SPI Slave NRF5340 Init Error
Hi all!
SPI3 Slave project is not built - error:
identifier "__device_dts_ord_DT_N_S_soc_S_peripheral_50000000_S_spi_c000_P_cs_gpios_IDX_0_PH_ORD" not determined
C:\ncs\v2.1.1\zephyr\include\zephyr\drivers\pinctrl.h:89:10: error: 'PINCTRL_STATE_DT_N_S_soc_S_peripheral_50000000_S_spi_c000_PINCTRL_IDX_0_UPPER_TOKEN' undeclared here (not in a function); did you mean 'DT_N_S_soc_S_peripheral_50000000_S_spi_b000_PINCTRL_IDX_0_UPPER_TOKEN'?
What could be?
I ask for the help of a specialist.
  • Are you working on some sample? Would you be able to share your project?
     * app_spi3_s.c
    #include <zephyr/zephyr.h>
    #include <zephyr/drivers/spi.h>
    #include "app_spi3_s.h"
    /* Devicetree node corresponding to the peripheral to be used via Zephyr SPI
     * driver (SPIS3), in the background transfer.
    #define SPI_DEV_NODE DT_NODELABEL( spi3 )
    const struct device *spi3_s_dev = DEVICE_DT_GET( SPI_DEV_NODE );
    static const struct spi_config spi3_s_dev_cfg = {
            .operation = SPI_OP_MODE_SLAVE |
                         SPI_WORD_SET(8) |
                         SPI_TRANSFER_MSB |
                         SPI_MODE_CPOL |
                         SPI_MODE_CPHA,
            .frequency = 500000,
            .slave = 1
    //      .cs = &spi3_s_dev_cs_ctrl ???
    // Signal ------------------------------------------------------------------
    static struct k_poll_signal spi3_s_done_sig = K_POLL_SIGNAL_INITIALIZER( spi3_s_done_sig );
    // Value -------------------------------------------------------------------
    static struct spi_buf       tx_buf;
    static struct spi_buf_set   tx;
    static struct spi_buf       rx_buf;
    static struct spi_buf_set   rx;
    // SPI Slave **************************************************************
    // SPI Slave Init func ----------------------------------------------------
    uint8_t spi3_s_init( void )
        if( !device_is_ready( spi3_s_dev ) )
            return ERR_INIT_N_RDY;
        return ERR_INIT_NO;
    uint8_t spi3_s_transfer( uint8_t *tx_buffer, uint8_t *rx_buffer, uint16_t num_transfer )
        int ret;
    //  printk( "-- Background transfer on \"%s\" --\n", spi3_s_dev->name );
        tx_buf.buf = (void*)tx_buffer;
        tx_buf.len = num_transfer;
        tx.buffers = &tx_buf;
        tx.count = 1;
        rx_buf.buf = (void*)rx_buffer;
        rx_buf.len = num_transfer;
        rx.buffers = &rx_buf;
        rx.count = 1;
        // Reset signal
        k_poll_signal_reset( &spi3_s_done_sig );
        // Start transaction
        ret = spi_transceive_async( spi3_s_dev, &spi3_s_dev_cfg, &tx, &rx, &spi3_s_done_sig );
        if( ret < 0 )
    //      printk( "Background transfer failed: %d\n", ret );
            return TRANSFER_ERR;
        return TRANSFER_RUN;
    uint8_t spi3_s_check_transfer( void )
        unsigned int signaled;
        int          result;
        k_poll_signal_check( &spi3_s_done_sig, &signaled, &result );
        if( signaled )
            return TRANSFER_OK;
     * app_spi3_s.h
    #ifndef _APP_SPI3_S_
    #define _APP_SPI3_S_
    #include <stdint.h>
    // Define ------------------------------------------------------------------
    #define ERR_INIT_NO     0
    #define ERR_INIT_N_RDY  1
    #define TRANSFER_OK     0
    #define TRANSFER_ERR    1
    #define TRANSFER_RUN    2
    // Prototype ---------------------------------------------------------------
    uint8_t spi3_s_init( void );
    uint8_t spi3_s_transfer( uint8_t *tx_buffer, uint8_t *rx_buffer, uint16_t num_transfer );
    uint8_t spi3_s_check_transfer( void );
    #endif  // _APP_SPI3_S_
    nrf5340dk_nrf5340_cpuapp.overlay
    &pinctrl {
        spi3_default: spi3_default {
            group1 {
                psels = <NRF_PSEL(SPIS_SCK, 1, 5)>,
                        <NRF_PSEL(SPIS_MOSI, 1, 4)>,
                        <NRF_PSEL(SPIS_MISO, 1, 1)>,
                        <NRF_PSEL(SPIS_CSN, 1, 0)>;
        spi3_sleep: spi3_sleep {
            group1 {
                low-power-enable;
    /* SPI3 for slave mode
    &spi3 {
        compatible = "nordic,nrf-spis";
        status = "okay";
        pinctrl-0 = <&spi3_default>;
        pinctrl-1 = <&spi3_sleep>;
        def-char = <0x00>;
    prj.conf
    # This is needed for using another SPIM instance via the Zephyr SPI driver.
    CONFIG_SPI=y
    CONFIG_SPI_ASYNC=y
    CONFIG_SPI_SLAVE=y
    CONFIG_MAIN_STACK_SIZE=4096
  • Thank you for posting the files. Would you also be able to share relevant code from main?
  • thanks, why not
    #define     SPI3_S_TRANSFER_SIZE    128
    uint8_t     spi3_s_tx_buff[SPI3_S_TRANSFER_SIZE];
    uint8_t     spi3_s_rx_buff[SPI3_S_TRANSFER_SIZE];
    uint16_t    spi3_s_tx_rx_cnt = SPI3_S_TRANSFER_SIZE;
    // Main
    void main( void )
      int     i;
      app_leds_init();
      if( !spi3_s_init() )
          printk( "SPI3S is not ready\n" );
          while( 1 )
                app_led3_on();
                k_msleep( 600 );
                app_led3_off();
                k_msleep( 600 );
        // Init buffers
        for( i = 0; i < SPI3_S_TRANSFER_SIZE; i++ )
            spi3_s_rx_buff[i] = 0;
            spi3_s_tx_buff[i] = i;
        // SPI Slave transfer Start --------------------------------------------
        spi3_s_transfer( spi3_s_tx_buff, spi3_s_rx_buff, spi3_s_tx_rx_cnt );
        while( 1 )
            // Test SPI Slave Transfer -----------------------------------------
            if( spi3_s_check_transfer() == TRANSFER_OK )
              app_led1_on();
                spi3_s_tx_buff[0]++;
                for( i = 1; i < SPI3_S_TRANSFER_SIZE; i++ )
                // SPI Slave transfer Restart ----------------------------------
              app_led1_off();
  • Thank you for sharing the files.
    It looks like you need to add the following line:
    to your overlay, like below.
     &spi3 {
        status = "okay";
        def-char = <0x00>;
