Extended Advertisement with Scan Response
Target: nrf52 dev kit
Soft device: s132_nrf52_7.2.0_softdevice.hex
SDK: nrf5 sdk 17.1.0
Environment: IAR
Example modified: ble_app_rscs
I am trying to modify the example to support extended advertisement with scan response.  In the following example init function if I set ble_adv_extended_enabled to false it will allow the advertising and scan response data sets.  If I set ble_adv_extended_enabled to true and remove the initialization of the scan response encoding, that will also run.
Please advise on the configuration to allow extended advertisement with scan response.
Thanks
    ret_code_t             err_code;
    ble_advertising_init_t init;
#define ADV_SIZE 60
//#define SR_SIZE 20
    ble_advdata_manuf_data_t 		  adv_manuf_data_config;
    uint8_t 		                  adv_manuf_data_data[ADV_SIZE] = {0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF,
        0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF};
    adv_manuf_data_config.data.size       = ADV_SIZE;
//    ble_advdata_manuf_data_t 		  adv_manuf_data_sr_config;
//    uint8_t 		                  adv_manuf_data_sr_data[SR_SIZE] = {0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF,0xDE,0xAD,0xBE,0xEF};
//    adv_manuf_data_config.data.size       = SR_SIZE;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
//    init.srdata.name_type = BLE_ADVDATA_NO_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.config.ble_adv_fast_enabled     = true;
    init.config.ble_adv_fast_interval    = APP_ADV_INTERVAL;
    init.config.ble_adv_fast_timeout     = APP_ADV_DURATION;
    init.config.ble_adv_primary_phy      = BLE_GAP_PHY_1MBPS;
    init.config.ble_adv_secondary_phy    = BLE_GAP_PHY_2MBPS;
    init.config.ble_adv_extended_enabled = true;
//    adv_manuf_data_sr_config.data.p_data        = adv_manuf_data_sr_data;
//    adv_manuf_data_sr_config.data.size          = sizeof(adv_manuf_data_sr_data);
    adv_manuf_data_config.data.p_data        = adv_manuf_data_data;
    adv_manuf_data_config.data.size          = sizeof(adv_manuf_data_data);
    init.advdata.p_manuf_specific_data     = &adv_manuf_data_config;
//    init.srdata.p_manuf_specific_data      = &adv_manuf_data_sr_config;
    m_advertising.adv_params.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_NONCONNECTABLE_SCANNABLE_UNDIRECTED;//BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED
    m_advertising.adv_params.interval = APP_ADV_INTERVAL;
    m_advertising.adv_params.duration = APP_ADV_DURATION;
//    m_advertising.adv_params.p_peer_addr     = NULL;
//    m_advertising.adv_params.duration        = BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED;
//    m_advertising.adv_params.interval      = 0x40;
//    m_advertising.adv_params.primary_phy   = BLE_GAP_PHY_AUTO;
//    m_advertising.adv_params.secondary_phy   = BLE_GAP_PHY_AUTO;
//    m_advertising.adv_params.set_id         = 4;
//    m_advertising.adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
     // Prepare the scan response manufacturer specific data packet
    ble_advdata_manuf_data_t  manuf_data_response;
    uint8_t                     data_response[4] = {0xDE,0xAD};
    manuf_data_response.data.p_data         = data_response;
    manuf_data_response.data.size           = sizeof(data_response);
    init.srdata.p_manuf_specific_data = &manuf_data_response;
    I see you already got an answer from my colleague Edvin in a private case. Copy-pasting the answer here in case it is useful for someone else.
    Bluetooth Core Specification Version 5.3 | Vol 4, Part E section 7.8.53: LE Set Extended Advertising Parameters command (page 2450 in the Bluetooth Core Specification Version 5.3):
    If extended advertising PDU types are being used (bit 4 = 0) then: The advertisement shall not be both connectable and scannable. High duty cycle directed connectable advertising (≤ 3.75 ms advertising interval) shall not be used (bit 3 = 0).
