Why is the SoftDevice automatically NAKing packets?
I'm developing a BLE application on the nRF52832 that uses NRF_SDH_DISPATCH_MODEL_APPSH to receive events from the SoftDevice. My application involves using some software-implemented elliptic-curve cryptographic computations, which can take up to a second and a half to run. I found that if I send enough Characteristic Writes while the nRF52832 is doing the ECC computations, I can overflow the App Scheduler (i.e. app_sched_event_put() in SD_EVT_IRQHandler() returns NRF_ERROR_NO_MEM).
Once I discovered this, I tried finding the upper limits of how many packets my device might have to receive over the air during the ECC computations. What I've found is that if I increase the size of the App Scheduler to about 60, then no matter how long the ECC computations take, I stop seeing NRF_ERROR_NO_MEM and the SoftDevice does not enqueue more than about 50 packets. On a sniffer, I see that the SoftDevice starts NAKing a packet at the Link Layer for an extended period (definitely not due to interference) after it correctly receives a stream of about 50. The ECC computations are running in APP_IRQ_PRIORITY_THREAD, so they should not be able to directly cause the SoftDevice to drop events.
What is the SoftDevice doing here? Is there a recommendation on how to determine the appropriate size of my App Scheduler based on this "automatic NAK" behavior?
I am using s132 v5.1.0.
  • I meant: "How do I determine the maximum number of events that the SoftDevice can hold?". "Worst-case" meaning with events that can happen arbitrarily fast and have the smallest corresponding data structure (e.g. zero-length writes).
  • Maximum number is 6 events/connection as this is the buffer set inside the softdevice. So softdevice will start nacking the connection packets if there are already 6 events due to be pulled by the application at any time.
  • Then why can I induce NRF_ERROR_NO_MEM during ECC computations when my App Scheduler is size 50?
    During ECC computations, the loop which calls nrf_sdh_evts_poll() is blocked. So, the SoftDevice can continue receiving events, but the application will not process them. If the SoftDevice has 6 events in its own buffer, wouldn't that mean that it called app_sched_event_put() only 6 times before the next time nrf_sdh_evts_poll() is called?
    Now, my application does support 4 concurrent connections, but that only accounts for (6*4=)24 events.  All my testing for this issue has been done with only one connection. There are no events in the application that happen comparably frequently to SoftDevice events, so the App Scheduler isn't filling for some other reason.
    The events buffer is inside the softdevice memory region and not the application memory region. The size of app_scheduler event buffer does not correlate directly to the size of the softdevice events buffer. If the call to nrf_sdh_evts_poll is blocked, during the ECC computations, then the application is not pulling the events out of the softdevice events buffer. Which means that the softdevice event buffer gets filled up quite fast.
    The size of the app_scheduler buffer corresponds to how many times you can call app_sched_event_put without calling app_sched_execute. The sched events can be any (in our case these are softdevice events) data.
    In simple design, the longer the thread which calls nrf_sdh_evt_poll is blocked in the midst of BLE activity that can generate softdevice events, the faster it is possible to fill up softdevice specific internal event buffer (not controlled by app and not the same as app_scheduler event buffer)
  • Yes, I understand all that. I think there might be some confusion over what I'm asking. I've figured out the "What is the SoftDevice doing here?" in concept, and now I'm trying to figure out the second part: "Is there a recommendation on how to determine the appropriate size of my App Scheduler based on this "automatic NAK" behavior?" I've opened a new thread.
