides and documentation on this and know it can be done by adding arguments to the the west build command but I dont want to do this everytime I want to build my application) Is there a way to specify them in VS Code so that when I press build in the nRF Connect Extension the build command includes those arguments
    3. Is there a better way to have a bootloader and perform DFU (serial & OTA) using something else other than the SMP Server and MCUMgr?
      Thank you very much for your time!
      Stavros
  • Hi Stavros,
    1. No it's not enabled by default. So the binary file are original and can be reverse engineer. It's possible to enable encryption with MCUBoot, but we haven't tested it and it's not integrated in the build system. So you would need to manually encrypt the image using imgtool.
    2. You can just create one your self. Just make the child_image folder and then put a mcuboot.conf there.
    You can also add extra CMake arguments like this:
    3. No. But it should be possible to make your own protocol. SMP is not obligated. You just need to find a way to store the image in the correct slot and then boot to MCUboot to finish the swap.
  • Hi Hung,
    Two followup questions to my first question:
       1. Could you elaborate on the method of manually encrypting using the imgtool or provide some relevant documentation as I could not find a way that worked by following the documentation and previous tickets on the subject:
    developer.nordicsemi.com/.../encrypted_images.html
    devzone.nordicsemi.com/.../mcuboot-with-serial-uart-and-image-encryption
     https://devzone.nordicsemi.com/f/nordic-q-a/91331/nrf52840-ncs-mcuboot-cc310-enabled-image-encryption/383355
       2. Is there encryption of the binary file used for updates available/possible for the nRF Secure Immutable Bootloader?
    Thank you!
    Stavros
  • Hi Stavros,
    Sorry for the late response. I was on vacation.
    I think you would need to create a new ticket as it's drifting away from the original question. Also I don't have much experience with the encrypting of image.
    As I mentioned, we don't support encrypting image out of the box. So you would need to follow the documentation from MCUBoot and imgtool.
    Vidar would have some more experience on this. I think creating a new ticket would be the best.
