LWM2M Client - Power Management/callback functions
Good day
I have noticed that when using a callback functions certain limitations exist.  For example, adding functions to the callback function will run into an error or a timeout.  Firstly, I wanted to ask what the limitations when using a callback function(specifically lwm2m ).  Secondly, I am using
pm_device_action_run(uart_dev, PM_DEVICE_ACTION_SUSPEND);  and
pm_device_action_run(uart_dev, PM_DEVICE_ACTION_RESUME);
to dynamically turn the UART on and off during the callback function.  I was able to switch the UART on but when I use pm_device_action_run(uart_dev, PM_DEVICE_ACTION_SUSPEND at the end of the function, the UART does not switch off despite the function returning a 0.  What could be the cause of this?  I am aware that these issues are rather specific and any advice would be worthwhile.
Hassan
  • Hello
    Its from my understanding, that the command can be used dynamically (I may be wring) so I'm using it whenever the an event is triggered.  This way when an update is triggered the command is sent.  This part works fine.
    tatic void rd_client_event(struct lwm2m_ctx *client, enum lwm2m_rd_client_event client_event)
    	k_mutex_lock(&lte_mutex, K_FOREVER);
    	if (client_state == LTE_OFFLINE &&
    	    client_event != LWM2M_RD_CLIENT_EVENT_ENGINE_SUSPENDED) {
    		LOG_DBG("Drop network event %d at LTE offline state", client_event);
    		k_mutex_unlock(&lte_mutex);
    		return;
    	UART_multiple_handler();
    	RAI_init();
    	switch (client_event) {
    	case LWM2M_RD_CLIENT_EVENT_NONE:
    		/* do nothing */
    	case LWM2M_RD_CLIENT_EVENT_BOOTSTRAP_REG_FAILURE:
    		LOG_DBG("Bootstrap registration failure!");
    		state_trigger_and_unlock(NETWORK_ERROR);
    	case LWM2M_RD_CLIENT_EVENT_BOOTSTRAP_REG_COMPLETE:
    		LOG_DBG("Bootstrap registration complete");
    		update_session_lifetime = true;
    		state_trigger_and_unlock(BOOTSTRAP);
    	case LWM2M_RD_CLIENT_EVENT_BOOTSTRAP_TRANSFER_COMPLETE:
    		LOG_DBG("Bootstrap transfer complete");
    	case LWM2M_RD_CLIENT_EVENT_REGISTRATION_FAILURE:
    		LOG_WRN("Registration failure!");
    	case LWM2M_RD_CLIENT_EVENT_REGISTRATION_COMPLETE:
    		LOG_DBG("Registration complete");
    		state_trigger_and_unlock(CONNECTED);
    		RAI_init();
    	case LWM2M_RD_CLIENT_EVENT_REG_TIMEOUT:
    		LOG_DBG("Registration update failure!");
    	case LWM2M_RD_CLIENT_EVENT_REG_UPDATE_COMPLETE:
    		LOG_DBG("Registration update complete");
    		RAI_init();
    	case LWM2M_RD_CLIENT_EVENT_DEREGISTER_FAILURE:
    		LOG_DBG("Deregister failure!");
    		reconnect = true;
    	case LWM2M_RD_CLIENT_EVENT_DISCONNECT:
    		LOG_DBG("Disconnected");
    		state_set_and_unlock(START);
    	case LWM2M_RD_CLIENT_EVENT_QUEUE_MODE_RX_OFF:
    		LOG_DBG("Queue mode RX window closed");
    		if (IS_ENABLED(CONFIG_LWM2M_CLIENT_UTILS_RAI)) {
    			lwm2m_rai_last();
    	case LWM2M_RD_CLIENT_EVENT_ENGINE_SUSPENDED:
    		LOG_DBG("LwM2M engine suspended");
    	case LWM2M_RD_CLIENT_EVENT_NETWORK_ERROR:
    		LOG_ERR("LwM2M engine reported a network error.");
    		reconnect = true;
    void RAI_init()
    	// RAI Setup
    	static char response[200] = { 0 };
    	response[0] = '\0';
    	 k_sleep(K_MSEC(100));
    	nrf_modem_at_cmd(response, sizeof(response), "AT%%XRAI=3");
    	LOG_WRN("RAI RESPONSE: %d",response );
    However, when I do the same thing at the end of the callback function i don't get the same result.  It seems as though the modem is used immediately after the indication is sent (Some code was redacted)
    static void *read_cb(uint16_t obj_inst_id, uint16_t res_id, uint16_t res_inst_id, size_t *data_len)
    	uart_enable();
    		int c, d;
    	LOG_WRN("IN CUSTOM READ_CB");
    	LOG_WRN("obj_inst_id: %d", obj_inst_id);
    	if (obj_inst_id != 1) {
    		*data_len = 0;
    		return NULL;
    	int err = lwm2m_engine_set_float("3300/1/5700", &sensor_value);
    	LOG_WRN("sensor value string: %d", err);
    	LOG_WRN("sensor value string: %s", numC);
    	LOG_WRN("sensor value double: %f", sensor_value);
    	if (err) {
    		LOG_ERR("Could not set custom sensor value: %d", err);
    		*data_len = 0;
    		return NULL;
    	*data_len = sizeof(sensor_value);
    	RAI_init();
    	return &sensor_value;
    	else if(ret<0)
    		sensor_value = 0;
    		 RAI_init();
    Do you have any suggestions of where to add the XRAI command to get the same result with the callback function?
    Which modem firmware version and SDK do you use?
    If you use modem firmware v1.3.x and NCS v2.2.0, you could have a look at additional configuration in LwM2M Client Utils.
    Dejan
  • Good day
    yes I do use the latest firmware.  When I use
    CONFIG_LWM2M_CLIENT_UTILS_RAI=y in the prj file I do not see RAI being used.  I have to wait 60s before entering edrx mode.  Is there more I need to do to ensure it works as required?
    Which network operator do you have? Does it support AS RAI?
    Dejan
  • Good day
    I will have to contact them to make sure.  However, XRAI works well.  Have you any idea how I can get in functional for the callback function?
