Hardfault with Zigbee initialisation when BLE SoftDevice is included.
Hello Nordic support,
I am working on an application that works either with BLE or Zigbee and the protocol to be used is determined at application startup. Initially, my application was only Zigbee based and was using RTOS for performing various operations. This is working as expected.
Now, I have added BLE support to this application and added the necessary macros. As mentioned in this link https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_tz_v4.2.0%2Fzigbee_multi_examples.html (point 6), I have initialised SoftDevice by calling the function  nrf_sdh_enable_request() in main.c and then call ZB_INIT() inside an RTOS task. However, while performing Zigbee initialisation, the program goes into hardfault.
Could you please let me know what could be the possible issue here?
Anusha
  • Hi Susheel,
    Ok,  this would be helpful so that I can understand if the issue is coming from my project or not.
  • Hi Susheel,
    While I was debugging my application when I enable SoftDevice, I noticed the following:
    When nrf_sdh_enable_request() is called, in this function, there is a call to sd_softdevice_enable() which is an SVC call. I noticed that this call transfers the program control to vPortSVCHandler() in port.c causing one of the RTOS task related to my application to start running and it looks like the softdevice_enable() never completed.
    I tried to see where the program control goes when sd_softdevice_enable() is called in one of the examples ble_app_hrs_freertos and in this I see that the program control goes to memory location 0xAA4 and starts executing some instructions and control comes back nrf_sdh_enable_request() after the instructions are executed. However, this does not happen in my case. So, I would like to understand the possible reason for the program control to go to vPortSVCHandler() when SVCALL is called for enabling the SoftDevice.
    Anusha
  • Hi Anusha,
    I verified enabling SYSTICK in ble_app_hrs_freertos project, disabling tickless idle mode.
    But I do not see any issues enabling the softdevice. I have disable app_timer_freertos in my project since it calls RTC.
    I have verified that the systick interrupt is being called now instead of rtc interrupt. It has to be something with your project that causes the issue you are seeing.
  • Hi Susheel,
    Thanks for checking this. The problem with Systick interrupt got solved. The issue was with function sd_softdevice_enable() not returning. My application had bootloader and application firmware with bootloader placed after soft device and then followed by application code. The issue was resolved by moving the application code after the soft device. However, now i am facing another issue with zigbee initialization not working. I see that when zigbee_init() is called, the program gets stuck on calling zb_mac_transport_init().This seems like not an issue with this thread. Let me know if i should raise a new case.
    Please create a new ticket for it as the issue with the original title seems solved.
