nrfutil for ARM and other platform
Hello !
I can see nrfutil is written in python and have a lot of dependencies and functionalities what typically need for x86 based host.
A lot of discussions about porting of it to RPi and other platforms as it is.
For light distributions , DFU via serial port can cover 99% of use cases.
I mean usage nrfutil like this :
nrfutil -v dfu usb-serial -p /dev/ttyACM0 -b 115200 -pkg dfu.zip
Do you have other light sources or examples for nrfutil what can be easily used in simple systems ?
Or porting sources from main repo https://github.com/NordicSemiconductor/pc-nrfutil is only option for produce own light version of nrfutil ?
Eugene
  • Hi Hung Bui !
    Please clarify a bit.
    1.
    Let's take for example nRF52 dongle.
    I have used  precompiled bootloader graviton_bootloader_mbr_v1.0.1-\[nRF5_SDK_15.0.1-1.alpha_f76d012\].hex
    and update application only from  x86 Ubuntu due python based nrfutil.
    $ nrfutil -v dfu usb-serial -p /dev/ttyACM0 -b 115200 -pkg dfu.zip
    nrfutil version 6.1.7
    2. I can't change the application build method from SDK but can move to another bootloader
       if it can be easily compiled from known sources and support the booting of old application.
    So any bootloader and serial flasher ( without security ) is OK for me.
    3. Can nrfutil version > 7 ( new one ) is used for serial flash of old application, via old bootloader ?
      Does nrfutil > 7 available as source code and be easy portable to RPi ARM platform ?
    At list subset for serial flashing, application only, no security.
    4. if we look for the future, e.g. full migration to nRF Connect SDK ( for nRF52/nRF53) and use Rpi ARM platform for hosting utility for serial flashing.
    What kind of utility is available in the source code or has support Rpi ARM platform?
    At list for secure flash ( package creation is no need).
    5. Does nRF Connect SDK platform provide a bootloader and application creation that compatible with old nrfutil version < 7 ? May be it not suitable for an update of dual core nRF53 but nRF52 is OK for now.
    6. I can't tell if porting of nrfutil < 7  (legacy) is fully doable for Rpi due python.
    But may be possible to port only part what need for support serial flashing
    a lot of discussions about it But no clear evidence if some one is succeed .
    Eugene
  • Hi Eugene,
    2. I don't see any point why you want to change the bootloader. The old bootloader should still work fine. It's just we don't do more development with the old bootloader/SDK.
    3. Yes. By using the legacy nrf5sdk-tools.
    4. Currently I don't see any out of the box tool that works with RPi. We do have nRF Connect desktop app that can run on Linux. But I don't know if it works on RPi ARM.
    5. No.
    6. I would suggest to develop your own application based on what we have in nRFUtil and based on the DFU protocol that we provided. It's not too complex. You can find that in my example in the blog, it's pretty small.
  • Hi Hung Bui !
    1.
    I have tried to install nrfutil directly on Rpi like HW by using $ pip install nrfutil
    and finally it install  nrfutil version 5.2.0
    So looks like exists some unofficial ports of nrfutil like this
    https://arribada.org/horizon-gps-tracking/installing-nrf-util-on-raspberry-pi-os/
    Can it be some unofficial support of nrfutil for other platforms ?
    No idea if it good way to continue on my side.
    What do you think about those unofficial branches ?
    2. But in the common case, from the nordicsemi side, I should expect that only legacy nrfutil < 7 will be available in the source code and can be adapted for other platforms especially in cases when security needs,
    Is this so ?
    Or some newer tools can be available in sources for porting to other platforms ?
    Eugene
  • Hi Eugene,
    1. Unfortunately, we can't verify that. The biggest challenge we have is that we don't have the resource to run a full test of the software on different platform. And no further resource is allocated for the legacy nrfutil except for bug fix.
    2. I don't know about the plan on open sourcing nrfutil v7 and on ward. We will have a blog in about 1-2 month about the new nrfutil. However it wouldn't affect you as your solution is currently on nRF5 SDK. And the source code of legacy nrfutil will be kept available as it is now.
    If you plan, in the future, to migrate to nRF Connect SDK for DFU, there will be solution so that you can implement the DFU protocol on an embedded device. For example here.
