nRF5340 audio DK WALKIE_TALKIE_DEMO build error
Hi, I am using nRF5340 audio DK PCA10121, NCS 2.1.1 I am following https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/nrf5340_audio/README.html#enabling-the-walkie-talkie-demo to have prj.conf with CONFIG_WALKIE_TALKIE_DEMO=y.
I got this undefined symbol error "c:/Projects/Amoeba/BLE-Firmware/central_comm_node/prj.conf:70: warning: attempt to assign the value 'y' to the undefined symbol WALKIE_TALKIE_DEMO".
Here is my complete build trace. Please advise, thanks.
* Executing task: nRF Connect: Build: central_comm_node/build (active)
Building central_comm_node
west build --build-dir c:\Projects\Amoeba\BLE-Firmware\central_comm_node\build c:\Projects\Amoeba\BLE-Firmware\central_comm_node --pristine --board nrf5340_audio_dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONFIG_DEBUG_OPTIMIZATIONS:STRING="y" -DCONFIG_DEBUG_THREAD_INFO:STRING="y" -DDTC_OVERLAY_FILE:STRING="c:/Projects/Amoeba/BLE-Firmware/central_comm_node/nrf5340_audio_dk_nrf5340_cpuapp.overlay" -DCONF_FILE:STRING="c:/Projects/Amoeba/BLE-Firmware/central_comm_node/prj.conf"
-- Application: C:/Projects/Amoeba/BLE-Firmware/central_comm_node
-- Found Python3: C:/ncs/toolchains/v2.1.1/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.1.1/zephyr/.cache
-- Zephyr version: 3.1.99 (C:/ncs/v2.1.1/zephyr)
-- Board: nrf5340_audio_dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.14.1 (C:/ncs/toolchains/v2.1.1/opt/zephyr-sdk)
-- Found dtc: C:/ncs/toolchains/v2.1.1/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (C:/ncs/toolchains/v2.1.1/opt/zephyr-sdk)
-- Found BOARD.dts: C:/ncs/v2.1.1/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: c:/Projects/Amoeba/BLE-Firmware/central_comm_node/nrf5340_audio_dk_nrf5340_cpuapp.overlay
-- Generated zephyr.dts: C:/Projects/Amoeba/BLE-Firmware/central_comm_node/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Projects/Amoeba/BLE-Firmware/central_comm_node/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Projects/Amoeba/BLE-Firmware/central_comm_node/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Projects/Amoeba/BLE-Firmware/central_comm_node/build/zephyr/dts.cmake
warning: Experimental symbol NRF5340_AUDIO is enabled.
warning: Experimental symbol BT_ISO_CENTRAL is enabled.
warning: Experimental symbol BT_AUDIO is enabled.
Parsing C:/Projects/Amoeba/BLE-Firmware/central_comm_node/Kconfig
Loaded configuration 'C:/ncs/v2.1.1/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp_defconfig'
Merged configuration 'c:/Projects/Amoeba/BLE-Firmware/central_comm_node/prj.conf'
Merged configuration 'C:/Projects/Amoeba/BLE-Firmware/central_comm_node/build/zephyr/misc/generated/extra_kconfig_options.conf'
warning: Experimental symbol BT_AUDIO_UNICAST_CLIENT is enabled.
warning: Experimental symbol BT_VCS_CLIENT is enabled.
error: Aborting due to Kconfig warnings
CMake Error at C:/ncs/v2.1.1/zephyr/cmake/modules/kconfig.cmake:293 (message):
command failed with return code: 1
C:/ncs/v2.1.1/zephyr/cmake/modules/zephyr_default.cmake:121 (include)
C:/ncs/v2.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.1.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:37 (find_package)
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.1.1\opt\bin\cmake.EXE' '-DWEST_PYTHON=c:\ncs\toolchains\v2.1.1\opt\bin\python.exe' '-Bc:\Projects\Amoeba\BLE-Firmware\central_comm_node\build' -GNinja -DBOARD=nrf5340_audio_dk_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DCONFIG_DEBUG_OPTIMIZATIONS:STRING=y -DCONFIG_DEBUG_THREAD_INFO:STRING=y -DDTC_OVERLAY_FILE:STRING=c:/Projects/Amoeba/BLE-Firmware/central_comm_node/nrf5340_audio_dk_nrf5340_cpuapp.overlay -DCONF_FILE:STRING=c:/Projects/Amoeba/BLE-Firmware/central_comm_node/prj.conf '-Sc:\Projects\Amoeba\BLE-Firmware\central_comm_node'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
