Radio Test with Skyworks FEM + NRF52840
I needed assistance to get the SKY66403-11 FEM working with the Radio Test Example in VS Code, for certification testing (FCC, CE etc). I am using the NCS 2.2.0 SDK.  I am using a custom board with nRF52840 SoC and it has the LFXO present.
I have added the device tree node as depicted below in the sample code, created as an existing project.:
nrf_radio_fem: SKY66403 {
		compatible = "skyworks,sky66403-11", "generic-fem-two-ctrl-pins";
		ctx-gpios = <&gpio1 01 GPIO_ACTIVE_HIGH>;
		crx-gpios = <&gpio1 04 GPIO_ACTIVE_HIGH>;
		chl-gpios = <&gpio1 06 GPIO_ACTIVE_HIGH>;
		cps-gpios = <&gpio0 24 GPIO_ACTIVE_HIGH>;
Are there any additional changes required beside these to be done to get the FEM working because while building this I get the following build error.
FAILED: CMakeFiles/app.dir/src/radio_cmd.c.obj
C:\nordicsemi\toolchains\v2.2.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF52840_XXAA -DUSE_PARTITION_MANAGER=0 -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/nordicsemi/v2.2.0/zephyr/include -Izephyr/include/generated -IC:/nordicsemi/v2.2.0/zephyr/soc/arm/nordic_nrf/nrf52 -IC:/nordicsemi/v2.2.0/zephyr/lib/util/fnmatch/. -IC:/nordicsemi/v2.2.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/nordicsemi/v2.2.0/nrf/include -IC:/nordicsemi/v2.2.0/nrf/lib/multithreading_lock/. -IC:/nordicsemi/v2.2.0/nrf/tests/include -IC:/nordicsemi/v2.2.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/nordicsemi/v2.2.0/modules/hal/nordic/nrfx -IC:/nordicsemi/v2.2.0/modules/hal/nordic/nrfx/drivers/include -IC:/nordicsemi/v2.2.0/modules/hal/nordic/nrfx/mdk -IC:/nordicsemi/v2.2.0/zephyr/modules/hal_nordic/nrfx/. -IC:/nordicsemi/v2.2.0/modules/debug/segger/SEGGER -IC:/nordicsemi/v2.2.0/modules/debug/segger/Config -IC:/nordicsemi/v2.2.0/zephyr/modules/segger/. -IC:/nordicsemi/v2.2.0/nrfxlib/mpsl/include -IC:/nordicsemi/v2.2.0/nrfxlib/mpsl/include/protocol -I../../../bluetooth/direct_test_mode/src/fem -isystem C:/nordicsemi/v2.2.0/zephyr/lib/libc/minimal/include -isystem c:/nordicsemi/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include -isystem c:/nordicsemi/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/include-fixed -isystem C:/nordicsemi/v2.2.0/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros C:/nordicsemi/v2.2.0/nrf/samples/peripheral/radio_test/build_nofem/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/nordicsemi/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/nordicsemi/v2.2.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/nordicsemi/v2.2.0/nrf/samples/peripheral/radio_test=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/nordicsemi/v2.2.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/nordicsemi/v2.2.0=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/src/radio_cmd.c.obj -MF CMakeFiles\app.dir\src\radio_cmd.c.obj.d -o CMakeFiles/app.dir/src/radio_cmd.c.obj -c ../src/radio_cmd.c
c:\nordicsemi\v2.2.0\nrf\samples\peripheral\radio_test\src\radio_cmd.c:64:20: error: 'CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB' undeclared here (not in a function)
   64 |         .txpower = CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB,
 PS: Just wanted to mention that I tried running the Radio Test Example directly without adding the support for the FEM and that works as expected.
Thanks in Advance
    2
    3
    4
    5
    6
    7
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    I have added my node as mentioned earlier in the nrf52840dk_nrf52840.dts file. Should that matter?
    It matters what is the location of your nrf52840dk_nrf52840.dts file. If you put it in your project folder, it will not work as you expect. However, modifying existing nrf52840dk_nrf52840.dts file which is located in \v2.0.0\zephyr\boards\arm\nrf52840dk_nrf52840 should work as expected. You can check if Skyworks configuration is included after building the project by looking at zephyr.dts file which is located in your build\zephyr folder. In order to avoid modifying existing dts file, it is recommended to use nrf52840dk_nrf52840.overlay file instead. You can put this overlay file in your project directory.
    Dejan
    I am using the Radio test sample as is (as an existing project), and haven't created a separate project directory.
    As you suggested to check the build\zephyr folder, I did and found the changes for the FEM node to be present. As I am not very well versed to create a custom .overlay file, didn't do that and instead changed the <board>.dts file directly.
    I'll just post the warnings I get after building here as well for reference.
    Any other pointers for what I should check/do next.
    If you want to try the way I suggested, please make sure that you have unmodified file \v2.0.0\zephyr\boards\arm\nrf52840dk_nrf52840\nrf52840dk_nrf52840.dts. When you have verified that this dts file is unmodified, proceed with steps outlined below.
    1. Make freestanding application in VS Code based on radio_test sample in NCS v2.0.0. When the application is made, radio_test directory is created. This is what I referred to as your project directory. You don't need to have separate project directory other than radio_test.
    2. Inside your project directory (radio_test), create a file called nrf52840dk_nrf52840.overlay. The content of this file should be (in case you use nRF52840-DK) as shown below
        nrf_radio_fem: SKY66112 {
    		compatible = "skyworks,sky66112-11", "generic-fem-two-ctrl-pins";
    		ctx-gpios = <&gpio1 10 GPIO_ACTIVE_HIGH>;
    		crx-gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>;
    		chl-gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>;
    		cps-gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>;
    3. Create a build configuration in VS Code and add following Extra CMake arguments
    -DCONFIG_MPSL=y
    -DCONFIG_MPSL_FEM=y
    -DCONFIG_MPSL_FEM_SIMPLE_GPIO=y
    4. Build your application
    You may still see some warnings, but the build should be successful.
    Dejan
    I made the file as you described. Below is the content and location of the same. Also reverted the changes on .dts
    After building I do get a new error.
