Renaming connected device
Hello Nordic
I am developing a sensor application using nRF52833. The user must be able to connect to the nRF52833 and give it a new name. I have a name characteristic that the user will write the new name to. When the nRF52833 receives the new name, it should disconnect and start advertising the new name. Then the user will reconnect using the new name.
I have read a lot of post on this subject. But none of them seems to work for me. I get the general idea about how to do it:
  • Set the new name using sd_ble_gap_device_name_set
  • Restart the advertising, several ways to do it are described in posts
I am using: SDK 17.1.0
Code starting point: examples\ble_peripheral\ble_app_template
I can rename the nRF52833, but nothing happens until a power cycling takes place.
This is my code:
In the main file I check whether the user has requested a new name. Then I set the new name and run the advertisement initialization again (suggested in this forum)
 if (is_new_device_name_requested()) // if the user has requested a new name for this sensor, then go ahead and set it
        NRF_LOG_INFO("setting new device name");
        set_device_name(DEVICE_NAME);
        advertising_init();
The set_device_name function is shown below:
void set_device_name(uint8_t* first_name)
ret_code_t err_code;
memset(full_device_name, 0, sizeof full_device_name);
strcpy(full_device_name, first_name);
strcat(full_device_name, general_par.last_device_name);
(const uint8_t *)full_device_name,
strlen(full_device_name));
general_par.is_new_device_name_wanted = false;
The advertising_init function is shown below:
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
  • Hi Thomas,
    Sorry for my misunderstanding. I thought you meant that the name was not changed when you said nothing happens.
    Have you explicitly called a function to start advertising when disconnection happen?
    For reference, this is the code doing so in the ble_app_blinky example:
            case BLE_GAP_EVT_CONNECTED:
                // ... omitted ...
                NRF_LOG_INFO("Disconnected");
                bsp_board_led_off(CONNECTED_LED);
                err_code = app_button_disable();
                advertising_start();
            // ... omitted ...
                // No implementation needed.
  • Hi Hieu
    Thank you for answering me so fast. I have tried to follow your example from ble_app_blinky. In connected mode the user requests a new name. I set the new name using set_device_name and I call the adv_data_update() function, that contains ble_advertising_advdata_update.
            adv_data_update();
    Then my codes receive an event from the bluetooth stack. I try to follow the blinky example:
        ret_code_t err_code = NRF_SUCCESS;
                NRF_LOG_INFO("Disconnected.");
                advertising_start(false);
    The NRF52833 crashes with NRF_ERROR_INVALID_STATE error.
    <info> app: setting new device name
    <info> app: Updating advertising data!
    <info> app: Advertising data updated!
    <info> app: Fast advertising.
    <info> app: Disconnected.
    <error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at R:\Produkter\HBCLS\4.Produktion\Software\Release\Git control\nRF5_SDK_17.1.0_ddde560\cal_sw\cal_sw\cal_sw\main.c:1449
    PC at: 0x0002BCFD
    <error> app: End of error report
    <info> app: Setting vector table to bootloader: 0x00077000
    Before this crash, there is a log saying: "Fast advertising" and "Disconnected". Maybe the advertising has somehow restarted already when I try to restart it. I have tried to comment out the advertising_start function call, but then there is no advertising following a device rename.
  • Hi Thomas,
    Sorry, it seems I am unable to keep the fast response going Disappointed
    Could you let me know what the function that outputs "Fast advertising" look like?
    And what function returns NRF_ERROR_INVALID_STATE? Was it ble_advertising_advdata_update()?
    If so, the possible causes are documented here: ble_advertising_advdata_update().
    Please notice that it also returns any error code that the functions it uses return. For NRF_ERROR_INVALID_STATE, sd_ble_gap_adv_set_configure() is also relevant; and the possible causes are documented here: sd_ble_gap_adv_set_configure().
    Hieu
  • Hi Hieu
    The "Fast advertising" message comes from the following function:
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising..");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
    The function that returns NRF_ERROR_INVALID_STATE is shown below. The error is generated by the call to "ble_advertising_start"
    static void advertising_start(bool erase_bonds)
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
  • Hi Thomas,
    I looked at the Advertising Module more closely and see that adding a call to ble_advertising_start() like I previously advised is not necessary. The module itself already done that, and you can see by looking at its on_disconnected() function. ble_app_blinky() does not use the Advertising Module and thus need that setup.
    My apology about this.
    However, now I am confused why you initially don't have advertising data then...
    Could you please use debug, put a breakpoint at the line that calls ble_advertising_start() in on_disconnected() in ble_advertising.c?
    If you could, it would be better to use breakpoint in ble_advertising_start() itself to check exactly where the error was reported.
    But in doing this, you need to pay attention to only enable the breakpoint right before a disconnection. In an BLE application, a breakpoint cannot be recovered from (because a halt in execution breaks BLE timing). Therefore, if you enable the breakpoint from the beginning, you will run into it at the initial advertising start, before the connection is established.
