nRF52840 Possible Flash Damage
I seemed to be randomly causing problems to our nRF52840 Zephyr v2.02 sensor's flash.
Previously I had bricked 3 sensors somehow. Before full production, I need to know what I am doing wrong and how is this happening.
How many times can the flash be written?
I update the sensor by BLE (not SMP) from our nRF52840 Gateway that is connected by its host processor to the internet for image download.
With my current code I can update one of sensors but the other one I cannot. It seems to give a hard fault when img_mgmt_read_info() or img_mgmt_impl_write_pending() are called after the whole new image has been written. I have not been able to debug the reason since the BLE is running. I tried to call bt_disable(); before the img_mgmt calls but the program then crashes.
I can program both sensors with the merged.hex file by way of the SDK or the debugger.
The "good" sensor DFU update always goes OK and does not revert to the old image when reset.
My DFU process:
 In my main at startup I call ami_dfu_Init() which allocates memory.
After the Gateway connects when performing an upgrade, I call ami_dfu_Start() which erases the flash's slot and initializes streaming.
I use a ring buffer to receive the image's packets [ami_dfu_ReceivingPacket()} and flash only accumulated 512 byte chucks [ami_dfu_HandleAndRespond()].
Would it be better to use larger chucks to flash or is it possible? (Just another question but the problem).
I use img_mgmt_impl_write_image_data() to write the data.
When the entire image has been written, I call as shown below and then reset.
            // All of the image was written?
            if (dfu_state->FileWrOffset>=dfu_state->FileSize.ulong){
              int image_slot = 1;
              struct image_version ver;
              uint8_t  hash;
              uint32_t flags;
              bool permanent = false;
// bt_disable();// ?!?
              err = img_mgmt_read_info(image_slot,&ver,&hash,&flags);
              if (err==0){
                err = img_mgmt_impl_write_pending(image_slot,permanent);
                if (err==0){
                  d_printf(LINE_INFO,kDbg_Error|kDbg_General,"FinishedDFU");
                }else{
                      dfu_state->err = AMI_DFU_CENTRAL_ERR_SET_PENDING;
                      d_printf(LINE_INFO,kDbg_Error|kDbg_General,"FinishedDFU ErrSetPending");
              }else{
                    dfu_state->err = AMI_DFU_CENTRAL_ERR_RD_INFO;
                    d_printf(LINE_INFO,kDbg_Error|kDbg_General,"ImageInfoErr:%d",err);
              // Reset after reply
              ami_state->reset_secs = 4;
Here is the whole file:
#include <stddef.h>
#include <string.h>
#include <stdio.h>
#include <errno.h>
#include <kernel.h>
#include <zephyr.h>
#include <sys/printk.h>
#include <zcbor_encode.h>
#include <zcbor_decode.h>
#include <zcbor_common.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/hci_vs.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <bluetooth/gatt_dm.h>
#include <zephyr/sys/byteorder.h>
#include <bluetooth/services/dfu_smp.h>
#include <sys/reboot.h>
#include <zephyr/sys/ring_buffer.h>
#include <dfu/mcuboot.h>
#include <zephyr/dfu/mcuboot.h>
#include <dfu/dfu_target.h>
#include <dfu/dfu_target_stream.h>
#include <dfu/dfu_target_mcuboot.h>
#include <img_mgmt/img_mgmt_impl.h>
#include <img_mgmt/img_mgmt.h>
#include <img_mgmt/image.h>
#include <storage/flash_map.h>
#include <dfu/flash_img.h>
#include <devicetree.h>
#if FLASH_AREA_LABEL_EXISTS(image_1)
	#define UPLOAD_FLASH_AREA_ID FLASH_AREA_ID(image_1)
#include "aqua_def.h"
#include "d_printf.h"
#include "ami_ble.h"
#include "ami_main_serv.h"
#include "ami_setup_serv.h"
#include "ami_learn_serv.h"
#include "ami_transfer_serv.h"
#include "ami_timer.h"
#include "ami_dfu.h"
#include "ami_watchdog.h"
// define Ring buffers
RING_BUF_ITEM_DECLARE_SIZE(dfu_ring_buf, AMI_DFU_RING_BUF_SIZE);
// Variables
ami_dfu_state_struct    *dfu_state = NULL;
static struct	flash_img_context flash_img;
// ami_dfu_ReceivingPacket
//  Description
//   Parses an incoming BLE image packet
//  Parameters
//  Returns
//   0 = OK
int ami_dfu_ReceivingPacket(uint8_t *buf,uint16_t buf_pos,uint16_t len)
  // transfer_receive_cb
  int       err = 0;
  uint16_t  data_len;
  // FileRxOffset
  dfu_state->FileRxOffset.bytes[LSB_LO_BYTE] = buf[buf_pos++];
  dfu_state->FileRxOffset.bytes[LSB_HI_BYTE] = buf[buf_pos++];
  dfu_state->FileRxOffset.bytes[MSB_LO_BYTE] = buf[buf_pos++];
  dfu_state->FileRxOffset.bytes[MSB_HI_BYTE] = buf[buf_pos++];
  // If FileRxOffset==0 then FileSize sent
  if (!dfu_state->FileRxOffset.ulong){
    dfu_state->FileSize.bytes[LSB_LO_BYTE] = buf[buf_pos++];
    dfu_state->FileSize.bytes[LSB_HI_BYTE] = buf[buf_pos++];
    dfu_state->FileSize.bytes[MSB_LO_BYTE] = buf[buf_pos++];
    dfu_state->FileSize.bytes[MSB_HI_BYTE] = buf[buf_pos++];
    d_printf(LINE_INFO,kDbg_Error|kDbg_General,"FileSize %lu",dfu_state->FileSize.ulong);
  data_len = (len-buf_pos);
  // Something to write to Flash
  if (data_len){
    // Store image data
    if (dfu_state->FileRingWrOffset==dfu_state->FileRxOffset.ulong){
      uint16_t num_put = ring_buf_put(&dfu_ring_buf,&buf[buf_pos],data_len);
      if (num_put!=data_len) {
        err            = AMI_DFU_CENTRAL_ERR_RING_OVERFLOW;
        dfu_state->err = AMI_DFU_CENTRAL_ERR_RING_OVERFLOW;
        d_printf(LINE_INFO,kDbg_Error|kDbg_General,"RingPut:%u Rx:%u Off:%ld",num_put,data_len,dfu_state->FileRxOffset.ulong);
        return err;
      }else{
            dfu_state->FileRingWrOffset += data_len;
    }else{
          // This was a retry that the Central did not received an acknowledgemnet
  return err;
} // ami_dfu_ReceivingPacket
// ami_dfu_HandleAndRespond
//  Description
//   Handles the incoming DFU image block as acculmulated
//  Parameters
//  Returns
//   After subscribe - returns the State field which contains if slot erase and init were OK.
//   Otherwise the offset next to write
uint32_t ami_dfu_HandleAndRespond(void)
  static   uint8_t wr_buf[CONFIG_IMG_BLOCK_BUF_SIZE];
  bool     bLast      = false;
  // If there was a fatal error, just return the last error
  if (dfu_state->err){
    return dfu_state->err;
  dfu_state->replies++;
  if (dfu_state->replies==1){
    return ami_state->State.ulong;
  // All bytes were received?
  bool bRxFinished = (dfu_state->FileRingWrOffset>=dfu_state->FileSize.ulong);
  do{
      // Peek and see how many bytes accumulated exist
      uint32_t accum_bytes = ring_buf_size_get(&dfu_ring_buf);
      // Wait to write until we have CONFIG_IMG_BLOCK_BUF_SIZE bytes or last packet
      if (accum_bytes<CONFIG_IMG_BLOCK_BUF_SIZE && !bRxFinished){
      // Don't write more than CONFIG_IMG_BLOCK_BUF_SIZE bytes at a time
      if (accum_bytes>CONFIG_IMG_BLOCK_BUF_SIZE){
        accum_bytes = CONFIG_IMG_BLOCK_BUF_SIZE;
      // Calculate the number of bytes left to write to flash
      uint32_t bytes_to_wr = (dfu_state->FileSize.ulong-dfu_state->FileWrOffset);
      // Last block to write?
      if (accum_bytes>=bytes_to_wr){
        accum_bytes = bytes_to_wr;
        bLast       = true;
        d_printf(LINE_INFO,kDbg_Error|kDbg_General,"DFU LastWr %u",accum_bytes);
      // Get the bytes from the ring buffer
      uint32_t data_len   = ring_buf_get(&dfu_ring_buf,wr_buf,accum_bytes);
      // Nothing to write?
      if (!data_len){
      // Write the data to the flash
      int err = img_mgmt_impl_write_image_data(dfu_state->FileWrOffset,wr_buf,data_len,bLast);
      if (err!=0) {
        dfu_state->err = AMI_DFU_CENTRAL_ERR_WR_BLOCK;
        d_printf(LINE_INFO,kDbg_Error|kDbg_General,"ImageWrErr:%d",err);
      }else{
            d_printf(LINE_INFO,kDbg_Info|kDbg_General,"FlashWr:%ld %u",dfu_state->FileWrOffset,data_len);
            // Update last offset written
            dfu_state->FileWrOffset += data_len;
              int image_slot = 1;
              uint8_t  hash;
              uint32_t flags;
              if (err==0){
                if (err==0){
                }else{
              }else{
  }while (bRxFinished);
  return dfu_state->FileRingWrOffset;
} // ami_dfu_HandleAndRespond
// ami_dfu_Start
//  Description
//   Inits the dfu state, erases slot and sets the dfu streaming buffer
//  Parameters
//  Returns
//  AMI_DFU_CENTRAL_ERR_NONE = OK
int ami_dfu_Start(void)
  // Clear dfu state
  memset(dfu_state,0,sizeof(ami_dfu_state_struct));
  // Reset dfu ring buffer
  ring_buf_reset(&dfu_ring_buf);
  // Erase upload slot
  int err = img_mgmt_impl_erase_slot();
  if (err!=0){
#ifdef TBD
    dfu_state->err = AMI_DFU_CENTRAL_ERR_ERASE;
    d_printf(LINE_INFO,kDbg_Error|kDbg_General,"ImageEraseErr:%d", err);
    return err;
  // Init Flash stream writer (CONFIG_IMG_BLOCK_BUF_SIZE)
  g_img_mgmt_state.area_id = UPLOAD_FLASH_AREA_ID;
  err = flash_img_init(&flash_img);
  if (err!=0){
    d_printf(LINE_INFO,kDbg_Error|kDbg_General,"FlashInitErr:%d", err);
    dfu_state->err = AMI_DFU_CENTRAL_ERR_IMAGE_INIT;
#ifdef TBD
    return err;
  return AMI_DFU_CENTRAL_ERR_NONE;
} // ami_dfu_Start
// ami_dfu_Init
//  Description
//   Alolocates memory
//  Parameters
//  Returns
//   0 = OK
int ami_dfu_Init(void)
  int err = 0;
  // Allocate memory
  dfu_state  = k_malloc(sizeof(ami_dfu_state_struct));
  while (!dfu_state);
  return err;
} // ami_dfu_Init
Also:
In my main file at startup, I check if the image is confirmed and the system reports it is not.
I do not know if this could cause a problem since at least when the debugger is running the code it always is never confirmed and the write confirmed does nothing.
  // DFU upgraded and not confirmed, confirm
  if (!boot_is_img_confirmed()){
    err = boot_write_img_confirmed();
      if (err) {
          d_printf(LINE_INFO,kDbg_Error|kDbg_Display,"BootConfirmErr:%d",err);
    }else{
          d_printf(LINE_INFO,kDbg_Error|kDbg_Display,"BootConfirmed");
Calling boot_is_img_confirmed() returns BOOT_FLAG_UNSET.
Calling boot_write_img_confirmed() calls boot_set_confirmed(); which calls boot_set_confirmed_multi(0);
In boot_set_confirmed_multi() state_primary_slot.magic=3 (BOOT_MAGIC_UNSET) and goes to done without doing anything!
   switch (state_primary_slot.magic) {
    case BOOT_MAGIC_GOOD:
        /* Confirm needed; proceed. */
    case BOOT_MAGIC_UNSET:
        /* Already confirmed. */
        goto done;
    case BOOT_MAGIC_BAD:
        /* Unexpected state. */
        rc = BOOT_EBADVECT;
        goto done;
github.com/.../1066
  • Here is my.config file.
    2330.config.txt
    My project proj.conf
    #stCount
    # Copyright (c) 2018 Nordic Semiconductor
    CONFIG_BT=y
    CONFIG_BT_DEBUG_LOG=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_APPEARANCE=1344
    CONFIG_BT_MAX_CONN=1
    #CONFIG_BT_LL_SOFTDEVICE=y
    CONFIG_BT_DEVICE_NAME="VaporBLE"
    # Enable Dynamic name modification
    CONFIG_BT_DEVICE_NAME_DYNAMIC=y
    # Maximum character of the device name
    # (Range: 2 to 248)
    CONFIG_BT_DEVICE_NAME_MAX=20
    CONFIG_BT_SMP=y
    CONFIG_BT_SIGNING=y
    # If yes then there is a random MAC advertised
    CONFIG_BT_PRIVACY=n
    # Allow for updating data length
    CONFIG_BT_USER_DATA_LEN_UPDATE=y
    # Allow for Phy change
    CONFIG_BT_USER_PHY_UPDATE=y
    # Device Information
    CONFIG_BT_DIS=y
    CONFIG_BT_DIS_PNP=n
    CONFIG_BT_DIS_MODEL="VaporBT"
    CONFIG_BT_DIS_MANUF="AMI Global"
    CONFIG_BT_DIS_SERIAL_NUMBER=y
    CONFIG_BT_DIS_SERIAL_NUMBER_STR="0523382370"
    CONFIG_BT_DIS_FW_REV=y
    CONFIG_BT_DIS_FW_REV_STR="000.000"
    CONFIG_BT_DIS_HW_REV=y
    CONFIG_BT_DIS_HW_REV_STR="000.000"
    CONFIG_BT_DIS_SW_REV=y
    CONFIG_BT_DIS_SW_REV_STR="000.000"
    # Below is setup to let DIS information be read from settings
    CONFIG_BT_SETTINGS=y
    CONFIG_SETTINGS_RUNTIME=y
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_NONE=y
    CONFIG_BT_DIS_SETTINGS=y
    CONFIG_BT_DIS_STR_MAX=21
    # TX Power
    #CONFIG_BT_CTLR_TX_PWR_PLUS_4=y
    #CONFIG_BT_CTLR_ADVANCED_FEATURES=y
    #CONFIG_BT_CTLR_CONN_RSSI=y
    CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
    # Passkey not used
    CONFIG_BT_AMI_CM_SECURITY_ENABLED=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=32768
    CONFIG_FPU=y
    CONFIG_NEWLIB_LIBC=y
    # for Spectral|Impact DSP
    CONFIG_CMSIS_DSP=y
    CONFIG_CMSIS_DSP_SUPPORT=y
    CONFIG_CMSIS_DSP_FASTMATH=y
    CONFIG_CMSIS_DSP_COMPLEXMATH=y
    CONFIG_CMSIS_DSP_STATISTICS=y
    CONFIG_CMSIS_DSP_TRANSFORM=y
    #CONFIG_CMSIS_DSP_TABLES_ALL_FAST=y
    #CONFIG_CMSIS_DSP_TABLES_ALL_FFT=y
    CONFIG_CMSIS_DSP_TABLES_ALL_FAST=n
    CONFIG_CMSIS_DSP_TABLES_ALL_FFT=n
    CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_F32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_COS_F32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_CMPLX_MAG_Q31=y
    CONFIG_CMSIS_DSP_TABLES_RFFT_F32_512=y
    # Watchdog
    #CONFIG_WDT_LOG_LEVEL_DBG=y
    CONFIG_WATCHDOG=y
    # GPIO
    CONFIG_GPIO=y
    # I2c for 24LC512
    CONFIG_I2C=y
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_LOG_LEVEL_OFF=y
    # EEPROM
    CONFIG_EEPROM=y
    CONFIG_EEPROM_AT24=y
    # SPI for LSM6DSL
    CONFIG_SPI=y
    CONFIG_NRFX_SPIM1=y
    # LSM6DSL
    CONFIG_SENSOR=y
    CONFIG_LSM6DSL=y
    CONFIG_AMI_LSM6DSL_EXTEND_CFG=y
    CONFIG_LSM6DSL_ACCEL_FS=2
    CONFIG_LSM6DSL_ACCEL_ODR=0
    # Power management
    CONFIG_PM=y
    CONFIG_PM_DEVICE=y
    CONFIG_PM_DEVICE_RUNTIME=y
    #CONFIG_PM_STATS=y
    #CONFIG_STATS=y
    CONFIG_PINCTRL=y
    CONFIG_MULTITHREADING=y
    # ADC
    CONFIG_ADC=y
    CONFIG_ADC_ASYNC=y
    # Timers
    CONFIG_NRFX_TIMER1=y
    # USE RTT  Instead of Uart
    CONFIG_CONSOLE=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    # below for DFU
    # Enable mcumgr.
    CONFIG_MCUMGR=y
    # DFU Target ?!? new
    CONFIG_DFU_TARGET=y
    CONFIG_DFU_TARGET_MCUBOOT=y
    CONFIG_STREAM_FLASH_ERASE=y
    CONFIG_STREAM_FLASH=y
    #CONFIG_IMG_ERASE_PROGRESSIVELY=y
    #CONFIG_IMG_BLOCK_BUF_SIZE=512 by default and gives an error when set higher ?!?
    #CONFIG_IMG_BLOCK_BUF_SIZE=8192
    #CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # ?!? new 14-Dec-2022
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_RING_BUFFER=y
    # The image management command handlers makes it possible to upload, list, test and confirm the image(s)
    CONFIG_MCUMGR_CMD_IMG_MGMT=y
    # The OS management command handlers makes it possible to reset the chip (and run the echo command).
    CONFIG_MCUMGR_CMD_OS_MGMT=y
    # Ensure an MCUboot-compatible binary is generated.
    CONFIG_BOOTLOADER_MCUBOOT=y
    # Allow for large Bluetooth data packets for uploading binary (Nordic Definitions)
    # commented when smp srv stuff added
    #CONFIG_BT_L2CAP_TX_MTU=252
    #CONFIG_BT_BUF_ACL_RX_SIZE=256
    # Enable the Bluetooth (unauthenticated) and shell mcumgr transports.
    CONFIG_MCUMGR_SMP_BT=y
    CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    # Some command handlers require a large stack.
    # already set CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    # Below from the throughput example
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
    # Below from the smp srv example
    # Allow for large Bluetooth data packets.
    CONFIG_BT_L2CAP_TX_MTU=498
    CONFIG_BT_BUF_ACL_RX_SIZE=502
    CONFIG_BT_BUF_ACL_TX_SIZE=502
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    # Enable the Bluetooth mcumgr transport (unauthenticated).
    CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL=y
    # Enable the Shell mcumgr transport.
    # ?!? no need for shell CONFIG_MCUMGR_SMP_SHELL=y
    # Enable the mcumgr Packet Reassembly feature over Bluetooth and its configuration dependencies.
    # MCUmgr buffer size is optimized to fit one SMP packet divided into five Bluetooth Write Commands,
    # transmitted with the maximum possible MTU value: 498 bytes.
    CONFIG_MCUMGR_SMP_REASSEMBLY_BT=y
    CONFIG_MCUMGR_BUF_SIZE=2475
    CONFIG_OS_MGMT_MCUMGR_PARAMS=y
    # ?!? already set CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    # Enable the LittleFS file system.
    CONFIG_FILE_SYSTEM=y
    CONFIG_FILE_SYSTEM_LITTLEFS=y
    # Enable file system commands
    # ?!? CONFIG_MCUMGR_CMD_FS_MGMT=y
    # Enable the storage erase command.
    CONFIG_MCUMGR_GRP_ZEPHYR_BASIC=y
    CONFIG_MCUMGR_GRP_BASIC_CMD_STORAGE_ERASE=y
    I have a overlay-secure_bootloader.conf file along the proj.conf
    # Copyright (c) 2021 Nordic Semiconductor ASA
    #CONFIG_SECURE_BOOT=y
    #CONFIG_SB_SIGNING_KEY_FILE="prev.pem"
    #CONFIG_BUILD_S1_VARIANT=y
    #CONFIG_SPM_SERVICE_S0_ACTIVE=y
    # Iadded this
    #CONFIG_NCS_MCUBOOT_IN_BUILD=y
    And in the child_image a mcuboot.conf
    CONFIG_PM=n
    CONFIG_MAIN_STACK_SIZE=10240
    CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
    CONFIG_BOOT_SWAP_SAVE_ENCTLV=n
    CONFIG_BOOT_ENCRYPT_RSA=n
    CONFIG_BOOT_ENCRYPT_EC256=n
    CONFIG_BOOT_ENCRYPT_X25519=n
    CONFIG_BOOT_UPGRADE_ONLY=n
    CONFIG_BOOT_BOOTSTRAP=n
    CONFIG_FLASH=y
    CONFIG_FPROTECT=y
    CONFIG_LOG=y
    CONFIG_LOG_MODE_MINIMAL=y # former CONFIG_MODE_MINIMAL
    ### Ensure Zephyr logging changes don't use more resources
    CONFIG_LOG_DEFAULT_LEVEL=0
    ### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y
    CONFIG_CBPRINTF_NANO=y
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    ### ?!? 18-Dec-2022 Without this swap is used which limits upgrades 10000 / (150 / 4) ~ 267
    CONFIG_BOOT_SWAP_USING_MOVE=y
    My boards directory is based on the generic nRF52840
    boards.zip
    I did not see some of the defines you highlighted in my build .config file.
    I just want to make sure I am not using the swap with the 256 upgrade limitation.
    Thanks David
    Unfortunately II couldn't identify the cause to the issue before the Holidays. I'll be out of office until the 29th, but in the meanwhile a colleague of mine will handle this case. Hopefully they will have the time to look into the issue and come with suggestions, but due to the staffing throughout the holiday period it's expected that the response time will be longer until the first week of January where we're fully staffed again.
    I hope this does not cause too many issues for you,
    Andreas
    As Andreas said, I will continue to help with this case.
    To make sure I have not missed anything, can you confirm if this is your current questions?
    1. You do want to know which swap type you use
    2. You are concerned that you have a limited amount of DFUs available before you use up the flash.
    Let me know if there was anything I have missed in the case.
    Swap Type:
    To figure out which swap type your project has, you can find that in VS Code after you built your project:
    Which swap type does your project use?
    Sigurd Hellesvik
  • To recap things:
    I previously did not define CONFIG_BOOT_SWAP_USING_MOVE=y since I was unaware of the consequences.
    In my current sensor code, I added a child_image folder and copied the mcuboot's prog.conf file adding the CONFIG_BOOT_SWAP_USING_MOVE=y #define in a mcuboot.conf file.
    I then programmed two sensors with the new code and then transferred the new image (with only the date changed) by my non-SMP BLE file transfer procedure.
    One sensor was programmed OK and the other not.
    I then connected the debugger and issued nrfjprog --readcode on both the good and bad sensors and uploaded to you the hex files along with the bootloader report.
    1.hex for the first sensor (failed) and nrfjprog --readcode 2.hex for the good sensor.
    The sensors will soon be in field tests and if I am doing something wrong, I need to know now.
    1) Does loading a new program when debugging count as an erasure?
    I have used sensor#1 quite a bit in debugging.
    2) I erase the slot on the sensor before starting its file transfer and do not use CONFIG_IMG_ERASE_PROGRESSIVELY=y.
    Would it be better to use progressive erasures and not erase it at the start?
    Before I start the DFU, I call img_mgmt_impl_erase_slot() to erase slot1 and flash_img_init().
    Then, I use img_mgmt_impl_write_image_data() to write incoming 512-byte blocks of the image.
    When I have finished writing the whole image to slot 1, I call img_mgmt_read_info() and img_mgmt_impl_write_pending()
    with the write pending permanent flag false. It is all in the code in my post.
    3) The default nRF52840 block size is 512 bytes. Would it help to increase it if possible?
    I tried once 1024 but it did not work or maybe I did not change the proper define.
    Thanks David
    When I run "debug" in VS Code, it calles this command to flash the chip:
    west flash -d c:\ncs\v2.2.0\zephyr\samples\hello_world\build --skip-rebuild -r nrfjprog --dev-id 1050084572
    So it flashes the chip, but does not erase the flash.
    From CONFIG_IMG_ERASE_PROGRESSIVELY:
    "If enabled, flash is erased as necessary when receiving new firmware, instead of erasing the whole image slot at once. This is necessary on some hardware that has long erase times, to prevent long wait times at the beginning of the DFU process."
    It seems that this configuration is for changing how fast the DFU goes.
    I suggest that you try to time your DFU with and without this configuration, to find which setting works best for you.
    I assume that you mean: "Will it help to decrease flash wear?"
    The way I understand it, the scratch size is mostly important if you use swap-scratch, as it will decrease the amount of times you write to the same flash.
    However, you should use swap-move, as it reduces wear on the flash.
    In this case, here is from Swap without using scratch:
    "The algorithm does two erase cycles on the primary slot and one on the secondary slot during each swap. Assuming that receiving a new image by the DFU application requires 1 erase cycle on the secondary slot, this should result in leveling the flash wear between the slots."
    From this it looks like the swap-move will only do a set number of erases, no matter the block size.
    For more information on swap alternatives, see MCUboot swap-scratch algorithm  and The Swap-Move algorithm in MCUboot .
    Sigurd Hellesvik
