Where to get "nrfx_rtc_t const *p_instance" for nrfx_rtc_init()
I could not find a way, where I can get the nrfx_rtc_t const *p_instance for the nrfx_rtc_init function. There is no example where it is shown where to get this struct from.
  • Ok I changed all above as you mentioned. I did not get any Repsonse from the RTC.
    static void rtc_handler(nrfx_rtc_int_type_t int_type) {
    	LOG_INF("%s","Intr");
       	set_intr_src(0x05);
    static void rtc_config(void) {
    	const nrfx_rtc_t rtc = NRFX_RTC_INSTANCE(RTC_INSTANCE_NUMBER);
    	uint32_t err_code;
    	//Initialize RTC instance
    	nrfx_rtc_config_t rtc_config;
    	rtc_config.prescaler = RTC_FREQ_TO_PRESCALER(10);
    	err_code = nrfx_rtc_init(&rtc, &rtc_config, rtc_handler);
    	LOG_INF("ErrorCode: %d",err_code);
    	err_code = nrfx_rtc_cc_set(&rtc,0,100,true);
    	//Power on RTC instance
    	nrfx_rtc_enable(&rtc);
    Is this code OK so far? I set the prescaler to 10 Hz and ah the cc to 100 so in my world it should trigger every 10 Sek. and should then print out the log message from rtc_handler()
    The return-statments from the rtc configuration are both ok
    Any Idea?
