Not able to set model publication state after reboot in sensor server model
I am using nrf sdk for mesh v5.0.0 and we are building our application on top of sensor_server example. I am provisioning the nrf52832(which is acting as sensor server) using an ESP32, which is acting as a provisioner. And I am also able to set the model publication state after provisioning how many ever times I do it. But when I reboot the sensor server node, I am not able to set the model publication state even once and a timeout occurs in the provisioner side which sets the model publication state using a configuration client model. What am I missing here? Any help on this would be great. Thanks
  • I am not facing any issue with the nrf mesh app!! With the nrf mesh app! Its working perfectly as expected! Even the model configuration.
    I am facing an issue in periodic publishing of data. When I try to set the publish period in nrf devices as 5 seconds using ESP32 as my provisioner, the server node publishes data within 3 seconds. If I set it as 10 seconds, its publishing data in 7 seconds. But am not facing this issue when I try to do the same using nrf mesh app. Setting a publish period should be the same across all devices regardless of which microcontroller I am using right?
    I am following the ble mesh documentation in order to set the model publication state.
  • Hi.
    Thanks. I think I was a little confused about what the real issue was.
    Well. Then we can safely assume that the problem lies with the provisioner.
    Could you add some more information about the provisioner you are using? Have you developed this using our Mesh SDK? If yes, I strongly suggest that you take a look at the provisioner example we have in the SDK and how it's done there.
    Yes, you should be able to provision and configure the device as long as your provisioner is following the specification.
    Br,
    Joakim
  • I misread the endianness in the mesh specification. I assumed it to be big endianness but it should have been in little endian. Now I am able to set the desired publish period
  • Glad to hear that you figured it out!
    Thanks for sharing the solution.
    Br,
    Joakim
