Failed to create ID on LE-Audio DK
Hi Nordic team
According to this post I eliminated all calls to cs47l63, ina231 max14690 pmic in order to migrate the project to my custom hardware.
After that I get the following log on both the audio DK and on my custom hardware:
HR [00:00:00.001,129] <inf> audio_sync_timer: Audio sync timer initialized
HR [00:00:00.001,770] <dbg> nrf5340_audio_dk_nrf5340_cpuapp: core_config: Setting gpiote latency to low power
HR [00:00:00.001,831] <dbg> nrf5340_audio_dk_nrf5340_cpuapp: remoteproc_mgr_boot: Network MCU released.
*** Booting Zephyr OS build v3.1.99-ncs1-1  ***
HR [00:00:11.464,447] <inf> fw_info:
	 nRF5340 Audio nRF5340 Audio DK cpuapp
	 NCS Version: 2.1.2
	 Cmake run : Mon Nov 28 10:32:47 2022
HR [00:00:11.464,477] <inf> fw_info: ------- DEBUG BUILD -------
	 HEADSET right device
HR [00:00:12.030,792] <inf> board_version: Compatible board/HW version found: 0.8.0
HR [00:00:13.649,932] <wrn> ble: Failed to create ID
HR [00:00:13.653,137] <inf> fs_nvs: 6 Sectors of 4096 bytes
HR [00:00:13.653,137] <inf> fs_nvs: alloc wra: 0, f98
HR [00:00:13.653,137] <inf> fs_nvs: data wra: 0, 5c
HR [00:00:16.367,767] <wrn> bt_hci_core: Controller to host flow control not supported
HR [00:00:16.370,819] <inf> bt_hci_core: No ID address. App must call settings_load()
HR [00:00:16.370,880] <inf> ble: MAC: 00:00:00:00:00:00 (public)
HR [00:00:16.371,459] <inf> ble: Controller version: 3303
HR [00:00:26.212,768] <inf> cis_headset: Regular advertising started
settings_load() is called in main - on_ble_core_ready()
"ble: Failed to create ID" confuses me. However, the service is visible on nRF Connect.
Streaming starts on the Audio DK
On my custom hardware strm_state in streamctr.c is always STATE_PAUSED
even when I call this custom function in streamctr.c
int stream_run(void)
	int ret;
	if (strm_state == STATE_PAUSED) {
		ret = le_audio_play();
		if (ret) {
			LOG_WRN("Failed to start playing");
		return ret;
	return 0;
What am I doing wrong here?
Kind regards
Gerry
  • I tested on the Audio DK and assumed that it wouldn't work as I thought interfacing of the cs47l63 had been disabled the code. There were some GPIO functions calls I had to comment out because the project would not build otherwise, but I do not recall which file was in.
    Here is the projected I tested with:
    test_klaud_mod.zip
    Gerry said:
    I would expect to have a I2s signal at the inputs of the MAX98357A, so I would only have to enable the chip with P1.12 right?
    Can you try to probe the lines with a logic analyzer or scope to verify if data is being transferred?
  • Hi Vidar
    I probed the I2s lines, no signal, even with your modified code.
    After investing 100+ hours in this example project and some days in the board files, and also with the help of nordic in several tickets, i was unfortunately not able to get the code to work without the audio DK peripherals. It seems more difficult than expected. Uncommenting the peripherial calls like mentioned here doesn't do the job. Unexpected behavior wherever i change the code. our streaming hardware has only one button, 5 leds and needs the I2s signal. I could never see an I2s signal on the outputs.
    Unfortunately, we have to stop the project or at least pause it, because the effort gets too great. It would be very helpful if nordic had an example project of how the audio DK works without all the peripherals. I think most developers need this as a starting point to develop custom hardware.
    Anyway thanks for your support Vidar
    Best regards
    Gerry
  • Hi Gerry,
    I am sorry to hear about your experience with our LE audio solution. I agree that there are things we can do to improve the developer experience, especially when it comes to development with other HW. I will forward your feedback to the team who is working on this.
    Vidar
  • Thanks Vidar
    i will check back later.
    if you remember, please let me know, when an example or instructions for custom HW is available.
    Best regards
    Gerry
