PSM floor current is 60uA not 4uA
Hi there,
We are running a power consumption test using PSM mode, and we are however not measuring the 4uA floor current as expected.
We are requesting a active time of 6 minutes, and TAU time of 30minutes. We are also using eDRX.
However after the active time has passed, the device does not go into a low power state. There also appears to be a lot of noise:
I can confirm that the network does assign us the correct timers, as we get the following message in:
+CEREG: 1,"0001","01A2D002",7,,,"00100110","11100000"
Kindly advise what can be the issue here?
  • Hi Dejan,
    Good news, as  advised, it was indeed the uart2 that had to be manually disabled. We also disable serial logging, and we are able to measure a PSM current of 4uA.
    We do however have 3 more questions regarding the power profile. Please see power profile and description below:
    Section 1: Attach procedure including RRC inactivity timer
    Section 2: EDRX paging time window
    Section 3: eDRX interval
    Section 4: AT#XSLEEP=2 command sent to modem to turn of uart1
    Section 5: PSM sleep mode entered with floor current of 4 uA
    The floor current (as specified by the long line in red) during the entire RRC Idle state (where eDRX is active) sits around 40ua.
    1) Is the floor current of 40uA in the RRC Idle state expected, or can that be optimized as well with some project config changes? I think the 40uA makes sense as I think SIM is still active in this state?
    2) There seems to be a random spike (section highlighted by the power profiler app) every 30 seconds between eDRX cycles. Do you have any idea what this might be? It is important for us to understand the power profile perfectly.
    3) How can an external MCU know when the modem goes into and exits from the PSM mode? Is there for example an unsolicited response code which we can enable?
    Frikkie
  • Hi Frikkie,
    In PSM, it should be possible to achieve floor current of around 4us. This is expected for SIM card which is shut down. However, if SIM card is not switched off due to being used frequently, power consumption may rise. Reference value in the Online Power Profiler for SIM stop clock current is around 30 us, which is relatively close to what you see. Some SIM cards are required to go to sleeping state before being completely shut down to prevent flash wear-out. Newer cards for IoT applications have this sleeping time set to around 1 minute or less, while other can have this interval at around 10 minutes.
    I would need to get back to you when I get more information related to this question.
    There is modem sleep notification and periodic TAU notification. You can read more about modem sleep notifications in the documentation.
    Dejan
  • Hi Frikkie,
    The spike that can be seen is switching noise of the PPK when it goes from one measuring region to another. This is expected behavior.
    Dejan
