nrf9160 has a compilation error
Hi:
After downloading the sdk, I installed the compilation environment on my laptop and successfully compiled the at_client project. However, after the same installation steps and compilation of the at_client project on my desktop computer, the following screenshot of the compilation error did appear.
Please help me see how to resolve this compilation error;
This is the configuration on the computer side;
regard
owen
  • Hi Marte:
    This is the log of the entire compilation process, please check.
     *  正在执行任务: nRF Connect: Generate config nrf9160dk_nrf9160_ns for d:\Nordic\ncs_v2.1.0\ncs2.1.0\v2.1.0\nrf\samples\nrf9160\at_client
    Building at_client
    west build --build-dir d:\Nordic\ncs_v2.1.0\ncs2.1.0\v2.1.0\nrf\samples\nrf9160\at_client\build d:\Nordic\ncs_v2.1.0\ncs2.1.0\v2.1.0\nrf\samples\nrf9160\at_client --pristine --board nrf9160dk_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE"
    -- Application: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/samples/nrf9160/at_client
    -- Found Python3: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/toolchains/v2.1.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/zephyr/.cache
    -- Zephyr version: 3.1.99 (D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/zephyr)
    -- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
    -- Found host-tools: zephyr 0.14.1 (D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/toolchains/v2.1.0/opt/zephyr-sdk)
    -- Found dtc: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/toolchains/v2.1.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: zephyr 0.14.1 (D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/toolchains/v2.1.0/opt/zephyr-sdk)
    -- Found BOARD.dts: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
    -- Generated zephyr.dts: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/samples/nrf9160/at_client/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/samples/nrf9160/at_client/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/samples/nrf9160/at_client/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/samples/nrf9160/at_client/build/zephyr/dts.cmake
    Parsing D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/zephyr/Kconfig
    Loaded configuration 'D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
    Merged configuration 'D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/samples/nrf9160/at_client/prj.conf'
    Configuration saved to 'D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/samples/nrf9160/at_client/build/zephyr/.config'
    Kconfig header saved to 'D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/samples/nrf9160/at_client/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 10.3.0
    -- The CXX compiler identification is GNU 10.3.0
    -- Found assembler: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/toolchains/v2.1.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    CMake Warning at D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/zephyr/CMakeLists.txt:1839 (message):
    Dropping partition 'nrf_modem_lib_trace' since its size is 0.
    Dropping partition 'nonsecure_storage' since it is empty.
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/samples/nrf9160/at_client/build
    [1/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ripemd160.c.obj
    [2/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/md5.c.obj
    [3/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/chachapoly.c.obj
    [4/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/sha1.c.obj
    [5/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/aria.c.obj
    [6/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/aesni.c.obj
    [7/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/des.c.obj
    [8/253] Generating include/generated/version.h
    -- Zephyr version: 3.1.99 (D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/zephyr), build: v3.1.99-ncs1
    [9/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ecdh.c.obj
    [10/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ecdsa.c.obj
    [11/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ecp_curves.c.obj
    [12/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ecp.c.obj
    [13/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/camellia.c.obj
    [14/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/gcm.c.obj
    [15/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/cmac.c.obj
    [16/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ctr_drbg.c.obj
    [17/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ccm.c.obj
    [18/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/sha256.c.obj
    [19/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/hkdf.c.obj
    [20/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/entropy.c.obj
    [21/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
    [22/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/hmac_drbg.c.obj
    [23/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pk_wrap.c.obj
    [24/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pk.c.obj
    [25/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/padlock.c.obj
    [26/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
    [27/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/nist_kw.c.obj
    [28/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/platform.c.obj
    [29/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/rsa_alt_helpers.c.obj
    [30/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/cipher_wrap.c.obj
    [31/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/base64.c.obj
    [32/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/sha512.c.obj
    [33/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
    [34/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pkparse.c.obj
    [35/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/asn1parse.c.obj
    [36/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/md.c.obj
    [37/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pkcs12.c.obj
    [38/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/version.c.obj
    [39/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pkwrite.c.obj
    [40/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/oid.c.obj
    [41/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/asn1write.c.obj
    [42/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/constant_time.c.obj
    [43/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/platform_util.c.obj
    [44/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/dhm.c.obj
    [45/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pem.c.obj
    [46/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pkcs5.c.obj
    [47/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/cipher.c.obj
    [48/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/rsa.c.obj
    [49/253] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [50/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/bignum.c.obj
    [51/253] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto_base.a
    [52/253] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
    [53/253] Generating include/generated/driver-validation.h
    [54/253] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [55/253] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [56/253] Generating ../../tfm/CMakeCache.txt
    -- Found Python3: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/toolchains/v2.1.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/samples/nrf9160/at_client/build/tfm
    [57/253] Creating directories for 'tfm'
    [58/253] No download step for 'tfm'
    [59/253] No update step for 'tfm'
    [60/253] No patch step for 'tfm'
    [61/253] No configure step for 'tfm'
    [61/253] Performing build step for 'tfm'
    [1/2] Generating ../generated/secure_fw/spm/cmsis_func/tfm_spm_db_func.inc, ../generated/secure_fw/spm/cmsis_func/tfm_veneers.c, ../generated/interface/include/tfm_veneers.h, ../generated/secure_fw/spm/cmsis_func/tfm_secure_irq_handlers.inc, ../generated/interface/include/psa_manifest/sid.h, ../generated/interface/include/psa_manifest/pid.h, ../generated/interface/include/config_impl.h, ../generated/tools/config_impl.cmake
    [1/2] Re-running CMake...
    -- Configuring done
    -- Generating done
    [1/169] Building C object lib/fih/CMakeFiles/tfm_fih_implementation.dir/src/fih.o
    [2/169] Linking C static library lib\fih\libtfm_fih_implementation.a
    [3/169] Generating liboberon_mbedcrypto__psa_3.0.12.a
    [4/169] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/faults.o
    [5/169] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [6/169] Building ASM object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/nrf9160/gcc/startup_nrf9160_s.o
    [7/169] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [8/169] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/tfm_psa_api_veneers.o
    [9/169] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [10/169] Building C object secure_fw/CMakeFiles/tfm_s.dir/spm/cmsis_psa/psa_interface_cross.o
    [11/169] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [12/169] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/idle_partition/load_info_idle_sp.o
    [13/169] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/interface/src/tfm_psa_call_pack.o
    [14/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/utilities.o
    [15/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch.o
    [16/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_boot_data.o
    [17/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_core_utils.o
    [18/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/psa_api.o
    [19/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/static_load.o
    [20/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/backend_ipc.o
    [21/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_cross_call.o
    [22/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/main.o
    [23/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_ipc.o
    [24/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_core_svcalls_ipc.o
    [25/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_pools.o
    [26/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ns_client_ext/tfm_spm_ns_ctx.o
    [27/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch_v8m_main.o
    [28/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/thread.o
    [29/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/interrupt.o
    [30/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [31/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/ns_agent_tz.o
    [32/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/interface/src/tfm_psa_call_pack.o
    [33/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [34/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [35/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/idle_partition.o
    [36/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/psa_interface_cross.o
    [37/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/load_info_idle_sp.o
    [38/169] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [39/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcmp.o
    [40/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memmove.o
    [41/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_strnlen.o
    [42/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/service_api.o
    [43/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memset.o
    [44/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcpy.o
    [45/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_partition_metadata_indicator.o
    [46/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [47/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/platform/tfm_platform_secure_api.o
    [48/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/crypto/tfm_crypto_secure_api.o
    [49/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sfn_common_thread.o
    [50/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_main.o
    [51/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_psa_call_pack.o
    [52/169] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/spm/cmsis_psa/psa_interface_cross.o
    [53/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o
    [54/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o
    [55/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o
    [56/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o
    [57/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o
    [58/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key.o
    [59/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o
    [60/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o
    [61/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o
    [62/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_management.o
    [63/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o
    [64/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o
    [65/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/spm/cmsis_psa/psa_interface_cross.o
    [66/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [67/169] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [68/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/memory_buffer_alloc.o
    [69/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/psa_crypto_ecp.o
    [70/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/psa_crypto_cipher.o
    [71/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/psa_crypto_aead.o
    [72/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/psa_crypto_client.o
    [73/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/psa_crypto.o
    [74/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/psa_crypto_hash.o
    [75/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/psa_crypto_driver_wrappers.o
    [76/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/random_ext.o
    [77/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/psa_crypto_rsa.o
    [78/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/psa_crypto_storage.o
    [79/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/d5dc39c65d42db98dc165d6902aef706/library/psa_crypto_slot_management.o
    [80/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/psa_crypto_mac.o
    [81/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pem.o
    [82/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pkwrite.o
    [83/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/dhm.o
    [84/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pkcs12.o
    [85/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/cipher.o
    [86/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pkcs5.o
    [87/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pkparse.o
    [88/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pk_wrap.o
    [89/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/pk.o
    [90/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/sha256.o
    [91/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/cipher_wrap.o
    [92/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/md.o
    [93/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/sha1.o
    [94/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/md5.o
    [95/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/aria.o
    [96/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/camellia.o
    [97/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/aesni.o
    [98/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/sha512.o
    [99/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ripemd160.o
    [100/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ecdsa.o
    [101/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ecp.o
    [102/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ccm.o
    [103/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ecdh.o
    [104/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/chachapoly.o
    [105/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/des.o
    [106/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/cmac.o
    [107/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/hmac_drbg.o
    [108/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/rsa_alt_helpers.o
    [109/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/hkdf.o
    [110/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/rsa.o
    [111/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/ecp_curves.o
    [112/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/gcm.o
    [113/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/ecjpake_oberon.o
    [114/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/asn1parse.o
    [115/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes.o
    [116/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes_oberon.o
    [117/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/611c7bc5855df0756b05a2bcb1e00e54/target/nordic_nrf/common/core/plat_test.o
    [118/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/nist_kw.o
    [119/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/bignum.o
    [120/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/base64.o
    [121/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/padlock.o
    [122/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/oid.o
    [123/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/asn1write.o
    [124/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/platform_util.o
    [125/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/platform.o
    [126/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/constant_time.o
    [127/169] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/version.o
    [128/169] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libmbedcrypto_base.a
    [129/169] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o
    [130/169] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [131/169] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/spm/cmsis_psa/psa_interface_cross.o
    [132/169] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o
    [133/169] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [134/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o
    [135/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o
    [136/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_Flash.o
    [137/169] Building C object platform/CMakeFiles/platform_s.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.o
    [138/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mpu_armv8m_drv.o
    [139/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o
    [140/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/spm_hal.o
    [141/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o
    [142/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/plat_test.o
    [143/169] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_nvic.o
    [144/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o
    [145/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/target_cfg.o
    [146/169] Building C object platform/CMakeFiles/platform_s.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/modules/tfm/tfm/boards/common/tfm_hal_platform.o
    [147/169] Building C object platform/CMakeFiles/platform_s.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.o
    [148/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/tfm_interrupts.o
    [149/169] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_s_api.o
    [150/169] Building C object platform/CMakeFiles/platform_s.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/modules/tfm/tfm/boards/common/dummy_provisioning.o
    [151/169] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_platform.o
    [152/169] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_memory_symbols.o
    [153/169] Building C object platform/CMakeFiles/platform_s.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/modules/tfm/tfm/boards/src/tfm_ioctl_s_api.o
    [154/169] Building C object platform/CMakeFiles/platform_s.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/modules/tfm/tfm/boards/common/dummy_otp.o
    [155/169] Building C object platform/CMakeFiles/platform_s.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/modules/tfm/tfm/boards/src/tfm_platform_system.o
    [156/169] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/spm/cmsis_psa/psa_interface_cross.o
    [157/169] Building C object platform/CMakeFiles/platform_s.dir/__/interface/src/tfm_psa_call_pack.o
    [158/169] Linking C static library platform\libplatform_s.a
    [159/169] Linking C static library secure_fw\partitions\platform\libtfm_psa_rot_partition_platform.a
    [160/169] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libcrypto_service_mbedcrypto.a
    [161/169] Linking C static library secure_fw\partitions\crypto\libtfm_psa_rot_partition_crypto.a
    [162/169] Linking C static library secure_fw\partitions\lib\sprt\libtfm_sprt.a
    [163/169] Linking C static library secure_fw\spm\libtfm_spm.a
    [164/169] Building C object platform/target/nrf9160/nrf_common/CMakeFiles/tfm_s_scatter.dir/gcc/nordic_nrf_s.ld
    [165/169] Linking C executable bin\tfm_s.axf
    [166/169] Generating ../bin/tfm_s.hex
    [167/169] Linking C static library secure_fw\libtfm_s_veneers.a
    [168/169] Generating ../bin/tfm_s.elf
    [169/169] Generating ../bin/tfm_s.bin
    [63/253] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    [64/253] Generating zephyr/tfm_secure.hex
    [65/253] Completed 'tfm'
    [66/253] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [67/253] Generating include/generated/offsets.h
    [68/253] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [69/253] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [70/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
    [71/253] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_secure.c.obj
    [72/253] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [73/253] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [74/253] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [75/253] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [76/253] Generating linker_zephyr_pre1.cmd
    [77/253] Generating linker_zephyr_pre0.cmd
    [78/253] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [79/253] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [80/253] Building C object zephyr/CMakeFiles/zephyr.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [81/253] Linking C static library zephyr\arch\common\libisr_tables.a
    [82/253] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [83/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [84/253] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [85/253] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [86/253] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [87/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/getaddrinfo.c.obj
    [88/253] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [89/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
    [90/253] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [91/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
    [92/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/socket_offload.c.obj
    [93/253] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [94/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets_select.c.obj
    [95/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
    [96/253] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [97/253] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [98/253] Linking C static library zephyr\arch\common\libarch__common.a
    [99/253] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [100/253] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [101/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [102/253] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [103/253] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/mbedtls/library/platform.c.obj
    [104/253] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [105/253] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [106/253] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [107/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [108/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [109/253] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\zephyr\libmbedtls_zephyr.a
    [110/253] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [111/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [112/253] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [113/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [114/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [115/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [116/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [117/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [118/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [119/253] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [120/253] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
    [121/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [122/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [123/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [124/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [125/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [126/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [127/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [128/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [129/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [130/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [131/253] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [132/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [133/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [134/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [135/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [136/253] Building C object CMakeFiles/app.dir/src/main.c.obj
    [137/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [138/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [139/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [140/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [141/253] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets.c.obj
    [142/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [143/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [144/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [145/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [146/253] Linking C static library app\libapp.a
    [147/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [148/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [149/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [150/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [151/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [152/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [153/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [154/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [155/253] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [156/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [157/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [158/253] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [159/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [160/253] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [161/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [162/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [163/253] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
    [164/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [165/253] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [166/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [167/253] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [168/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [169/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [170/253] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
    [171/253] Building C object zephyr/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
    [172/253] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [173/253] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [174/253] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [175/253] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [176/253] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [177/253] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
    [178/253] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
    [179/253] Linking C static library zephyr\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
    [180/253] Linking C static library zephyr\kernel\libkernel.a
    [181/253] Linking C static library zephyr\lib\posix\liblib__posix.a
    [182/253] Linking C static library zephyr\libzephyr.a
    [183/253] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [184/253] Linking C static library zephyr\lib\libc\newlib\liblib__libc__newlib.a
    [185/253] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [186/253] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [187/253] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [188/253] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [189/253] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/nrf/drivers/entropy/entropy_cc3xx.c.obj
    [190/253] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [191/253] Linking C static library zephyr\subsys\random\libsubsys__random.a
    [192/253] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [193/253] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [194/253] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [195/253] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [196/253] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [197/253] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [198/253] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [199/253] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
    [200/253] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [201/253] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
    [202/253] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
    [203/253] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj
    [204/253] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [205/253] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_platform_ipc_api.c.obj
    [206/253] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
    [207/253] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
    [208/253] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/fault.c.obj
    [209/253] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [210/253] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [211/253] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [212/253] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
    [213/253] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/src/zephyr_tfm_log.c.obj
    [214/253] Linking C static library zephyr\subsys\net\libsubsys__net.a
    [215/253] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
    [216/253] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_psa_ns_api.c.obj
    [217/253] Building C object modules/nrf/lib/at_monitor/CMakeFiles/..__nrf__lib__at_monitor.dir/at_monitor.c.obj
    [218/253] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_ioctl_core_ns_api.c.obj
    [219/253] Building C object modules/nrf/modules/tfm/zephyr/CMakeFiles/tfm_api_nrf.dir/__/tfm/boards/src/tfm_ioctl_ns_api.c.obj
    [220/253] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
    [221/253] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [222/253] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.obj
    [223/253] Building C object modules/nrf/lib/modem_antenna/CMakeFiles/..__nrf__lib__modem_antenna.dir/modem_antenna.c.obj
    [224/253] Linking C static library modules\nrf\lib\at_monitor\lib..__nrf__lib__at_monitor.a
    [225/253] Linking C static library modules\nrf\modules\tfm\zephyr\libtfm_api_nrf.a
    [226/253] Linking C static library zephyr\subsys\net\ip\libsubsys__net__ip.a
    [227/253] Building C object modules/nrf/lib/at_host/CMakeFiles/..__nrf__lib__at_host.dir/at_host.c.obj
    [228/253] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [229/253] Linking C static library modules\nrf\lib\modem_antenna\lib..__nrf__lib__modem_antenna.a
    [230/253] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf91_sockets.c.obj
    [231/253] Linking C static library modules\nrf\lib\at_host\lib..__nrf__lib__at_host.a
    [232/253] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
    [233/253] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [234/253] Linking C static library modules\nrf\lib\nrf_modem_lib\lib..__nrf__lib__nrf_modem_lib.a
    [235/253] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [236/253] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [237/253] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_crypto_ipc_api.c.obj
    [238/253] Linking C static library modules\trusted-firmware-m\libtfm_api.a
    [239/253] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/D_/Nordic/ncs_v2.1.0/ncs2.1.0/v2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [240/253] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [241/253] Linking C executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && D:\Nordic\ncs_v2.1.0\ncs2.1.0\v2.1.0\toolchains\v2.1.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe   @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf  && cmd.exe /C "cd /D D:\Nordic\ncs_v2.1.0\ncs2.1.0\v2.1.0\nrf\samples\nrf9160\at_client\build\zephyr && D:\Nordic\ncs_v2.1.0\ncs2.1.0\v2.1.0\toolchains\v2.1.0\opt\bin\cmake.exe -E echo ""
    'cmd.exe'      ڲ    ⲿ   Ҳ   ǿ    еij
             ļ
    FATAL ERROR: command exited with status 1: 'd:\Nordic\ncs_v2.1.0\ncs2.1.0\v2.1.0\toolchains\v2.1.0\opt\bin\cmake.EXE' --build 'd:\Nordic\ncs_v2.1.0\ncs2.1.0\v2.1.0\nrf\samples\nrf9160\at_client\build'
     *  终端进程已终止,退出代码: 1。
     *  终端将被任务重用,按任意键关闭。
    regard
    owen
  • Hi Owen,
    I am not able to find what the issue is based on the log. Did you get the exact same error when you tried to install the SDK and toolchain closer to the root directory, i.e. with a shorter path? Where did you install it?
    Do you see this error when building other samples and with other boards as well?
    Marte
