Encryption of FW images when using MCUBoot + SMP Server for DFU
Greetings,
We are developing a new product based on the nRF52840 and have been using MCUBoot + SMP Server + MCUMgr for DFU via Serial & BLE on our application with great success up to now.
We want however to have encrypted .bin & .zip (for Serial & BLE DFU respectively) so that reverse engineering our FW from the binaries is not possible.
We also want to have downgrade protection so that only newer versions can be updated on the device.
When adding the following configuration options on the MCUBoot (using a .conf file in the child_image folder of our project) configuration to enable encryption of the FW image generated we get the following error:
(documentation used:  Enryption , Encryption ticket #1, Encryption ticket #2Downgrade prevention)
configuration options for MCUBoot - mcuboot.conf
# Encryption configuration
CONFIG_BOOT_SERIAL_ENCRYPT_EC256=y
CONFIG_BOOT_ENCRYPTION_KEY_FILE="C:/ncs/feel_v2_fw/feel_v2_fw/child_image/keys/feel_encrypt_priv.pem"
CONFIG_BOOT_ECDSA_TINYCRYPT=y
CONFIG_SINGLE_APPLICATION_SLOT=y
Error:
In file included from C:\ncs\v2.1.0\bootloader\mcuboot\boot\bootutil\src\bootutil_public.c:43:
C:/ncs/v2.1.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c: In function 'boot_swap_type_multi':
c:\ncs\v2.1.0\bootloader\mcuboot\boot\zephyr\include\sysflash\sysflash.h:15:40: error: 'PM_MCUBOOT_SECONDARY_ID' undeclared (first use in this function); did you mean 'PM_MCUBOOT_PRIMARY_ID'?
   15 | #define FLASH_AREA_IMAGE_SECONDARY(x)  PM_MCUBOOT_SECONDARY_ID
What could be the reason for this? Are we missing any configuration options?
Also as a follwup question, is it easier/better to use the nRF Secure Immutable Bootloader as the first stage? Does this bootloader feature encryption of the generated FW images?
I also understand that it features roll-back protection. Can you confirm this?
Thank you very much!
Stavros
    clockis said:
    The device cannot perform DFU if the FW image of the application is not present and active on the device as it uses the MCUMgr to perform DFU, which is part of the application (DFU cannot be retried as it is not performed by the MCUBoot itself but by the application using MCUMgr) so does this mean if the DFU fails in Single-Slot mode the device is unrecoverable(stays forever in Bootloader mode)?
    In Serial Recovery Mode / single slot, the the bootloader is receiving and writing to the slot. The bootloader is not updated. If something breaks during the DFU, then just retry the DFU.
    clockis said:
    On another note, I was talking with some members/contributors to the Zephyr Project in the Zephyr Discord to learn more about how to achieve the encrypted FW images using the MCUBoot that is already included in our application and I was informed that
    1. The MCUBoot code is currently being reworked to support FW image encryption
    2. It could possibly be included in the upcoming NCS SDK release.
    Could you please confirm if this is indeed the case?
    There might be some plans here, but I'm not aware of them. For roadmap questions, you should contact your local Nordic Semiconductor sales representative
  • In Serial Recovery Mode / single slot, the the bootloader is receiving and writing to the slot. The bootloader is not updated. If something breaks during the DFU, then just retry the DFU.
    Our device does not have a reset button so If I understood correctly cannot be setup to enter Serial Recovery mode. Is there any other way to enter Serial recovery mode that I am not aware of?
    Ok, will do, thank you!
    The Serial Recovery mode is usually activated if a pin is held high at boot, but the mode can also be activated for some time at each boot. So if you can make the app trigger a SW reset, then you will have a time window where you can enter Serial Recovery mode.
    You might find this repo here created by a colleague of mine useful: https://github.com/hellesvik-nordic/samples_for_nrf_connect_sdk/tree/main/bootloader_samples/serial_recovery
  • but the mode can also be activated for some time at each boot
    Ok, I see, a functionality like this is very useful!
    Thank you very much I wasn't aware of this!
