QDEC sample code from zephyr is not running on nrf52840dk
I am using a rotary encoder with nrf52840dk and I am confused about how to run sample QDEC code from zephyr/sample/sensor/qdec on nrf52840dk.
I got this error when i tried to directly build the code for nrf52840
I tried to add an overlay file to add qdec0 in this project. It was compulsory to add reg and interrupts parameters.
    qdec0: qdec0{
        compatible="nordic,nrf-qdec";
        a-pin = <38>;
        b-pin = <39>;
        enable-pin = <32>;
        led-pin = <13>;
        led-pre = <0>;
        steps = <20>;
        reg = <0x000f8000 0x00008000>;
        interrupts = <&gpio0>;
    aliases {
        qdec0=&qdec;
 C
  • So I should modify the original nrf52840dk_nrf52840.dts file? I thought I should be using an overlay file to make configuration changes. Therefore I put everything in the file nrf52840dk_nrf52840.overlay which now has this content:
        aliases {
            qdec0=&qdec;
    &qdec {
        compatible = "nordic,nrf52840-dk-nrf52840";
        pinctrl-0 = <&qdec_default>;
        pinctrl-1 = <&qdec_sleep>;
        label = "qdec";
    &pinctrl {
        qdec_default: qdec_default {
            group1 {
                psels = <NRF_PSEL(QDEC_A, 0, 3)>,
                    <NRF_PSEL(QDEC_B, 0, 28)>;
        qdec_sleep: qdec_sleep {
            group1 {
                low-power-enable;
    &qdec {
        status = "okay";
        enable-pin = <30>;
        led-pre = <0>;
        steps = <24>;
    And this still produces the same error message '__device_dts_ord_DT_N_ALIAS_qdec_ORD' undeclared
    This does not mention qdec0, but qdec.
    In main.c the following line is used to get the device:
        const struct device *const dev = DEVICE_DT_GET(DT_ALIAS(qdec));
    Thank you BTW for your assistance; I am just starting with nrf/Zephyr development and this device tree configuration is quit confusing to me.
  • This does not mention qdec0, but qdec.
    Oh....Then just changing the value in aliases node from qdec0 to qdec should solve the problem
  • You have not any node called qdec0. Try to change this to ''qdec''.
  • That helped! The previous error is now gone.
    However, there is now a new error:
         undefined reference to `__device_dts_ord_101'
    I have just this minimal main.c:
    #include <device.h>
    #include <drivers/sensor.h>
    void main(void) {
        if (!device_is_ready(dev)) {
            printk("Qdec device is not ready\n");
            return;
  • Can you try to place this app.overlay file inside the sample folder (for example C:\NCS\v2.0.2\zephyr\samples\sensor\qdec) and run the sample?
     2043.app.overlay
