UART RX missing bytes -event buffer length and offset mismatch-NRF Connect SDK
Hi, greetings all !!
I am developing an application based on ble_uart_peripheral example on nrf52dk_nrf52832 using NRF Connect SDK2.1. In my application, I have to receive bytes from an external client via UART. The problem is, at high baud rate, some of my bytes get missed. For example, while debugging, the evt->data.rx.offset shows 4 but evt->data.rx.len shows 2. So, when i try to read the buffer, based on offset value, I miss bytes. HW flow control is not an option for me since that would involve changes to my client as well. Is there anything else I can do to get this working ? I thought it might be an overrun case, but that was not the error cause.
Any ideas ?
  • I want to get data byte by byte for my purpose. what would be a better method to do that ? please excuse my ignorance.
  • Did you try setting the config I suggested in my last post?
  • I am sorry I did not mention about that. Yes, I tried but that didnt work. When I added that in the config environment, the device stopped receiving at all. No callbacks at all for receiving.
  • Ah, I see. The config is used for both the RX and TX buffers, and the buffer will be too small for the TX strings used in the example, causing an error.
    You can modify the example to use separate TX and RX buffer sizes, as shown in this patch:
    diff --git a/samples/bluetooth/peripheral_uart/src/main.c b/samples/bluetooth/peripheral_uart/src/main.c
    index d8afb44ca..bb93b71f4 100644
    --- a/samples/bluetooth/peripheral_uart/src/main.c
    +++ b/samples/bluetooth/peripheral_uart/src/main.c
    @@ -62,6 +62,12 @@ static struct bt_conn *auth_conn;
     static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
     static struct k_work_delayable uart_work;
    +struct uart_data_rx_t {
    +	void *fifo_reserved;
    +	uint8_t data[1];
    +	uint16_t len;
     struct uart_data_t {
     	uint8_t data[UART_BUF_SIZE];
    @@ -92,6 +98,7 @@ static void uart_cb(const struct device *dev, struct uart_event *evt, void *user
     	static size_t aborted_len;
     	struct uart_data_t *buf;
    +	struct uart_data_rx_t *buf_rx;
     	static uint8_t *aborted_buf;
     	static bool disable_req;
    @@ -128,15 +135,16 @@ static void uart_cb(const struct device *dev, struct uart_event *evt, void *user
     	case UART_RX_RDY:
     		LOG_DBG("UART_RX_RDY");
    -		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
    -		buf->len += evt->data.rx.len;
    +		buf_rx = CONTAINER_OF(evt->data.rx.buf, struct uart_data_rx_t, data);
    +		buf_rx->len += evt->data.rx.len;
    +		LOG_INF("UART RX: offset: %d, len: %d", evt->data.rx.offset, evt->data.rx.len);
     		if (disable_req) {
     			return;
    -		if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
    -		    (evt->data.rx.buf[buf->len - 1] == '\r')) {
    +		if ((evt->data.rx.buf[buf_rx->len - 1] == '\n') ||
    +		    (evt->data.rx.buf[buf_rx->len - 1] == '\r')) {
     			disable_req = true;
     			uart_rx_disable(uart);
    @@ -147,26 +155,26 @@ static void uart_cb(const struct device *dev, struct uart_event *evt, void *user
     		LOG_DBG("UART_RX_DISABLED");
     		disable_req = false;
    -		buf = k_malloc(sizeof(*buf));
    -		if (buf) {
    -			buf->len = 0;
    +		buf_rx = k_malloc(sizeof(*buf));
    +		if (buf_rx) {
    +			buf_rx->len = 0;
     		} else {
     			LOG_WRN("Not able to allocate UART receive buffer");
     			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
     			return;
    -		uart_rx_enable(uart, buf->data, sizeof(buf->data),
    +		uart_rx_enable(uart, buf_rx->data, sizeof(buf_rx->data),
     			       UART_WAIT_FOR_RX);
     	case UART_RX_BUF_REQUEST:
     		LOG_DBG("UART_RX_BUF_REQUEST");
    -		if (buf) {
    -			buf->len = 0;
    -			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
    +		buf_rx = k_malloc(sizeof(*buf_rx));
    +		if (buf_rx) {
    +			buf_rx->len = 0;
    +			uart_rx_buf_rsp(uart, buf_rx->data, sizeof(buf_rx->data));
     		} else {
    @@ -175,13 +183,13 @@ static void uart_cb(const struct device *dev, struct uart_event *evt, void *user
     	case UART_RX_BUF_RELEASED:
     		LOG_DBG("UART_RX_BUF_RELEASED");
    -		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
    +		buf_rx = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_rx_t,
     				   data);
    -		if (buf->len > 0) {
    -			k_fifo_put(&fifo_uart_rx_data, buf);
    +		if (buf_rx->len > 0) {
    +			k_fifo_put(&fifo_uart_rx_data, buf_rx);
     		} else {
    -			k_free(buf);
    +			k_free(buf_rx);
    @@ -208,18 +216,18 @@ static void uart_cb(const struct device *dev, struct uart_event *evt, void *user
     static void uart_work_handler(struct k_work *item)
    -	struct uart_data_t *buf;
    -	if (buf) {
    -		buf->len = 0;
    +	if (buf_rx) {
    +		buf_rx->len = 0;
     	} else {
     		return;
    -	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
    +	uart_rx_enable(uart, buf_rx->data, sizeof(buf_rx->data), UART_WAIT_FOR_RX);
     static bool uart_test_async_api(const struct device *dev)
    @@ -234,7 +242,7 @@ static int uart_init(void)
     	int err;
     	int pos;
    -	struct uart_data_t *rx;
    +	struct uart_data_rx_t *rx;
     	struct uart_data_t *tx;
     	if (!device_is_ready(uart)) {
    Note that the peripheral_uart application gave lots of warnings about not being able to allocate UART receive buffer when receiving much data, so this approach may lead to data loss if you are not careful about the baudrate and frequency of incoming data. I would advise against using this approach. Processing the received bytes according to the offset and len parameters and/or pushing the received data into a queue for later processing would be a much safer approach.
  • Yes. The issue was caused due to the shared buffer. So, i tried using seperate buffers. But buffer size of 1 wont be enough as I observed it caused kernel panic. I believe the first 2 locations are used for some OS level purposes. Anyway, I got it working with size 3. But as you mentioned, this might not be a good solution.
    That was what i tried to do initially, but without knowing the exact length and offset, that would be difficult.  Can you guide me with a code snippet ?
