I have a simple SPI circuit to read data from a flash memory W25Q64 to be exact and I have difficult time reading the device address of the chip through SPI.
The situation is SPI works but just that the data received is wrong.
I tried a bunch of solutions like setting the Frequency to 1Mhz, 4MHz and 8 MHz and still the situation is the same. ( external spi flash memory read as per this solution)
There are no pullup resistors connected as of now to the circuit.
The more weird part is if I remove the Vcc to the memory chip, I get the correct data that I expect to receive.
Please help me with the same.
The code is as follows:
#include "app_error.h"
#include "boards.h"
#include "nrf_drv_spi.h"
#include "nrf_delay.h"
#define LEDBUTTON_LED BSP_BOARD_LED_2
#define WB_JEDEC_ID 0x9F
#define ID_READ 4 // 4
#define SPI_CS 34
#define SPI_MISO 35
#define SPI_MOSI 36
#define SPI_SCK 37
#define APP_CFG_CHAR_LEN 20
static uint8_t m_char_value[APP_CFG_CHAR_LEN];
static const nrf_drv_spi_t m_spi = NRF_DRV_SPI_INSTANCE(0);
void spi_init()
ret_code_t err_code;
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
// spi_config.ss_pin = SPI_CS;
spi_config.ss_pin = NRF_DRV_SPI_PIN_NOT_USED;
spi_config.miso_pin = SPI_MISO;
spi_config.mosi_pin = SPI_MOSI;
spi_config.sck_pin = SPI_SCK;
spi_config.frequency = NRF_DRV_SPI_FREQ_4M;
spi_config.bit_order = NRF_SPI_BIT_ORDER_MSB_FIRST;
spi_config.mode = NRF_SPI_MODE_0;
err_code = nrf_drv_spi_init(&m_spi, &spi_config, NULL, NULL);
nrf_gpio_cfg_output(SPI_CS);
nrf_gpio_pin_set(SPI_CS);
void read_id()
uint8_t reg_addr[4]={WB_JEDEC_ID, 0x00, 0x00, 0x00};
uint8_t read_temp[ID_READ];
nrf_gpio_pin_clear(SPI_CS);
nrf_drv_spi_transfer(&m_spi, reg_addr, sizeof(reg_addr), read_temp, ID_READ);
// nrf_drv_spi_transfer(&m_spi, reg_addr, 1, read_temp, ID_READ);
for (int i = 1; i < ID_READ; i++)
m_char_value[i] = read_temp[i];
m_char_value[ID_READ] = 0x44;
int cnt = 0;
spi_init();
// Main loop.
for (;;)
read_id();
if (cnt%2)
bsp_board_led_on(LEDBUTTON_LED);
bsp_board_led_off(LEDBUTTON_LED);
nrf_delay_ms(25);
cnt ++;
