Getting started with blinky doesn't work
I followed all the steps from the website:
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/develop/getting_started/index.html
But I get the following error message:
~/zephyrproject/zephyr$ west build -p always -b nrf52840dk_nrf52840 samples/basic/blinky
-- west build: making build dir /home/ephimee/zephyrproject/zephyr/build pristine
Including boilerplate (Zephyr base): /home/ephimee/zephyrproject/zephyr/cmake/app/boilerplate.cmake
CMake Deprecation Warning at /home/ephimee/zephyrproject/zephyr/cmake/app/boilerplate.cmake:37 (cmake_policy):
The OLD behavior for policy CMP0079 will be removed from a future version
of CMake.
The cmake-policies(7) manual explains that the OLD behaviors of all
policies are deprecated and that a policy should be set to OLD only under
specific short-term circumstances. Projects should be ported to the NEW
behavior and not rely on setting a policy to OLD.
/home/ephimee/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
/home/ephimee/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
CMakeLists.txt:4 (find_package)
-- Application: /home/ephimee/zephyrproject/zephyr/samples/basic/blinky
-- Zephyr version: 2.4.99 (/home/ephimee/zephyrproject/zephyr)
-- Found Python3: /usr/bin/python3.8 (found suitable exact version "3.8.10") found components: Interpreter
-- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
-- Board: nrf52840dk_nrf52840
-- Cache files will be written to: /home/ephimee/.cache/zephyr
-- Found toolchain: zephyr (/home/ephimee/ncs_v2.0.2/toolchains/v2.0.2/opt/zephyr-sdk)
-- Found dtc: /usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found BOARD.dts: /home/ephimee/zephyrproject/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
CMake Error at /home/ephimee/zephyrproject/zephyr/cmake/extensions.cmake:1585 (file):
file failed to open for reading (No such file or directory):
/home/ephimee/zephyrproject/zephyr/build/zephyr/nrf52840dk_nrf52840.dts.pre.d
/home/ephimee/zephyrproject/zephyr/cmake/dts.cmake:162 (toolchain_parse_make_rule)
/home/ephimee/zephyrproject/zephyr/cmake/app/boilerplate.cmake:506 (include)
FATAL ERROR: Couldn't open "nrf52840dk_nrf52840.dts.pre.tmp": No such file or directory
CMake Error at /home/ephimee/zephyrproject/zephyr/cmake/dts.cmake:205 (message):
command failed with return code: 1
FATAL ERROR: command exited with status 1: /home/ephimee/.local/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/home/ephimee/zephyrproject/zephyr/build -S/home/ephimee/zephyrproject/zephyr/samples/basic/blinky -GNinja -DBOARD=nrf52840dk_nrf52840
  • Yes, you are right. I'm using NCS 1.6.1 with Nordic Segger.
    Because NCS 1.6.1 will be phased out in the future, I'm already preparing for NCS 2.x
    So basically I want to run both versions because I want to develop new things on NCS 2x while maintaining the older versions on NCS 1.6.1
    Is there a way to setup the environment for a specific NCS version? So I can go back and forth?
    Aha, the mismatch makes sense then.
    It is possible to have several instances of NCS installed. But you need to make sure that all the environment variables are set to the version you are using for each session.
    Note that you do not have NCS v2.0.2 installed by following the guide you linked in your original ticket. To install NCS v2.0.2, follow this guide.
    I do not know how SEGGER Embedded Studio (SES) sets up the building environment and if it is compatible with another version of NCS being installed. Let me know if you want to continue to use SES for NCS v1.6.1 and I can find out what to consider when having multiple versions of NCS installed.
    A configuration that should work is to build from the command line. To use switch between the versions you can run the zephyr-env.sh script before building with the version you choose. Instructions are found here. The script is within <ncs-installation>/zephyr.
    I have not tested this configuration yet, but I can do so after the weekend.
    An extra bit of information about NCS v1.6.1 and v2.0.2 is that they use different toolchains. v1.6.1 uses GNU Arm Embedded toolchain, while v2.0.2 uses Zephyr SDK toolchain. The switch was made with the release of NCS 2.0.0.
    BR,
    Maria
  • It is possible to have several instances of NCS installed. But you need to make sure that all the environment variables are set to the version you are using for each session.
    Can you tell me which environment settings I need to set including value?
    It's a long time ago I installed SES with NCS 1.6.1, but I use it daily and is necessary to support the code base until we've completely moved to NCS2 so yes I still need it.
    I ran the script zephyr/zephyr-env.sh before west build, and it compiles. And with west flash I was able to load it onto the DK board.
    Sorry for the delay. I had a few days off.
    The following is the case for setting up the environment variables for building with the command line.
    In both versions of NCS you need ZEPHYR_BASE=<path to ncs-version>.
    For NCS v1.6.1, you need
    ZEPHYR_TOOLCHAIN_VARIANT="gnuarmemb"
    GNUARMEMB_TOOLCHAIN_PATH=<path to installation of toolchain>
    For NCS v2.0.2 you need
    ZEPHYR_TOOLCHAIN_VARIANT="zephyr"
    You can either set these variables when switching between the versions, or make a script for setting them for ease of use.
    use export <VARIABLE_NAME>=value to set the variables.
    Ok, thank you for clarifying. Setting up the environment variables in SES is done by following the instructions here.
    Starting with NCS v2.0.0 SES is no longer supported as an IDE. The recommended IDE for NCS v2.x.y is VS Code and using the nRF Connect for VS Code Extension.
    Ok, good that you were able to build and flash. When building, make sure to pay attention to the toolchain variant and the Zephyr version when building. When building with NCS v1.6.1, the Zephyr version should be 2.6.0-rc1 and the toolchain found should be gnuarmemb. When building with NCS v2.0.2, the Zephyr version should be 3.0.99 and the toolchain found should be zephyr 0.14.1.
    Kind Regards,
    Maria
  • Sorry for the late reply. My problem is solved with the following commands:
    cd $HOME/ncs2/v2.1.2/zephyr
    source zephyr-env.sh
