Setting Matter bridge to BLE device
Hello.
Thank you for your support.
I am trying to build a BLE bridge for Matter.
I was able to create the Matter Lock sample and Ble app separately, but I am having trouble figuring out how to connect the Ble app from the Matter Lock sample.
Would it be better to connect Matter and BLE app on two nrf52840dk by connecting them with UART from GPIOs?
Or is it better to build BLE app into Matter sample?
Matter Lock sample:
nrf Connect SDK 2.0.0
BLE smart lock app:
Using ble_app_multirole_lesc_s140_pca10056
Thank you.
  • Hi Marte,
    I could build up BLE app with peripheral_UART sample. Thank you.
    Then I would like to merge BLE app into Matter door lock sample.
    How could I set up?
    Shin
  • Hi Shin,
    I think the best way to implement this is to look at how SMP is implemented and used in the Matter samples. I started implementing this myself, but I have not been able to test it yet. I will try to test it and get back to you tomorrow.
    Marte
    I was able to successfully test that it works, so I have added the example to github here: https://github.com/martelmy/NCS_examples/tree/main/matter/light_bulb_ble_uart.
    You can use this as a starting point when developing this yourself. I just wanted to make a simple example to test that it works, so now it only handles receiving one character at a time, but you can expand it to receive strings. Look at the Peripheral UART sample for help with this.
    If you want to test this example, make sure to add overlay-multiprotocol_ble.conf as OVERLAY_CONFIG when building, if not, NUS will not be enabled. I sometimes see that the device shows up without a name when scanning, but you can identify it by looking for the NUS UUID. If you are unable to connect to it, press button 3 and try again.
    I will explain what I did so it might be easier to use this or do something similar yourself.
    bt_nus.cpp and bt_nus.h
    In my implementation I looked at how the SMP service is handled, as I mentioned in my previous reply. So if you look in the src directory you can see that I have created two new files: bt_nus.cpp and bt_nus.h. These are similar to the dfu_over_smp files you can find in nrf/samples/matter/common/src in the SDK. I have modified StartBLEAdvertising() to add the correct data for the scan response packets, and I have added OnNUSReceived() to handle receiving NUS events. If you look at OnNUSReceived() you will see that it is very simple, as it only prints the first character received, so here you can add your own implementation.
    CMakeLists.txt
    As mentioned, I have created an overlay file overlay-multiprotocol_ble.conf with the necessary configurations. When you add this to your build, you will set CONFIG_BT_NUS, which will make it so bt_nus.cpp is added as a target_source in CMakeLists.txt:
    if(CONFIG_BT_NUS)
        target_sources(app PRIVATE src/bt_nus.cpp)
    endif()
    app_config.h
    Here I simply added BLE_NUS_BUTTON for button 3, which I use somewhere else to start advertising NUS.
    #define BLE_NUS_BUTTON DK_BTN3
    #define BLE_NUS_BUTTON_MASK DK_BTN3_MSK
    app_event.h
    The only thing I did in app_event.h was to add StartNUSAdvertising to AppEventType:
    enum class AppEventType : uint8_t {
    	None = 0,
    	Button,
    	ButtonPushed,
    	ButtonReleased,
    	Timer,
    	UpdateLedState,
    	Lighting,
    	IdentifyStart,
    	IdentifyStop,
    	StartSMPAdvertising,
    	StartNUSAdvertising
    app_task.h
    Then in app_task.h I include bt_nus.h and added StartBLENUSHandler() and RequestNUSAdvertisingStart() to AppTask:
    class AppTask {
    public:
    private:
    	static void FunctionHandler(const AppEvent &event);
    	static void StartBLENUSHandler(const AppEvent &event);
    	static void StartBLEAdvertisementAndLightActionEventHandler(const AppEvent &event);
    #ifdef CONFIG_MCUMGR_SMP_BT
    	static void RequestSMPAdvertisingStart(void);
    #ifdef CONFIG_BT_NUS
    	static void RequestNUSAdvertisingStart(void);
    app_task.cpp
    Of the existing files, this is the one where I made the most changes.
    I added so that advertising will start during AppTask init by calling RequestNUSAdvertisingStart()
    	/* Initialize BLE NUS */
    	GetNUS().Init(RequestNUSAdvertisingStart);
    This function is implemented a bit further down:
    void AppTask::RequestNUSAdvertisingStart(void)
    	AppEvent event;
    	event.Type = AppEventType::StartNUSAdvertising;
    	event.Handler = [](const AppEvent &) { GetNUS().StartBLEAdvertising(); };
    	PostEvent(event);
    In the ButtonEventHandler I added a check for BLE_NUS_BUTTON (button 3) that calls StartBLENUSHandler().
    if (BLE_NUS_BUTTON & hasChanged) {
    	button_event.ButtonEvent.PinNo = BLE_NUS_BUTTON;
    	button_event.ButtonEvent.Action =
    		static_castuint8_t>((BLE_NUS_BUTTON_MASK & buttonState) ? AppEventType::ButtonPushed :
    									    AppEventType::ButtonReleased);
    	button_event.Handler = StartBLENUSHandler;
    	PostEvent(button_event);
    StartBLENUSHandler was implemented further down, and it will start NUS advertising by calling GetNUS().StartServer().
    void AppTask::StartBLENUSHandler(const AppEvent &event)
    	if (event.ButtonEvent.PinNo != BLE_NUS_BUTTON)
    		return;
     	Instance().mFunction = FunctionEvent::NoneSelected;
    		GetNUS().StartServer();
    #else
    		LOG_INF("NUS is disabled");
    I hope this helps you get started!
    Marte
