Cannot reconfigure BLE peripheral UART example to send data I have stored in buffer please help
Hello I have seen ALOT of posts referencing to first build and run ble peripheral uart example and then from there that it will be easy to remove the uart from the functionality if so desired but I cannot seem to get this to work.
I have tried many different approaches over the past few weeks and no matter what I do I cannot get an app up and running that allows me to use my PCB as peripheral that automatically sends a buffer of data (a bunch of SSIDs concatenated) on connection of central device (NRF Connect app). Is there please a snippet of code you can provide me that shows how to go from using the uart to having my own custom service that just sends a buffered message over ble?
  • HI Matt,
    You mean that the program "spins" in  the APP_UART_DATA_READY switch case? Are you sending a lot off data? Maybe the APP_UAR_DATA_READY event is just generated multiple times because you're trying to send much data at a time.
    regards
    Jared
  • Yes that is what it is doing, but I am only sending 20 bytes per nus_data_send() per your earlier instruction, perhaps it is my invocation?
        static int index = 1;
        app_sched_execute();
        cli_process();
        (void)NRF_LOG_PROCESS();
       if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
          uart_event_handle(APP_UART_DATA_READY);
    Can you share your main.c file?
    regards
    Jared
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
     *    list of conditions and the following disclaimer.
     *    Semiconductor ASA integrated circuit in a product or a software update for
     *    such product, must reproduce the above copyright notice, this list of
     *    conditions and the following disclaimer in the documentation and/or other
     *    materials provided with the distribution.
     *    contributors may be used to endorse or promote products derived from this
     *    software without specific prior written permission.
     *    Nordic Semiconductor ASA integrated circuit.
     *    engineered, decompiled, modified and/or disassembled.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include <stdlib.h>
    #include "sdk_config.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_delay.h"
    #include "nrf_drv_clock.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_scheduler.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_uart.h"
    #include "u_version.h"
    #include "u_app.h"
    #include "u_cli.h"
    #include "u_nest.h"
    #include "u_timers.h"
    #include "esp32_wroom.h"
    #include "ble_cus.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    // Scheduler sizes
    // TODO: Determine an actual fact-based max event size and queue size.
    #define APP_SCHED_MAX_EVENT_SIZE    32u
    #define APP_SCHED_QUEUE_SIZE        256u
    //#ifdef USE_BLE
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "OVVi_connect"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. (64)This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                0 // MC 18000                               /**< The advertising duration (180 seconds) in units of 10 milliseconds. */ //This is what puts the app to sleep after 3 minutes
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define PASSKEY_TXT                     "Passkey:"                                  /**< Message to be displayed together with the pass-key. */
    #define PASSKEY_TXT_LENGTH              8                                           /**< Length of message to be displayed together with the pass-key. */
    #define PASSKEY_LENGTH                  6                                           /**< Length of pass-key received by the stack for display. */
    #define STATIC_PASSKEY            "123456"                                     /**< Static pin. */
    #define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2       /**< Reply when unsupported features are requested. */
    static ble_gap_opt_t            m_static_pin_option;                        /**< Pointer to the struct containing static pin option. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    // ESP32 Def
    #define AP_SSID                         "F58516"
    #define AP_PWD                          "65916957"*/
    APP_TIMER_DEF(tx_timer);                      //defining timer
    #define NOTIFICATION_INTERVAL           APP_TIMER_TICKS(1000)
    uint32_t err_code = 0u;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/ //qwrS for multiple connections
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    static int transmission_complete = 0;
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     *          how your product is supposed to react in case of Assert.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
        ble_gap_conn_params_t   gap_conn_params;
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&sec_mode); // Use encryption with no man in the middle so any malicious actors cannot read encrypted wifi parameters
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_HID); //creating custom services and unique application
        gap_conn_params.slave_latency     = SLAVE_LATENCY;
        gap_conn_params.conn_sup_timeout  = CONN_SUP_TIMEOUT;
        err_code = sd_ble_gap_ppcp_set(&gap_conn_params); //Allows master device to acccept or dictate connection params to Nordic
    // C substring function definition
    void substring(char s[], uint8_t sub[], int p, int l) {
       int c = 0;
       while (c < l) {
          sub[c] = s[p+c-1];
          c++;
       sub[c] = '\0';
    /**@brief   Function for sending SSIDs to.
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t data_array1[20];
        substring(bleBuff, data_array1, 0, 20);
        static uint8_t data_array2[20];
        substring(bleBuff, data_array2, 20, 20);
        static uint8_t data_array3[20];
        substring(bleBuff, data_array3, 40, 20);
        static uint8_t data_array4[20];
        substring(bleBuff, data_array4, 60, 20);
        static uint8_t data_array5[20];
        substring(bleBuff, data_array5, 80, 20);
        static uint8_t data_array6[20];
        substring(bleBuff, data_array6, 100, 20);
        static uint8_t data_array7[20];
        substring(bleBuff, data_array7, 120, 20);
        static uint8_t data_array8[20];
        substring(bleBuff, data_array8, 140, 20);
        uint32_t       err_code;
        static int lengthOfMessage;
        lengthOfMessage = sizeof(bleBuff);
        uint16_t  packetSize = 20;
        static int packetCount = 0;
        packetCount = (lengthOfMessage / packetSize) +.5;
        switch (p_event->evt_type)
        case APP_UART_DATA_READY:
                nrf_delay_ms(2000);
                NRF_LOG_INFO("Ready to send data over BLE NUS");
                      err_code = ble_nus_data_send(&m_nus, data_array1, &packetSize, m_conn_handle);
                      NRF_LOG_INFO("ble_nus_data_send returned %d", err_code);
                      err_code = ble_nus_data_send(&m_nus, data_array2, &packetSize, m_conn_handle);
                      err_code = ble_nus_data_send(&m_nus, data_array3, &packetSize, m_conn_handle);
                      err_code = ble_nus_data_send(&m_nus, data_array4, &packetSize, m_conn_handle);
                      err_code = ble_nus_data_send(&m_nus, data_array5, &packetSize, m_conn_handle);
                      err_code = ble_nus_data_send(&m_nus, data_array6, &packetSize, m_conn_handle);
                      err_code = ble_nus_data_send(&m_nus, data_array7, &packetSize, m_conn_handle);
                      err_code = ble_nus_data_send(&m_nus, data_array8, &packetSize, m_conn_handle);
        case APP_UART_FIFO_ERROR:
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
    typedef enum{
      AP_SSID,
      AP_PWD
    }ble_msgs;
    bool ble_tx_enable = true;
        uint16_t length;
        static char data_array[40];
        static char temp_data_array[40];
        static uint8_t index = 0;
        char ap_ssid[40];
        char ap_pwd[40];
            uint32_t err_code;
            NRF_LOG_INFO("Received data from BLE NUS. Writing data on UART.");
            NRF_LOG_HEXDUMP_DEBUG(data_array, p_evt->params.rx_data.length);
            switch(p_evt->params.rx_data.p_data[0])
              case AP_SSID:
                index = 0;
                while(p_evt->params.rx_data.p_data[index] != 0x3F)
                  app_uart_put(p_evt->params.rx_data.p_data[index]);
                  index++;
                app_uart_put(0x0A);
              case AP_PWD:
                index = 0;
                  index++;
                app_uart_put(0x0A);
     *          application about an error.
     * @param[in]   nrf_error   Error code containing information about what went wrong.
        APP_ERROR_HANDLER(nrf_error);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
     * @param[in] p_evt  Event received from the Connection Parameters Module.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        uint32_t               err_code;
        cp_init.p_conn_params                  = NULL;
        cp_init.next_conn_params_update_delay  = NEXT_CONN_PARAMS_UPDATE_DELAY;
        cp_init.max_conn_params_update_count   = MAX_CONN_PARAMS_UPDATE_COUNT;
        cp_init.start_on_notify_cccd_handle    = BLE_GATT_HANDLE_INVALID;
        cp_init.disconnect_on_fail             = false;
        cp_init.evt_handler                    = on_conn_params_evt;
        cp_init.error_handler                  = conn_params_error_handler;
     * @param[in] ble_adv_evt  Advertising event.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING); // blink LED for 1 second duration
            case BLE_ADV_EVT_IDLE:
                //sleep_mode_enter();
     * @param[in]   p_ble_evt   Bluetooth stack event.
     * @param[in]   p_context   Unused.
        uint32_t err_code;
        ble_gatts_rw_authorize_reply_params_t auth_reply;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("New Device is Connected");
                //on_connected(BLE_GAP_EVT_CONNECTED);
                NRF_LOG_INFO("Device is Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
        uint32_t               err_code;
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance = true;  //false 10/19/2022
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; //Changed from GENERAL_DISC by MC 08/22/22
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_fast_enabled  = true;
        init.config.ble_adv_fast_timeout  = APP_ADV_DURATION;
    void send_data_BLE(uint16_t length, char * data_array)
        uint32_t err_code;
    //#endif
    /**@brief Function for initializing the Power Management.
      ret_code_t err_code = nrf_pwr_mgmt_init();
    /**@brief Function for initializing the BSP(LEDs).
    static void leds_init(void)
      ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
    //    err_code = app_timer_create(&tx_timer,
    //                                APP_TIMER_MODE_REPEATED,
    //                                send_message);
    /** @brief Function starting the internal LFCLK XTAL oscillator.
    static void lfclk_config(void)
        ret_code_t err_code = nrf_drv_clock_init();
    static void log_init(void)
        cli_process();
       if ((m_conn_handle != BLE_CONN_HANDLE_INVALID) && (index == 1))
          nus_data_handler(BLE_NUS_EVT_RX_DATA);
          index++;
    /**@brief Application main function.
        #if CONFIG_JLINK_MONITOR_ENABLED
        NVIC_SetPriority(DebugMonitor_IRQn, _PRIO_SD_LOW);
        nrf_delay_ms(1000);
        lfclk_config();
        //********* Initialize.***************
        log_init();
        // Initialize the app scheduler and the app timer.
        APP_SCHED_INIT(APP_SCHED_MAX_EVENT_SIZE, APP_SCHED_QUEUE_SIZE);
        timers_init();
        leds_init();
    //#ifdef USE_BLE
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
    //#endif
        cli_init();
        init_System();
        const version_t * const p_version = version_get();
        NRF_LOG_INFO("Firmware version: " VERSION_FORMAT,
                        p_version->major,
                        p_version->minor,
                        p_version->build);
       // app_timer_start(tx_timer, NOTIFICATION_INTERVAL, NULL);
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;) {
          idle_state_handle();
  • I think I may have solved it by adding in the index++
    to
          index++;
    I am just not sure how "good" of a solution it is. It only send the data once then waits for a response
