Problems with using the nRF Connect SDK v2.1.2 after upgrading from nRF Connect SDK v.2.0.0 and after having deleted (on my PC) the directory that was created for nRF Connect v2.0.0
I successfully completed all exercises from DevAcademy using nRF Connect SDK v2.0.0 and nRF Connect SDK v2.1.1.
However, when I tried to experiment with DevAcademy Lesson 8: Simple Tracker - I run into difficulties.
Suspecting that I might need to use the latest nRF Connect SDK v2.1.2 , I did install this nRF Connect SDK v2.1.2 and I did delete (on my PC) the folder that was created for nRF Connect SDK v2.0.0., namely C:\Nordic-20\.
But since that time, while I am able to open the VS Code from nRF Connect SDK v2.1.1 and from nRF Connect SDK v2.1.2  - I can see the following error messages (copy attached):
OUTPUT:
2022/11/10, [20:29:29] Unable to resolve configuration with compiler Path: "C:\Nordic-20\toolchain\v2.0.0\Zephyr-SDK\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe"
As I mentioned above, I did delete (on my PC) the folder "C:\Nordic-20\" after installing on my PC the nRF Connect SDK v2.1.2 in the folder c:\Nordic-212\.
And when I try to: "Add Build Configuration", to one of the applications already listed under Applications, I see the following message below the "Board" field:
"No board found" - as can be seen from the attached screenshot.
How can this problem be overcome, so that I could use the nRF Connect SDK v2.1.1 or v2.1.2 to: "Add Build Configuration" to the existing apps without being told that: "No Board found".
Screenshot 10-November-2022.docx
  • Ok I figured out what is causing the "SDK is inferred" message.
    You have a workspace opened in the file explorer tab in VS Code.
    You can only use one SDK per workspace.
    So if you want to use another SDK, you must make a new folder to build applications in (Application location), which you must open in VS Code (File > Open Folder) to make it the active workspace.
    You will then be able to choose another SDK in the New Application window.
    Hope this helps.
    -Einar
    I did follow your advice and I did create a new folder to build applications in, which I opened in VS Code (File>Open Folder) to make it the active workspace - and it worked !
    Problem solved. Thanks for your assistance.
    JM
    It's me again. After having successfully created a build of the sample "blinky" and then successfully created a build of the sample: "Bluetooth: Peripheral UART" , I tried to create and build another application/sample, namely: "Bluetooth: Multiple advertising sets" that can be found under Samples/Bluetooth/multiple_adv_sets  in the nRF SDK folder structure.
    But the build process was interrupred/terminated with the following error messages, highlighted in yellow:
    "fatal error:zephyr/dt-bindings/adc/adc.h: no such file or directory".
    7: #include<zephyr/dt-bindings/adc/adc.h>        Compilation terminated.
    CMake Error at: c:/Nordic-212_SDK/v2.1.2/zephyr/cmake/modules/dts.cmake: 189 (message)             "Command failed with return code:1"
    Since that time, I am unable to complete a build process of any sample, even of simple samples like: "blinky" or "at_client", as these error messages keep coming up and the build process gets interrupted.
    I attach a screenshot of these error messages, which came up when I tried to create a build for the sample "at_client".
    I also attach a screenshot of the "Quick Setup" page of nRF Connect for VS Code that shows the correct settings for the nRF Connect SDK and nRF Connect Tolchain.
    How can the problem of the error messages, highlighted in yellow, above, be resolved?
    Shall I open a new ticked for this problem or shall I keep discussing it with you?
    JM
    Error Messages 20-November-2022.docx
    Quick Setup Screen - 20-November-2022.docx
  • Hi
    I believe the sample you are building here isn't natively supported on the nRF9160 DK.
    From the error messages you are seeing, it looks like the build fails because the sample is trying to use a devicetree node that isn't present in the 9160 devicetree by default.
    But yes, I would say this is a new issue, so please open a new ticket.
    Einar.
