We are looking to use nRF5340 device in our new design. We need RTC (Real Time clock) feature with this design.
Does nRF5340 device support RTC (Real Time Clock). nRF5340 supports only Real Time counters.
Best Regards
Ishwar
Best Regards
Ishwar
You can add external pull up resistor if you want. However, according to design, it is not necessary. All our pin has internal 13Kohm. This actually can restore the signal to high when no device is asserting it low.
BR
Kazi
Thanks.
I have one more query as below.
What is the best way to configure unused GPIOs for minimum current consumption. This is our low power mode (Battery operated) application.
Please suggest configuration for unused GPIOs.
Best regards
Can you please update here on priority.
Best regards
You can set the unused pins as input with disconnected buffers (as GPIOs are configured as inputs with the input buffer disconnected on reset), they will not draw excessive current due to floating.
https://infocenter.nordicsemi.com/topic/ps_nrf52840/gpio.html?cp=4_0_0_5_8_1_9#register.PIN_CNF-0-31.
Thanks.
Best Regards
Kazi
Please see my below queries:
1. There are different option given for RF signal (ANT) connection with Antenna. What should be the matching circuit. Is there any calculation for this. We need to use SR4W035 Antenna (2.4 GHz) with NRF52840-QIAA-R device.
2. Do we need to populate series resistors and capacitors to Ground for I2C signals.
3. Should we go with High drive 0 and High drive 1 if the GPIO (output) is used with connector/Cable.
Best regards
