Good day
I am developing on the nrf9160dk with a tag reader using i2c and am wanting to know if there is a function to pull down the SDA or SCL pins during operation in order to wake up the slave device.
Thank you in advance.
Hassan
Good day
Hassan
Yes, this is our function to start a TWI transfer. However, in general, we recommend to use the Zephyr's driver APIs when possible (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/hardware/peripherals/i2c.html). You can have a look at the i2c_fujitsu_fram driver sample in the Zephyr tree for an example of how this API can be used.
Vidar
Good day,
I've attempted using these functions and APIs and when I test the board with the multimeter, pin 30 and 31 (my i2c2 pins) get zero voltage output. Do the pins start the output in the prj file or when a write/read sequence is initiated?
Hassan
My code is as follows:
main.c
#include <zephyr/zephyr.h>
#include <drivers/i2c.h>
#include <stdio.h>
#include <nrfx_twim.h>
#include <C:\nordicsemi\v2.1.1\modules\hal\nordic\nrfx\hal\nrf_gpio.h>
#include <hal/nrf_twim.h>
/** I2C address to be used for ST25DV Data accesses. */
#define ST25DV_ADDR_DATA_I2C 0x53
/** I2C address to be used for ST25DV System accesses. */
#define ST25DV_ADDR_SYST_I2C 0x57
void Delay(int n)
int c, d;
for (c = 1; c <= n; c++)
for (d = 1; d <= n; d++)
return 0;
void main(void)
// *************START************* //
const struct device * i2c_dev;
i2c_dev = DEVICE_DT_GET(DT_NODELABEL(i2c2));
if (i2c_dev == NULL) {
printk("Unable to bind !\n");
return;
//************** DEVICE SELECT CODE**************//
const uint8_t devSelCode[8] = {1, 0, 1, 0, 0, 1, 1, 0};
int err1 = i2c_write(i2c_dev,devSelCode,8,ST25DV_ADDR_DATA_I2C);
printk("Device select msg: %d", err1);
prj
CONFIG_STDOUT_CONSOLE=y
CONFIG_PRINTK=y
CONFIG_I2C=y
# CONFIG_LOG=y
Is there possibly something wrong in my configuration that I am not seeing an output in my specified i2c2 pins? Thank you for your help!
It seems like you don't have external pull-ups on the SDA and SCL lines as you measure 0 V on both . In that case, you will need to enable the internal pull-up resistors by adding the bias-pull-up property to your pin assignment in the device tree.
&pinctrl {
i2c2_default: i2c2_default {
group1 {
psels = <NRF_PSEL(TWIM_SDA, 0, 30)>,
<NRF_PSEL(TWIM_SCL, 0, 31)>;
bias-pull-up;
i2c2_sleep: i2c2_sleep {
group1 {
low-power-enable;
HI
This has helped! Am now seeing an output when the program starts as well as the drop of output on the SDA line when writing to the i2c2 . However, the write function still returning an error value. Other than the slave address or device function code being incorrect, are there any other reasons for the function to fail?
