ncs 2.1.0: BLE Stacks Overrun when code built for debug with CONFIG_NO_OPTIMIZATIONS=y
When building my BLE application for debug, the BLE stacks overflow and crash the firmware.  Note that this happens every release of ncs.  Would be great to have the stacks setup properly when full debug is built.  Or AT LEAST make all the stacks configurable by users so we don't have to change the ncs sources.
Here is how I config for debug:
CONFIG_DEBUG=y
CONFIG_DEBUG_INFO=y
CONFIG_DEBUG_THREAD_INFO=y
CONFIG_EXTRA_EXCEPTION_INFO=y
CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT=y
CONFIG_BT_HCI_TX_STACK_SIZE=4096
CONFIG_BT_RX_STACK_SIZE=4096
# CONFIG_BT_CTLR_ECDH_STACK_SIZE=4096 # Can't be set...
# CONFIG_BT_LONG_WQ_STACK_SIZE=4096 # Can't be set...
Here are some of the BLE stacks that can't be changed via CONFIG so I had to modify ncs:
% cd nrf
% git diff
diff --git a/subsys/bluetooth/controller/Kconfig b/subsys/bluetooth/controller/Kconfig
index edbfdedf4..18efb2991 100644
--- a/subsys/bluetooth/controller/Kconfig
+++ b/subsys/bluetooth/controller/Kconfig
@@ -168,7 +168,7 @@ config BT_CTLR_SDC_RX_PRIO
config BT_CTLR_SDC_RX_STACK_SIZE
int "Size of the receive thread stack"
- default 1024
+ default 4096 # 1024
help
Size of the receiving thread stack, used to retrieve HCI events and
data from the controller.
@@ -248,8 +248,8 @@ endchoice
config BT_CTLR_ECDH_STACK_SIZE
int
- default 900 if BT_CTLR_ECDH_LIB_OBERON
- default 1200 if BT_CTLR_ECDH_LIB_TINYCRYPT
+ default 4096 if BT_CTLR_ECDH_LIB_OBERON # 900
+ default 4096 if BT_CTLR_ECDH_LIB_TINYCRYPT # 1200
help
Size of the ECDH processing thread stack.
% cd ../zephyr
% git diff
diff --git a/subsys/bluetooth/host/Kconfig b/subsys/bluetooth/host/Kconfig
index 86b128b1f9..6319fdc40c 100644
--- a/subsys/bluetooth/host/Kconfig
+++ b/subsys/bluetooth/host/Kconfig
@@ -15,9 +15,9 @@ config BT_LONG_WQ_STACK_SIZE
# Hidden: Long workqueue stack size. Should be derived from system
# requirements.
int
- default 1300 if BT_GATT_CACHING
- default 1140 if BT_TINYCRYPT_ECC
- default 1024
+ default 1300 if BT_GATT_CACHING # 4096
+ default 1140 if BT_TINYCRYPT_ECC # 4096
+ default 1024 # 4096
config BT_LONG_WQ_PRIO
int "Long workqueue priority. Should be pre-emptible."
