No device found with bt_le_scan_start and observer
Dear,
I am using nRF5340 and I am trying to scan devices around me. With the example observer my device founds other devices around me, but when I use the same configuration and the same functions into my project the device doesn't find anything. The code is the same, exactly the same but I can't see anything.
The prj.conf is
#Peripherals
CONFIG_GPIO=y
CONFIG_SPI=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_PRINTK=y
# Bootloader
CONFIG_BOOTLOADER_MCUBOOT=y
# Bluetooth configuration
CONFIG_BT=y
#CONFIG_BT_PERIPHERAL=y
#CONFIG_BT_DEVICE_NAME="Test"
#CONFIG_BT_DEBUG_LOG=y
#CONFIG_BT_CENTRAL=y
#CONFIG_BT_SCAN=y
CONFIG_BT_OBSERVER=y
# Other
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_LOG=y
And the code is:
#include <zephyr/bluetooth/hci.h>
#if (APP_DEBUG_ON == 1)
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
static void deviceFound (const bt_addr_le_t *addr,
                         int8_t rssi,
                         uint8_t type,
                         struct net_buf_simple *buf)
    char dev[BT_ADDR_LE_STR_LEN];
    // if (type == BT_GAP_ADV_TYPE_ADV_SCAN_IND)
        bt_addr_le_to_str(addr, dev, sizeof(dev));
        printk("[DEVICE]: %s, AD evt type %u, AD data len %u, RSSI %i\n",dev, type, buf->len, rssi);
void Bluetooth_init (void)
    int err = 0;
    err = bt_enable(NULL);
    if (err)
        printk("ERROR: Bluetooth init failed (err %d)\n", err);
        goto bluetooth_init_error;
    printk("BLUETOOTH0: Bluetooth initialized\n");
	struct bt_le_scan_param scanParam =
        .type       = BT_LE_SCAN_TYPE_PASSIVE,
        .options    = BT_LE_SCAN_OPT_FILTER_DUPLICATE,
        .interval   = BT_GAP_SCAN_FAST_INTERVAL,
        .window     = BT_GAP_SCAN_FAST_WINDOW,
    err = bt_le_scan_start(&scanParam, deviceFound);
    if (err)
        printk("ERROR: Scanning failed to start (err %d)\n", err);
    printk("BLUETOOTH0: Scanning successfully started\n");
bluetooth_init_error:
    if (err)
        // TODO
The output log is:
Where is it the error? Haw can I debug this issue?
Thanks
Marco
  • Hi Hieu,
    Ok, I have a problem. At this time the CPU is always doing something in the application code... (in the clear project that I used for the previous test, the while loop is empty).
    Which is the solution? Add in the main loop a ksleep or something else to switch threads (it is my first time with operating systems).
    About your last question: yes, the code is the same and there was code into the main loop.
    Best
    Marco
  • Hi Marco,
    Sorry I just now returned after a few days of sick leaves.
    It is curious why there is no issue when you add advertising. I would assume the same problem will arise.
    That being said, I too am not an expert with RTOS. I had to double check carefully with a colleague before sending my last reply.
    I am sure that adding ksleep is a solution, having tried that myself. However, I am not certain that it is the best solution. My not-an-expert suggestion is indeed to use different threads to handle different duties, rather than doing everything in a while loop. Without knowing what you are doing in that while loop, that is the best suggestion I can make right now.
    If you wish to learn more about the OS, Nordic does provide the nRF Connect SDK Fundamentals free online course. The Lesson 7 and 8 are made by the same colleague I mentioned above and should give you some idea. Though I suggest you still start from Lesson 1, and quickly skim and skip any topics you already know, rather than skipping the entire thing. There are some knowledge dependencies between the lessons.
    Hieu
  • Hi Hieu,
    thank you for your suggestion, I'll study the course. If you have any news, please share it with me!
    In the meantime, I am facing another problem with USB, and I suppose that the issue is the same... but for this, I'll open a new ticket.
    Best
    Marco
  • Hi Marco,
    I consult further with the same colleague again. The lessons that I linked previously are the best resources we would currently recommend.
    Beyond the lessons, please read the documentation of the Zephyr OS. In particular, I think this page and its subpages are of immediate interest:
    Kernel Services — Zephyr Project Documentation (nordicsemi.com)
    We cannot really advise on how to setup the application in deeper details, as that depends a lot on teams'/personal preferences and the projects' natures.
    Hieu
