nrf5340 is unable to trigger rpmsg(ipc) transfer
I have quite demanding SPI device which should send its data over BLE.
Thanks to throughput example i was able to achieve maximum transfer speeds for synthetic tests (without SPI).
Sadly after adding real data input, I noticed that no transfer is executed until I finish my commands.
Thanks to SystemView I was able to narrow this problem to one part of configuration -> rpmsg.
flow
Colors:
Green -> spi thread
Yellow -> bt_hci thread
Orange -> ble host TX
Red (small squere in top) - IRQ 58 from probably ipc, but i wasnt able to find it in manual (not listed)
Blue - probably openAmp mailing work queue thread
purple - systemwork queue
SystemView Data Log
4010.BleProblem.dat
Here is repo with configs etc.
https://github.com/DuMaM/bitly_nrf5x
  • Dumam said:
    The problematic code do the same but gets data from SPI.
    Can you please show me how you do that?
    In case I have follow up questions, feel free to zip and upload the entire project here (just drag and drop into the window where you are typing).
  • My repo is public you can download or clone it without any issues.
    I also placed this in attachment.
    SPI Thread.
    More here: github.com/.../spi_adc.c
    void ads129x_set_data()
        /* add timestamp */
        tx_data.packet.timestamp = k_uptime_get() - timestamp;
        conv_u24_to_raw(tx_data.packet.timestamp, tx_data.buffer, 0);
        /* do processing */
        /* NOTE: Work directly on a ring buffer memory */
        int ret = spi_read(ads129x_spi, &ads129x_spi_cfg, &ads129x_rx);
        if (!ret)
            /* add missing leads */
            lead1 = conv_u24_to_i32(conv_raw_to_u24(tx_data.packet.leads._buffer, ADS129x_LEAD1_OFFSET));
            lead2 = conv_u24_to_i32(conv_raw_to_u24(tx_data.packet.leads._buffer, ADS129x_LEAD2_OFFSET));
            conv_u24_to_raw(ads129x_get_leadIII(lead1, lead2), tx_data.packet.leads._buffer, ADS129x_LEAD3_OFFSET);
            conv_u24_to_raw(ads129x_get_aVR(lead1, lead2), tx_data.packet.leads._buffer, ADS129x_AVR_OFFSET);
            conv_u24_to_raw(ads129x_get_aVL(lead1, lead2), tx_data.packet.leads._buffer, ADS129x_AVL_OFFSET);
            conv_u24_to_raw(ads129x_get_aVF(lead1, lead2), tx_data.packet.leads._buffer, ADS129x_AVF_OFFSET);
            //ads129x_dump_data(tx_data.packet.leads._buffer);
        /* send data to consumers */
        /* send data to the consumers */
        k_pipe_put(&ads129x_pipe, &tx_data.buffer, total_size, &bytes_written, sizeof(pipe_packet_u), K_NO_WAIT);
    void ads129x_th(void)
        /* setup ecg */
        ads129x_setup();
        for (;;)
             * Wait for semaphore from ISR; if acquired, do related work, then
             * go to next loop iteration (the semaphore might have been given
             * again); else, make the CPU idle.
            if (k_sem_take(&ads129x_new_data, K_FOREVER) == 0)
                ads129x_set_data();
    K_THREAD_DEFINE(thread_ads129x, STACKSIZE, ads129x_th, NULL, NULL, NULL, PRIORITY, K_ESSENTIAL, 0);
    BLE Thread:
    More here: https://github.com/DuMaM/bitly_nrf5x/blob/e6cf66e1655bf3da2c65d58fedb561893194ba80/src/app/cmd_run_adc.c#L104
    K_THREAD_STACK_DEFINE(ecg_ble_stack, 4096);
    struct k_thread ecg_ble_thread;
    static uint32_t bytes_to_send = 1024;
    static uint32_t send_test_ecg_data(uint32_t _bytes_to_send)
        uint32_t prog = 0;
        uint8_t *analog_data_ptr = test_data_buffer;
        uint32_t analog_data_size = 0;
        int err = 0;
         * we always waiting for data to match whole buffer
         * so data requested should also match it
         * otherwise we should ignore it
        uint16_t remainder = _bytes_to_send % ADS129x_DATA_BUFFER_SIZE;
        if (remainder) {
            _bytes_to_send = ((_bytes_to_send / ADS129x_DATA_BUFFER_SIZE) + 1) * ADS129x_DATA_BUFFER_SIZE;
        LOG_INF("Sending %"PRIu32" bytes (value after rounding to max packet size)", _bytes_to_send);
        while (prog < _bytes_to_send)
            analog_data_size = _bytes_to_send - prog;
            if (test_params.data_len->tx_max_len <= analog_data_size) {
                analog_data_size = test_params.data_len->tx_max_len;
             * TODO: add scaling from shell
             * It would be good to send optimal number of data
             * during each transfer
             * also when we change a number o leads
            if (!ads129x_get_data(analog_data_ptr, analog_data_size))
                continue;
            err = bt_performance_test_write(&performance_test, analog_data_ptr, analog_data_size);
            if (err)
                LOG_ERR("GATT write failed (err %d)", err);
            prog += analog_data_size;
        return prog;
    bitly_nrf5x-main.zip
  • Oh, my impression was that this was someone else's repository. I understand. I will have a look at it as soon as possible.
  •   I'm soo grateful for this. I'm trying to figure it out for 2 months without any luck. :(
  • Ok, I am trying to navigate your project. I am struggling to see exactly how it relates to the throughput sample. Where exactly are you sending the BLE packets. Can you please point to it? Where it sends, and how long are the packets that you are sending? There should be a call to bt_gatt_notify_cb() or bt_gatt_write() or something like that.
    You say that your throughput is much higher when you disable the SPI and just use dummy data. So the MTU and connection interval and everything else is the same, just that you wait for the SPI to finish?
    What is it that triggers send_test_ecg_data()?
    ads129x_get_data() only triggers a read from a buffer? No actual peripheral transferring data? When will it continue; and when will it send data (which I assume it does inside bt_performance_test_write(). And when bt_performance_test_write() is called, what is the length of the data that is being sent?
    Sorry, a lot of unstructured questions, but I was reading more and more into your project. So the question is, how often is send_test_ecg_data() called, and how often is bt_performance_test_write() called? Is bt_performance_test_write() called every time send_test_ecg_data() is called, or does it often skip it because of continue; ?
